EG and VCF not working after battery leakage
2014-05-27 by phil0065@yahoo.fr
Bonjour !
I am French and happy to join this group of Polysix owner. My old Polysix bought back in 1983 has been sleeping in the attic since 1990, until I have returned back now to my first love. Unfortunately I have discovered the battery leakage problem !
So I did the standard procedure (like many)
Spend a lot of time checking the lines on KLM-367 with plenty of leds on at start up..
Browse internet for hours (discover service manual, old crown, etc)…, change IC 30 & 31 … recheck continuity, still few leds on..
Recheck again, change all set of panel switches (vintage planet)..4 leds on... Bank B not working...
Check lines again, to get finally only leds A1 on start up. Great !
Unfortunately sound is not OK.
Tune seems OK, 6 voices are OK, voltages from power board are OK (15V, 5V -5V and -15V) all pots and switches seem to work except the 4x EG and 4x VCF pots which are not active!
I think at this stage it is useless to do the calibration procedure. Is there some indications, checking to start with to define if it is still a line/continuity problem or if electronic parts (IC, diode..) should be changed.
Thanks in advance for your help
Phil
Re: [PolySix] EG and VCF not working after battery leakage
2014-05-28 by Bob Grieb
See if these functions can be controlled correctly when using patches
in memory.  If so, then the output from the CPU to the analog circuits
is OK.   Then you have a problem with reading the controls.
But if the sound is always the same with all programs, then the
output circuit is bad and maybe t is reading from the pots OK.
Did you try the DAC calibration test in the manual?  It would be helpful
to know if that is working OK.  Just the part where you try to get the
two LEDs to light up.
  Bob
 From: "phil0065@yahoo.fr [PolySix]" <PolySix@yahoogroups.com>
To: PolySix@yahoogroups.com
Sent: Tuesday, May 27, 2014 6:02 PM
Subject: [PolySix] EG and VCF not working after battery leakage
Bonjour !
I am French
Unfortunately sound
is not OK.
Tune seems OK,
active!
I think at
Thanks in
Phil
2014-05-28 by Phil65
Thanks Bob for your quick answer !
Seems that my patch looses "EG" from memory. I have no sound unless I put the VCA switch from EG back to "square" again to get some sound.
Not sure to keep the bank memory even when polysix is still on.
I did the procedure and it passes directly. Here a quick summary:
*dummy 56 ohm => all leds on
*remove resistance => A1 leds
*SW1 in test mode and tape switch to enable => Only leds 1+8 on
* SW1 back to normal => still leds 1+8
* "7 ) confirm that output DC click noise is within 6V p-p when power is switched off" => sorry I don't understand precisely what to do/ measure?
 * Power on again => A1 leds on.
Thanks for your support
Phil
En date de : Mer 28.5.14, Bob Grieb bobgrieb@yahoo.com [PolySix] <PolySix@yahoogroups.com> a écrit :
 Objet: Re: [PolySix] EG and VCF not working after battery leakage
 À: "PolySix@yahoogroups.com" <PolySix@yahoogroups.com>
 Date: Mercredi 28 mai 2014, 2h09
 See if
 patchesin
 circuitsis
 controls.But
 output
 OK.Did
 be helpfulto
 get the
 two
 LEDs to light up.
 Bob
  To:
 2014 6:02 PM
 and VCF not
       Bonjour !I am
 French
 leakage problem !
 So I did
 the standard procedure (like many)Spend a
 up.. Browse internet for hours (discover service
 on..Recheck again, change all set of
 working...Check
 Unfortunately sound
 is not OK.
 Tune seems
 OK,
 which are not
 active! I think at
 should be changed.
 Thanks in
  Phil
Hi Phil,
     If you are seeing LEDs 1 and 8 in DAC calibration mode, that implies
that the DAC and the input muxes are working.   Another thing to try -
in the DAC calibration test mode, turn the two controls that you were supposed
to set for this test, and you should see the LED's change.
    Don't worry about the click noise test for now.
    The voltage demux for controlling the EG and the VCF is mostly
IC18 (4051).   I would check with the ohmmeter that you have good connections
(with the power off, of course) between pin 3 of IC18 and pin 1 of IC27, and between
pin 6 of IC18 and IC23-4.  Also, pins 9,10 and 11 of IC18 and 19 should be connected
to each other and to IC22.
    With power on, you should be able to vary a front panel control,
such as filter cutoff, and see IC7 pin 7 change voltage as you do it (in manual
mode).   And when you select different patches, you should see the attack at IC10-1
decay at IC10-7, etc changing with different patches.  Be careful when probing with
the power on not to short anything or you can damage chips in an instant.  Use the gnd
test pt for the meter black or negative lead.
    Tell us what you measure at these points in the circuit and if they vary with the
corresponding front panel control in manual mode, or when you change patches.
    Bob
 From: "Phil65 phil0065@yahoo.fr [PolySix]" <PolySix@yahoogroups.com>
Sent: Wednesday, May 28, 2014 6:05 PM
Subject: Re: [PolySix] EG and VCF not working after battery leakage
Phil
See if
patchesin
circuitsis
controls.But
output
OK.Did
be helpfulto
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
leakage problem !
So I did
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
which are not
active! I think at
should be changed.
Thanks in
Phil
Hi Bob,
You are really helpfull. Merci !
1) I did the DAC calib again and turning VR6 CCW  => from led 8 to led 7 6 then 5,  while turning VR7 CCW from led 8 to 7 then 6
2)   pin 3 of IC18 and pin 1 of  IC27, OK
3)  pin  6 of IC18 and IC23-4.  OK
4) pins 9,10 and 11 of IC18 and  19 should be connected to  each other and to IC22 ?
  It seems I have a problem here. I found only IC18-9 + IC19-9 + IC22 -5 , IC22-19 and IC22-35 connected together. Nothing between IC18-10 (IC18-11) with any pin of IC19 or IC22 ??
Shall I strap IC18-9 + 10 + 11
5) With power on, you should be able to vary a front panel
 control,such  as filter cutoff, and see IC7 pin 7 change voltage as you
  do it (in manual   mode).
3.177V => 3.120V cut off from 10 to 0 with all controls at normal setting
 6) when you select different patches, you should see the  attack at IC10-1decay
=> On IC 10-1 no change always 13.56V
 7) Decay  at IC10-7 ?
=>slight variation between patches. In manual mode and normal setting with decay control from 0 to 10 => 3.240V to 3.346V
 Thanks for your help, really appreciated !
Phil
En date de : Jeu 29.5.14, Bob Grieb bobgrieb@yahoo.com [PolySix] <PolySix@yahoogroups.com> a écrit :
 Date: Jeudi 29 mai 2014, 0h21
       Hi Phil,
 impliesthat
 to try -
 in
 you were supposedto
 change.
 now.
 mostlyIC18
 good connections(with
 IC27, and between
 pin
 19 should be connectedto
 control,such
  do it (in manual
 mode).
 when probing with
 instant.  Use the gndtest
 corresponding
 patches.
 Bob
  To:
 28, 2014 6:05 PM
 on.
 summary:
 1+8 on
 Phil
 leakage
  See if
  patchesin
 analog
  circuitsis
  controls.But
  output
  OK.Did
 would
  be helpfulto
 to
  get the
  two
  LEDs to light up.
  Bob
   To:
  2014 6:02 PM
  and VCF not
        Bonjour !I am
  French
 have
 battery
  leakage problem !
  So I did
 leds on at start
  working...Check
  Unfortunately sound
  is not OK.
  Tune seems
  OK,
 5V
 pots
  which are not
  active! I think at
 Is
 diode..)
  should be changed.
  Thanks in
   Phil
 #yiv8680019145 #yiv8680019145 --
2014-05-29 by Bob Grieb
These should be connected:
IC18-9 IC19-9 and IC22-23  this is signal "P22"
IC18-10 IC19-10 and IC22-22  this is signal "P21"
IC18-11 IC19-11 and IC22-21  this is signal "P20"
IC19-6 and IC23-10
Also, IC18-3 must connect to IC19-3 as well as to IC27-1 which you checked already.
You may want to download the service manual as it is available for
free on the web, and see the schematic for KLM-367.
If IC18 and IC19 are not connected properly, the control voltages
won't work correctly.
Please ignore IC22 pins 5, 19,and 35.    They are not related to
this discussion.  We are checking A B C and INH signals to IC18 and IC19.
   Bob
Sent: Wednesday, May 28, 2014 7:55 PM
Hi Bob,
Phil
Hi Phil,
impliesthat
to try -
in
you were supposedto
change.
now.
mostlyIC18
IC27, and between
pin
control,such
do it (in manual
mode).
when probing with
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
on.
summary:
1+8 on
Phil
leakage
See if
patchesin
analog
circuitsis
controls.But
output
OK.Did
would
be helpfulto
to
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
have
battery
leakage problem !
So I did
leds on at start
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
5V
pots
which are not
active! I think at
Is
diode..)
should be changed.
Thanks in
Phil
2014-05-29 by Phil65
Looking at the klm367 schematic, I understand now your point with the connections between pins and signal P20, P21 and P22 but I had some diffuculty to cross link that information with the PCB drawing... until  I realize that i was counting incorrectly the pins while I did know that it was from top right then CCW
Do what I say, not what I do... I was correct for top side numbers but reverse for the bottom side i.e i did restart with 9 below 1... Stupid!
So now I do have the following:
P22          IC18-9 IC19-9 and IC22-23     => OK
P21          IC18-10 IC19-10 and IC22-22  => OK
P20          IC18-11 IC19-11 and IC22-21  => OK
INH          IC19-6 and  IC23-10               => OK
"X"           IC18-3 and IC19-3 and IC27-1 =>OK
I did recheck my previous post to correct them in light of my wrong pin counting
OK
OK
OK
UPDATED: Wrong comment see above!
UPDATED: Luckily correct, I did measure in fact pin 6 but it is strapped to pin 7...
UPDATED: Correct measurement
UPDATED: Again Luckily correct, I did measure in fact pin 6 but it is strapped to pin 7...
I apologize for my mistake and thanks again for your patience and your support.
Phil
 Date: Jeudi 29 mai 2014, 3h28
 These should be
 connected:
 is signal "P22"
 this is signal
  "P21"
 IC19-6 and
 IC23-10
 service manual as it is available forfree on the web, and see the
 won't work
 correctly.
 IC19.
    Bob
  To:
 28, 2014 7:55 PM
       Hi Bob,
 to 7 then 6
 IC22 ??
 panel
 voltage as you
 at normal setting
 to 3.346V
 Phil
 leakage
        Hi Phil,
 that
  impliesthat
 thing
  to try -
  in
 that
  you were supposedto
  change.
  now.
  mostlyIC18
 have
 of
  IC27, and between
  pin
 and
  control,such
 you
   do it (in manual
  mode).
 careful
  when probing with
 an
 and
  corresponding
  patches.
  Bob
   To:
  28, 2014 6:05 PM
 to
 still
  on.
  summary:
 leds
  1+8 on
 6V
 don't
  Phil
 battery
  leakage
   See if
   patchesin
  analog
   circuitsis
   controls.But
   output
   OK.Did
  would
   be helpfulto
 try
  to
   get the
   two
   LEDs to light up.
   Bob
    To:
   2014 6:02 PM
   and VCF not
         Bonjour !I am
   French
  have
  battery
   leakage problem !
   So I did
 of
  leds on at start
 not
   working...Check
   Unfortunately sound
   is not OK.
   Tune seems
   OK,
  5V
  pots
   which are not
   active! I think at
 procedure.
  Is
  diode..)
   should be changed.
   Thanks in
    Phil
    So it seems that all of those connections are OK.  Please check the
IC23 connections next.  P23 from IC22 to IC23-12,13,8, and the other
connections on IC23 which you can see on the schematic.   I am assuming
that you do not have an oscilloscope, right?
    You say you have 13.56 volts at IC10-1   That's interesting, as
IC18 outputs should range from -5 to +5 only.   Does IC10 have -15
on pin 4?   Does IC18 have +5 on pin 16 and -5 on pin 7?
   Bob
Sent: Thursday, May 29, 2014 4:47 AM
OK
OK
OK
Phil
These should be
connected:
is signal "P22"
this is signal
"P21"
IC19-6 and
IC23-10
won't work
correctly.
IC19.
   Bob
To:
28, 2014 7:55 PM
Hi Bob,
to 7 then 6
IC22 ??
panel
voltage as you
at normal setting
to 3.346V
Phil
leakage
Hi Phil,
that
impliesthat
thing
to try -
in
that
you were supposedto
change.
now.
mostlyIC18
have
of
IC27, and between
pin
and
control,such
you
do it (in manual
mode).
careful
when probing with
an
and
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
to
still
on.
summary:
leds
1+8 on
6V
don't
Phil
battery
leakage
See if
patchesin
analog
circuitsis
controls.But
output
OK.Did
would
be helpfulto
try
to
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
have
battery
leakage problem !
So I did
of
leds on at start
not
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
5V
pots
which are not
active! I think at
procedure.
Is
diode..)
should be changed.
Thanks in
Phil
2014-05-29 by Johannes Hausensteiner
Most probably IC1 on KLM-370 (the 4051 analog mux) is dead. I had this
before; the leaked battery acid crawls along the thick black ground wire
up to KLM-370 and continues its destructive work there. Replace that
black wire as well.
Good luck!
Johannes
On 29.05.2014 13:34, Bob Grieb bobgrieb@yahoo.com [PolySix] wrote:
> Hi,
>     Bob
> *From:* "Phil65 phil0065@yahoo.fr [PolySix]" <PolySix@yahoogroups.com>
> *To:* PolySix@yahoogroups.com
> *Sent:* Thursday, May 29, 2014 4:47 AM
> *Subject:* Re: [PolySix] EG and VCF not working after battery leakage
> counting
> OK
> OK
> OK
> to IC22 ?
> to pin 7...
> IC10-1decay
> support.
> Phil
> <PolySix@yahoogroups.com> a �crit :
> �: "PolySix@yahoogroups.com" <PolySix@yahoogroups.com>
> These should be
> connected:
> is signal "P22"
> this is signal
> "P21"
> IC19-6 and
> IC23-10
> won't work
> correctly.
> IC19.
>     Bob
> From: "Phil65
> To:
> 28, 2014 7:55 PM
> Hi Bob,
> to 7 then 6
> IC22 ??
> panel
> voltage as you
> at normal setting
> to 3.346V
> Phil
> [PolySix] <PolySix@yahoogroups.com> a �crit :
> leakage
> Hi Phil,
> that
> impliesthat
> thing
> to try -
> in
> that
> you were supposedto
> change.
> now.
> mostlyIC18
> have
> of
> IC27, and between
> pin
> and
> control,such
> you
> do it (in manual
> mode).
> the
> careful
> when probing with
> the
> an
> and
> corresponding
> patches.
> Bob
> From:
> To:
> 28, 2014 6:05 PM
> to
> still
> on.
> summary:
> leds
> 1+8 on
> 6V
> don't
> Phil
> battery
> leakage
> See if
> patchesin
> analog
> circuitsis
> controls.But
> the
> output
> OK.Did
> would
> be helpfulto
> try
> to
> get the
> two
> LEDs to light up.
> Bob
> From:
> To:
> 2014 6:02 PM
> and VCF not
> Bonjour !I am
> French
> have
> battery
> leakage problem !
> So I did
> of
> leds on at start
> manual, old crown, etc)\u2026, change IC
> 30 & 31 \u2026 recheck continuity, still few leds
> not
> working...Check
> Unfortunately sound
> is not OK.
> Tune seems
> OK,
> 5V
> pots
> which are not
> active! I think at
> procedure.
> Is
> diode..)
> should be changed.
> Thanks in
> Phil
> #yiv8680019145ygrp-mkp {
> border:1px solid #d8d8d8;font-family:Arial;margin:10px
> 0;padding:0 10px;}
> #yiv8680019145 #yiv8680019145ygrp-mkp hr {
> border:1px solid #d8d8d8;}
> #yiv8680019145 #yiv8680019145ygrp-mkp #yiv8680019145hd {
> color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
> 0;}
> #yiv8680019145 #yiv8680019145ygrp-mkp #yiv8680019145ads
> margin-bottom:10px;}
> #yiv8680019145 #yiv8680019145ygrp-mkp .yiv8680019145ad {
> padding:0 0;}
> #yiv8680019145 #yiv8680019145ygrp-mkp .yiv8680019145ad p
> margin:0;}
> #yiv8680019145 #yiv8680019145ygrp-mkp .yiv8680019145ad a
> color:#0000ff;text-decoration:none;}
> #yiv8680019145 #yiv8680019145ygrp-sponsor
> #yiv8680019145ygrp-lc {
> font-family:Arial;}
> #yiv8680019145ygrp-lc #yiv8680019145hd {
> margin:10px
> 0px;font-weight:700;font-size:78%;line-height:122%;}
> #yiv8680019145ygrp-lc .yiv8680019145ad {
> margin-bottom:10px;padding:0 0;}
> #yiv8680019145 #yiv8680019145actions {
> font-family:Verdana;font-size:11px;padding:10px 0;}
> #yiv8680019145 #yiv8680019145activity {
> background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
> #yiv8680019145 #yiv8680019145activity span {
> font-weight:700;}
> #yiv8680019145 #yiv8680019145activity span:first-child {
> text-transform:uppercase;}
> #yiv8680019145 #yiv8680019145activity span a {
> color:#5085b6;text-decoration:none;}
> #yiv8680019145 #yiv8680019145activity span span {
> color:#ff7900;}
> .yiv8680019145underline {
> text-decoration:underline;}
> #yiv8680019145 .yiv8680019145attach {
> clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
> 0;width:400px;}
> #yiv8680019145 .yiv8680019145attach div a {
> #yiv8680019145 .yiv8680019145attach img {
> border:none;padding-right:5px;}
> #yiv8680019145 .yiv8680019145attach label {
> display:block;margin-bottom:5px;}
> #yiv8680019145 .yiv8680019145attach label a {
> #yiv8680019145 blockquote {
> margin:0 0 0 4px;}
> #yiv8680019145 .yiv8680019145bold {
> font-family:Arial;font-size:13px;font-weight:700;}
> #yiv8680019145 .yiv8680019145bold a {
> #yiv8680019145 dd.yiv8680019145last p a {
> font-family:Verdana;font-weight:700;}
> #yiv8680019145 dd.yiv8680019145last p span {
> margin-right:10px;font-family:Verdana;font-weight:700;}
> span.yiv8680019145yshortcuts {
> margin-right:0;}
> #yiv8680019145 div.yiv8680019145attach-table div div a {
> #yiv8680019145 div.yiv8680019145attach-table {
> width:400px;}
> #yiv8680019145 div.yiv8680019145file-title a,
> #yiv8680019145
> div.yiv8680019145file-title a:active, #yiv8680019145
> div.yiv8680019145file-title a:hover, #yiv8680019145
> div.yiv8680019145file-title a:visited {
> #yiv8680019145 div.yiv8680019145photo-title a,
> #yiv8680019145 div.yiv8680019145photo-title a:active,
> #yiv8680019145 div.yiv8680019145photo-title a:hover,
> #yiv8680019145 div.yiv8680019145photo-title a:visited {
> #yiv8680019145 div#yiv8680019145ygrp-mlmsg
> #yiv8680019145ygrp-msg p a span.yiv8680019145yshortcuts
> font-family:Verdana;font-size:10px;font-weight:normal;}
> #yiv8680019145 .yiv8680019145green {
> color:#628c2a;}
> #yiv8680019145 .yiv8680019145MsoNormal {
> margin:0 0 0 0;}
> #yiv8680019145 o {
> font-size:0;}
> #yiv8680019145 #yiv8680019145photos div {
> float:left;width:72px;}
> #yiv8680019145 #yiv8680019145photos div div {
> border:1px solid
> #666666;height:62px;overflow:hidden;width:62px;}
> #yiv8680019145 #yiv8680019145photos div label {
> color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
> #yiv8680019145 #yiv8680019145reco-category {
> font-size:77%;}
> #yiv8680019145 #yiv8680019145reco-desc {
> font-size:77%;}
> #yiv8680019145 .yiv8680019145replbq {
> margin:4px;}
> #yiv8680019145 #yiv8680019145ygrp-actbar div a:first-child
> margin-right:2px;padding-right:5px;}
> #yiv8680019145 #yiv8680019145ygrp-mlmsg {
> font-size:13px;font-family:Arial, helvetica, clean,
> sans-serif;}
> #yiv8680019145 #yiv8680019145ygrp-mlmsg table {
> font-size:inherit;font:100%;}
> #yiv8680019145 #yiv8680019145ygrp-mlmsg select,
> #yiv8680019145 input, #yiv8680019145 textarea {
> font:99% Arial, Helvetica, clean, sans-serif;}
> #yiv8680019145 #yiv8680019145ygrp-mlmsg pre,
> #yiv8680019145
> code {
> font:115% monospace;}
> #yiv8680019145 #yiv8680019145ygrp-mlmsg * {
> line-height:1.22em;}
> #yiv8680019145 #yiv8680019145ygrp-mlmsg #yiv8680019145logo
> padding-bottom:10px;}
> #yiv8680019145 #yiv8680019145ygrp-msg p a {
> font-family:Verdana;}
> p#yiv8680019145attach-count span {
> color:#1E66AE;font-weight:700;}
> #yiv8680019145 #yiv8680019145ygrp-reco
> #yiv8680019145reco-head {
> color:#ff7900;font-weight:700;}
> #yiv8680019145 #yiv8680019145ygrp-reco {
> margin-bottom:20px;padding:0px;}
> #yiv8680019145ov
> li a {
> font-size:130%;text-decoration:none;}
> #yiv8680019145ov
> li {
> font-size:77%;list-style-type:square;padding:6px 0;}
> #yiv8680019145ov
> ul {
> margin:0;padding:0 0 0 8px;}
> #yiv8680019145 #yiv8680019145ygrp-text {
> font-family:Georgia;}
> #yiv8680019145 #yiv8680019145ygrp-text p {
> margin:0 0 1em 0;}
> #yiv8680019145 #yiv8680019145ygrp-text tt {
> font-size:120%;}
> #yiv8680019145 #yiv8680019145ygrp-vital ul li:last-child
> border-right:none !important;
> #yiv8680019145
> #yiv8856219972 #yiv8856219972 --
> #yiv8856219972ygrp-mkp {
> 0;padding:0 10px;}
> #yiv8856219972 #yiv8856219972ygrp-mkp hr {
> #yiv8856219972 #yiv8856219972ygrp-mkp #yiv8856219972hd {
> 0;}
> #yiv8856219972 #yiv8856219972ygrp-mkp #yiv8856219972ads {
> #yiv8856219972 #yiv8856219972ygrp-mkp .yiv8856219972ad {
> padding:0 0;}
> #yiv8856219972 #yiv8856219972ygrp-mkp .yiv8856219972ad p {
> margin:0;}
> #yiv8856219972 #yiv8856219972ygrp-mkp .yiv8856219972ad a {
> #yiv8856219972 #yiv8856219972ygrp-sponsor
> #yiv8856219972ygrp-lc {
> font-family:Arial;}
> #yiv8856219972ygrp-lc #yiv8856219972hd {
> margin:10px
> #yiv8856219972ygrp-lc .yiv8856219972ad {
> #yiv8856219972 #yiv8856219972actions {
> #yiv8856219972 #yiv8856219972activity {
> #yiv8856219972 #yiv8856219972activity span {
> font-weight:700;}
> #yiv8856219972 #yiv8856219972activity span:first-child {
> #yiv8856219972 #yiv8856219972activity span a {
> #yiv8856219972 #yiv8856219972activity span span {
> color:#ff7900;}
> .yiv8856219972underline {
> #yiv8856219972 .yiv8856219972attach {
> 0;width:400px;}
> #yiv8856219972 .yiv8856219972attach div a {
> #yiv8856219972 .yiv8856219972attach img {
> #yiv8856219972 .yiv8856219972attach label {
> #yiv8856219972 .yiv8856219972attach label a {
> #yiv8856219972 blockquote {
> margin:0 0 0 4px;}
> #yiv8856219972 .yiv8856219972bold {
> #yiv8856219972 .yiv8856219972bold a {
> #yiv8856219972 dd.yiv8856219972last p a {
> #yiv8856219972 dd.yiv8856219972last p span {
> span.yiv8856219972yshortcuts {
> margin-right:0;}
> #yiv8856219972 div.yiv8856219972attach-table div div a {
> #yiv8856219972 div.yiv8856219972attach-table {
> width:400px;}
> #yiv8856219972 div.yiv8856219972file-title a, #yiv8856219972
> div.yiv8856219972file-title a:active, #yiv8856219972
> div.yiv8856219972file-title a:hover, #yiv8856219972
> div.yiv8856219972file-title a:visited {
> #yiv8856219972 div.yiv8856219972photo-title a,
> #yiv8856219972 div.yiv8856219972photo-title a:active,
> #yiv8856219972 div.yiv8856219972photo-title a:hover,
> #yiv8856219972 div.yiv8856219972photo-title a:visited {
> #yiv8856219972 div#yiv8856219972ygrp-mlmsg
> #yiv8856219972ygrp-msg p a span.yiv8856219972yshortcuts {
> #yiv8856219972 .yiv8856219972green {
> color:#628c2a;}
> #yiv8856219972 .yiv8856219972MsoNormal {
> margin:0 0 0 0;}
> #yiv8856219972 o {
> font-size:0;}
> #yiv8856219972 #yiv8856219972photos div {
> #yiv8856219972 #yiv8856219972photos div div {
> border:1px solid
> #yiv8856219972 #yiv8856219972photos div label {
> #yiv8856219972 #yiv8856219972reco-category {
> font-size:77%;}
> #yiv8856219972 #yiv8856219972reco-desc {
> font-size:77%;}
> #yiv8856219972 .yiv8856219972replbq {
> margin:4px;}
> #yiv8856219972 #yiv8856219972ygrp-actbar div a:first-child {
> #yiv8856219972 #yiv8856219972ygrp-mlmsg {
> sans-serif;}
> #yiv8856219972 #yiv8856219972ygrp-mlmsg table {
> #yiv8856219972 #yiv8856219972ygrp-mlmsg select,
> #yiv8856219972 input, #yiv8856219972 textarea {
> #yiv8856219972 #yiv8856219972ygrp-mlmsg pre, #yiv8856219972
> code {
> #yiv8856219972 #yiv8856219972ygrp-mlmsg * {
> #yiv8856219972 #yiv8856219972ygrp-mlmsg #yiv8856219972logo {
> #yiv8856219972 #yiv8856219972ygrp-msg p a {
> p#yiv8856219972attach-count span {
> #yiv8856219972 #yiv8856219972ygrp-reco
> #yiv8856219972reco-head {
> #yiv8856219972 #yiv8856219972ygrp-reco {
> #yiv8856219972 #yiv8856219972ygrp-sponsor #yiv8856219972ov
> li a {
> li {
> ul {
> #yiv8856219972 #yiv8856219972ygrp-text {
> #yiv8856219972 #yiv8856219972ygrp-text p {
> margin:0 0 1em 0;}
> #yiv8856219972 #yiv8856219972ygrp-text tt {
> font-size:120%;}
> #yiv8856219972 #yiv8856219972ygrp-vital ul li:last-child {
> #yiv8856219972
Phil,
     I was not clear before.   When in the DAC calibration mode, if
you turn the cutoff, does one of the lit LED's move?  (Not VR6 and VR7)
If so, that would tend to imply that the front panel reading of the cutoff
pot is OK.   It's true that the corrosion can travel up that black wire.
I replaced the wire on mine with another thick one.  16 gauge, I think.
    Also, if you are able to reload patches from cassette (or computer
audio port) and the EG and filter are still not working when you change
patches, that will indicate that it's from the CPU to the outputs, and
not the front panel reading.
      Bob
 From: "Johannes Hausensteiner johannes@eclipso.at [PolySix]" <PolySix@yahoogroups.com>
Sent: Thursday, May 29, 2014 8:05 AM
black wire as well.
Good luck!
Johannes
> Hi,
>     Bob
> counting
> OK
> OK
> OK
> to IC22 ?
> to pin 7...
> IC10-1decay
> support.
> Phil
> These should be
> connected:
> is signal "P22"
> this is signal
> "P21"
> IC19-6 and
> IC23-10
> won't work
> correctly.
> IC19.
>     Bob
> From: "Phil65
> To:
> 28, 2014 7:55 PM
> Hi Bob,
> to 7 then 6
> IC22 ??
> panel
> voltage as you
> at normal setting
> to 3.346V
> Phil
> leakage
> Hi Phil,
> that
> impliesthat
> thing
> to try -
> in
> that
> you were supposedto
> change.
> now.
> mostlyIC18
> have
> of
> IC27, and between
> pin
> and
> control,such
> you
> do it (in manual
> mode).
> the
> careful
> when probing with
> the
> an
> and
> corresponding
> patches.
> Bob
> From:
> To:
> 28, 2014 6:05 PM
> to
> still
> on.
> summary:
> leds
> 1+8 on
> 6V
> don't
> Phil
> battery
> leakage
> See if
> patchesin
> analog
> circuitsis
> controls.But
> the
> output
> OK.Did
> would
> be helpfulto
> try
> to
> get the
> two
> LEDs to light up.
> Bob
> From:
> To:
> 2014 6:02 PM
> and VCF not
> Bonjour !I am
> French
> have
> battery
> leakage problem !
> So I did
> of
> leds on at start
> not
> working...Check
> Unfortunately sound
> is not OK.
> Tune seems
> OK,
> 5V
> pots
> which are not
> active! I think at
> procedure.
> Is
> diode..)
> should be changed.
> Thanks in
> Phil
> 0;padding:0 10px;}
> 0;}
> padding:0 0;}
> margin:0;}
> font-family:Arial;}
> margin:10px
> font-weight:700;}
> color:#ff7900;}
> 0;width:400px;}
> margin:0 0 0 4px;}
> margin-right:0;}
> width:400px;}
> #yiv8680019145
> color:#628c2a;}
> margin:0 0 0 0;}
> #yiv8680019145 o {
> font-size:0;}
> border:1px solid
> font-size:77%;}
> font-size:77%;}
> margin:4px;}
> sans-serif;}
> #yiv8680019145
> code {
> #yiv8680019145ov
> li a {
> #yiv8680019145ov
> li {
> #yiv8680019145ov
> ul {
> margin:0 0 1em 0;}
> font-size:120%;}
> #yiv8680019145
> 0;padding:0 10px;}
> 0;}
> padding:0 0;}
> margin:0;}
> font-family:Arial;}
> margin:10px
> font-weight:700;}
> color:#ff7900;}
> 0;width:400px;}
> margin:0 0 0 4px;}
> margin-right:0;}
> width:400px;}
> color:#628c2a;}
> margin:0 0 0 0;}
> #yiv8856219972 o {
> font-size:0;}
> border:1px solid
> font-size:77%;}
> font-size:77%;}
> margin:4px;}
> sans-serif;}
> code {
> li a {
> li {
> ul {
> margin:0 0 1em 0;}
> font-size:120%;}
> #yiv8856219972
Sorry for the multiple emails.  In DAC calibration mode,
you should be able to turn the cutoff and see the lit LED move from 5-8
as you turn it.   Likewise, you should be able to move the speed/intensity pot
and see the other lit LED move from 1-4.
Bob
OK
OK
OK
Phil
These should be
connected:
is signal "P22"
this is signal
"P21"
IC19-6 and
IC23-10
won't work
correctly.
IC19.
   Bob
To:
28, 2014 7:55 PM
Hi Bob,
to 7 then 6
IC22 ??
panel
voltage as you
at normal setting
to 3.346V
Phil
leakage
Hi Phil,
that
impliesthat
thing
to try -
in
that
you were supposedto
change.
now.
mostlyIC18
have
of
IC27, and between
pin
and
control,such
you
do it (in manual
mode).
careful
when probing with
an
and
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
to
still
on.
summary:
leds
1+8 on
6V
don't
Phil
battery
leakage
See if
patchesin
analog
circuitsis
controls.But
output
OK.Did
would
be helpfulto
try
to
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
have
battery
leakage problem !
So I did
of
leds on at start
not
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
5V
pots
which are not
active! I think at
procedure.
Is
diode..)
should be changed.
Thanks in
Phil
2014-05-30 by Phil65
Thanks Bob and Johannes
I am off for the week end with family, but managed to take only the KLM 367A board and VM (shh!, don't tell my wife she doesn't know....)
I have checked all connections on IC23 and are OK. I will update on voltage on Sunday night..
Also I have managed to get a USB oscillo (data acquisition board) with dedicated software (tracerDAQ). Precisely:
http://www.mccdaq.com/usb-data-acquisition/USB-1208FS.aspx
much better than nothing, so I should be equipped for the next stage... (still in learning phase anyway !)
Phil
 Date: Jeudi 29 mai 2014, 14h49
 Sorry for
 mode,you
 from 5-8as
 speed/intensity potand
 Bob
  To:
 2014 4:47 AM
 =>OK
 7 then 6
 OK
 OK
 OK
 panel
 voltage as you
 at normal setting
 to 3.346V
 Phil
 leakage
  These should be
  connected:
  is signal "P22"
  this is signal
   "P21"
  IC19-6 and
  IC23-10
 see the
  won't work
  correctly.
  IC19.
     Bob
   To:
  28, 2014 7:55 PM
        Hi Bob,
 from
 8
  to 7 then 6
 together.
 or
  IC22 ??
  panel
 change
  voltage as you
 controls
  at normal setting
 and
 3.240V
  to 3.346V
  Phil
 battery
  leakage
         Hi Phil,
  that
   impliesthat
  thing
   to try -
   in
  that
   you were supposedto
   change.
   now.
   mostlyIC18
  have
 1
  of
   IC27, and between
   pin
  and
   control,such
  you
    do it (in manual
   mode).
  careful
   when probing with
 in
  an
  and
   corresponding
   patches.
   Bob
    To:
   28, 2014 6:05 PM
 I
  to
  still
   on.
 quick
   summary:
  leds
   1+8 on
 within
  6V
  don't
   Phil
  battery
   leakage
    See if
    patchesin
   analog
    circuitsis
    controls.But
 then
    output
    OK.Did
   would
    be helpfulto
  try
   to
    get the
    two
    LEDs to light up.
    Bob
     To:
    2014 6:02 PM
    and VCF not
          Bonjour !I am
    French
 I
   have
   battery
    leakage problem !
    So I did
  of
   leds on at start
  not
    working...Check
    Unfortunately sound
    is not OK.
    Tune seems
    OK,
 (15V,
   5V
   pots
    which are not
    active! I think at
  procedure.
   Is
   diode..)
    should be changed.
    Thanks in
     Phil
2014-06-03 by Bob Grieb
Hi Phil,
   If you plan to use that USB DAC as an oscilloscope, I don't think
it will work very well.   It's more of a data sampler, than a scope, it seems.
It doesn't sample fast enough to show the waveforms in a processor-based
synth.   You need something with at least 10-20 MHz bandwidth, and really
at least 60 MHz would be much better.
     Bob
Sent: Friday, May 30, 2014 6:54 AM
Phil
Sorry for
mode,you
from 5-8as
Bob
To:
2014 4:47 AM
=>OK
7 then 6
OK
OK
OK
panel
voltage as you
at normal setting
to 3.346V
Phil
leakage
These should be
connected:
is signal "P22"
this is signal
"P21"
IC19-6 and
IC23-10
see the
won't work
correctly.
IC19.
   Bob
To:
28, 2014 7:55 PM
Hi Bob,
from
8
to 7 then 6
together.
or
IC22 ??
panel
change
voltage as you
controls
at normal setting
and
3.240V
to 3.346V
Phil
battery
leakage
Hi Phil,
that
impliesthat
thing
to try -
in
that
you were supposedto
change.
now.
mostlyIC18
have
1
of
IC27, and between
pin
and
control,such
you
do it (in manual
mode).
careful
when probing with
in
an
and
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
I
to
still
on.
quick
summary:
leds
1+8 on
within
6V
don't
Phil
battery
leakage
See if
patchesin
analog
circuitsis
controls.But
then
output
OK.Did
would
be helpfulto
try
to
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
I
have
battery
leakage problem !
So I did
of
leds on at start
not
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
(15V,
5V
pots
which are not
active! I think at
procedure.
Is
diode..)
should be changed.
Thanks in
Phil
SV: [PolySix] EG and VCF not working after battery leakage
2014-06-03 by Hans
Hi
From my own experience a scope based around a USB sound card they’re only useful up to approx. 5200Hz.
There are ways around this by implementing a simple sample and hold circuit to the input. But this circuit has to be synced with the ADC clock which complicate things. I’ve not investigated this further, but my guess this is how many low priced digital scopes is manufactured.
-hans
Fra: PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com]
Sendt: 3. juni 2014 13:48
Til: PolySix@yahoogroups.com
Emne: Re: [PolySix] EG and VCF not working after battery leakage
Hi Phil,
     Bob
  _____
From: "Phil65  <mailto:phil0065@yahoo.fr> phil0065@yahoo.fr [PolySix]" < <mailto:PolySix@yahoogroups.com> PolySix@yahoogroups.com>
To:  <mailto:PolySix@yahoogroups.com> PolySix@yahoogroups.com
 <http://www.mccdaq.com/usb-data-acquisition/USB-1208FS.aspx> http://www.mccdaq.com/usb-data-acquisition/USB-1208FS.aspx
Phil
En date de : Jeu 29.5.14, Bob Grieb  <mailto:bobgrieb@yahoo.com> bobgrieb@yahoo.com [PolySix] < <mailto:PolySix@yahoogroups.com> PolySix@yahoogroups.com> a écrit :
À: " <mailto:PolySix@yahoogroups.com> PolySix@yahoogroups.com" < <mailto:PolySix@yahoogroups.com> PolySix@yahoogroups.com>
Sorry for
mode,you
from 5-8as
Bob
To:
2014 4:47 AM
=>OK
7 then 6
OK
OK
OK
panel
voltage as you
at normal setting
to 3.346V
Phil
leakage
These should be
connected:
is signal "P22"
this is signal
"P21"
IC19-6 and
IC23-10
see the
won't work
correctly.
IC19.
   Bob
To:
28, 2014 7:55 PM
Hi Bob,
from
8
to 7 then 6
together.
or
IC22 ??
panel
change
voltage as you
controls
at normal setting
and
3.240V
to 3.346V
Phil
battery
leakage
Hi Phil,
that
impliesthat
thing
to try -
in
that
you were supposedto
change.
now.
mostlyIC18
have
1
of
IC27, and between
pin
and
control,such
you
do it (in manual
mode).
careful
when probing with
in
an
and
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
I
to
still
on.
quick
summary:
leds
1+8 on
within
6V
don't
Phil
En date de : Mer 28.5.14, Bob Grieb  <mailto:bobgrieb@yahoo.com> bobgrieb@yahoo.com
battery
leakage
See if
patchesin
analog
circuitsis
controls.But
then
output
OK.Did
would
be helpfulto
try
to
get the
two
LEDs to light up.
Bob
" <mailto:phil0065@yahoo.fr%20[PolySix]> phil0065@yahoo.fr [PolySix]"
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
I
have
battery
leakage problem !
So I did
of
leds on at start
not
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
(15V,
5V
pots
which are not
active! I think at
procedure.
Is
diode..)
should be changed.
Thanks in
Phil
Re: SV: [PolySix] EG and VCF not working after battery leakage
2014-06-03 by Phil65
Hi
My KLM 367 repairing may not be good enough as I realize on Sunday that after 5-10 minutes of warming I have additional leds along with A+1 (led 3 then C+3 are also flashing). Disappointing..
I spend many time rechecking the board without success. After some cool down, when I switch ON, only leds A1 are on but after some timeof warming  C + 3 are coming back plus a noisy sound.
Please find also an update on the voltage:
Does IC10 have -15 on pin 4?   => -15V
Does IC18 have +5 on pin 16  and -5 on pin 7? => Yes  +5V and -5V
I have also recheck the DAC calib.
Cut off set to 10 => led 1+8
Cut Off from 0-8 => led 1+5
 Speed intensity 0-6 => led 1+8
Speed intensity 7-10 => led 4+8
Today unfortunately I do not have access to a proper oscillo. I will check what I can do with this simple USB oscillo, but I did try already and manage to get for example the correct shape for the figure 2 in the adjustment procedure (20 msec). I will send a screen copy in a next mail
Thanks
Phil
Le Mardi 3 juin 2014 14h03, "'Hans' hr.public@lonningdal.net [PolySix]" <PolySix@yahoogroups.com> a écrit :
Hi
-hans
Fra:PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com]
Hi Phil,
     Bob
From:"Phil65 phil0065@yahoo.fr[PolySix]" <PolySix@yahoogroups.com>
Phil
En date de : Jeu 29.5.14, Bob Grieb bobgrieb@yahoo.com[PolySix] <PolySix@yahoogroups.com> a écrit :
Sorry for
mode,you
from 5-8as
Bob
To:
2014 4:47 AM
=>OK
7 then 6
OK
OK
OK
panel
voltage as you
at normal setting
to 3.346V
Phil
leakage
These should be
connected:
is signal "P22"
this is signal
"P21"
IC19-6 and
IC23-10
see the
won't work
correctly.
IC19.
   Bob
To:
28, 2014 7:55 PM
Hi Bob,
from
8
to 7 then 6
together.
or
IC22 ??
panel
change
voltage as you
controls
at normal setting
and
3.240V
to 3.346V
Phil
battery
leakage
Hi Phil,
that
impliesthat
thing
to try -
in
that
you were supposedto
change.
now.
mostlyIC18
have
1
of
IC27, and between
pin
and
control,such
you
do it (in manual
mode).
careful
when probing with
in
an
and
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
I
to
still
on.
quick
summary:
leds
1+8 on
within
6V
don't
Phil
battery
leakage
See if
patchesin
analog
circuitsis
controls.But
then
output
OK.Did
would
be helpfulto
try
to
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
I
have
battery
leakage problem !
So I did
of
leds on at start
not
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
(15V,
5V
pots
which are not
active! I think at
procedure.
Is
diode..)
should be changed.
Thanks in
Phil
2014-06-04 by Bob Grieb
Phil,
    C and 3 LED's are both fed from data bit D2.   Please check resistance
of this connection between KLM-367  and KLM-371 board.   Ideally, you should
check the resistance from the source IC on the KLM-367 (IC31) to the chip on
the KLM-371 where it's used to control the LED (IC2 and IC4).   Better than
connector to connector, in case there is a trace problem on one of the pc bds.
    If you can get your hands on a decent oscilloscope, I can send you
captured waveforms for comparison.   It seems that you have several
different issues to track down.
    Bob
To: "PolySix@yahoogroups.com" <PolySix@yahoogroups.com>
Sent: Tuesday, June 3, 2014 5:16 PM
Subject: Re: SV: [PolySix] EG and VCF not working after battery leakage
Hi
Thanks
Phil
Hi
-hans
Hi Phil,
     Bob
Phil
Sorry for
mode,you
from 5-8as
Bob
To:
2014 4:47 AM
information
P21 IC18-10
=>OK
7 then 6
OK
OK
OK
panel
voltage as you
at normal setting
to 3.346V
Phil
leakage
These should be
connected:
is signal "P22"
this is signal
"P21"
IC19-6 and
IC23-10
see the
If IC18
 and IC19 are not
won't work
correctly.
IC19.
   Bob
To:
28, 2014 7:55 PM
Hi Bob,
from
8
to 7 then 6
together.
or
IC22 ??
panel
 7
change
voltage as you
controls
at normal setting
and
3.240V
to 3.346V
Thanks for
Phil
battery
leakage
Hi Phil,
that
impliesthat
thing
to try -
in
that
you were supposedto
change.
now.
mostlyIC18
have
1
of
IC27, and between
pin
and
control,such
you
do it (in manual
mode).
careful
when probing with
in
an
and
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
Subject:
 Re: [PolySix]
I
have no
to
still
on.
quick
summary:
*dummy 56
 ohm => all leds on
leds
1+8 on
within
6V
don't
Phil
battery
leakage
See if
patchesin
analog
circuitsis
controls.But
then
output
OK.Did
would
be helpfulto
try
to
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
 until
I
have
battery
leakage problem !
So I did
of
leds on at start
not
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
(15V,
5V
pots
which are not
active! I think at
procedure.
Is
diode..)
should be changed.
Thanks in
Phil
Phil,
   You said you have 13.56 volts on IC10-1.   This is very strange.
Please check to see if pins 1 and 2 of this chip are connected as they
should be.   Do you see the same voltage on pin 2?    Also, measure the
voltage on pin 3.  With the output connected to the inverting input,
this op amp is a voltage follower.   The output should match the input
(at pin 3)  Pin 3 should never go beyond +/- 5 volts, since it is fed
from IC18 which has those as its power rails.   So something odd is happening
here.  Or maybe that op amp is just toast.  It seems like the output is
just sitting at its positive output limit.
    Bob
Hi
Thanks
Phil
Hi
-hans
Hi Phil,
     Bob
Phil
Sorry for
mode,you
from 5-8as
Bob
To:
2014 4:47 AM
information
P21 IC18-10
=>OK
7 then 6
OK
OK
OK
panel
voltage as you
at normal setting
to 3.346V
Phil
leakage
These should be
connected:
is signal "P22"
this is signal
"P21"
IC19-6 and
IC23-10
see the
If IC18
 and IC19 are not
won't work
correctly.
IC19.
   Bob
To:
28, 2014 7:55 PM
Hi Bob,
from
8
to 7 then 6
together.
or
IC22 ??
panel
 7
change
voltage as you
controls
at normal setting
and
3.240V
to 3.346V
Thanks for
Phil
battery
leakage
Hi Phil,
that
impliesthat
thing
to try -
in
that
you were supposedto
change.
now.
mostlyIC18
have
1
of
IC27, and between
pin
and
control,such
you
do it (in manual
mode).
careful
when probing with
in
an
and
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
Subject:
 Re: [PolySix]
I
have no
to
still
on.
quick
summary:
*dummy 56
 ohm => all leds on
leds
1+8 on
within
6V
don't
Phil
battery
leakage
See if
patchesin
analog
circuitsis
controls.But
then
output
OK.Did
would
be helpfulto
try
to
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
 until
I
have
battery
leakage problem !
So I did
of
leds on at start
not
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
(15V,
5V
pots
which are not
active! I think at
procedure.
Is
diode..)
should be changed.
Thanks in
Phil
2014-06-04 by Phil65
Bonjour les amis Polysix,
1) Concerning the problem with led C+3, I have rechecked continuity between IC without success (cold and warm check). Precisely I have checked between IC31-8 and all the follwoing:
 Board 367 (Ic33-10 ic26-4 ic28-14 cn6-5 cn10-2)
 Board 371 (ic2-6 ic4-6)
 Board 370 (sw2-0)
All continuity seem OK.
Anyway problem with C3 is not clear. It could appear after 30s warm up  or never (If I do nothing ?), unless I switch apparently effect mode buttom or led 3. It disappears if I select "manual" ... Then selecting "1" again make C3 disappear until I select "3" and then "C" light up directly ...?
2) For the "high" voltage please find an update of the reading (done at normal setting as shown in service manual, figure1 and manual switch on):
IC10-1   13,46
IC10-2   13,46
IC10-3   NOT STABLE  ~0,2?
IC10-4   -14,99
IC10-5   3,173
IC10-6   3,206
IC10-7   3,206
IC10-8   14,94
IC11 is too high too?
IC11-1   14,2
IC11-2   14,2
IC11-3   NOT STABLE ~0,38
IC11-4   -14,99
IC11-5   3,174
IC11-6   ~3,2
IC11-7   ~3,2
IC11-8   14,94
SO I have checked the following (in case...):
IC16-1   3,18
IC7-1     3,212
IC7-7     3,16
IC9-1     3,18
IC12-7   2,2
IC12-1   2,21
IC13-1   2,21
IC13-7   2,22
IC14-7   2,22
3) For the usb -scope I have try to join as an example a screen copy of the signal found at TP5 equivalent to figure 2
"observe connector CN3-5 on oscilloscope"
Thanks again for your support and comments
Phil
Le Mercredi 4 juin 2014 4h32, "Bob Grieb bobgrieb@yahoo.com [PolySix]" <PolySix@yahoogroups.com> a écrit :
 Phil,
    Bob
Hi
Thanks
Phil
Hi
-hans
Hi Phil,
     Bob
Phil
Date: Jeudi 29 mai
 2014, 14h49
Sorry for
mode,you
from 5-8as
Bob
To:
2014 4:47 AM
your point with the
information
P21 IC18-10
=>OK
 VR6 CCW => from
7 then 6
OK
OK
OK
panel
voltage as you
at normal setting
to 3.346V
Phil
leakage
These should be
connected:
is signal "P22"
this is signal
"P21"
this is signal
 "P20"
IC19-6 and
IC23-10
see the
If IC18
 and IC19 are not
won't work
correctly.
IC19.
   Bob
To:
28, 2014 7:55 PM
Hi Bob,
from
8
to 7 then 6
together.
or
IC22 ??
panel
 7
change
voltage as you
controls
at normal setting
and
3.240V
to 3.346V
Thanks for
Phil
battery
leakage
Hi Phil,
that
impliesthat
 working.   Another
thing
to try -
in
that
you were supposedto
change.
now.
mostlyIC18
(4051).   I would
have
1
of
IC27, and between
pin
and
control,such
you
do it (in manual
mode).
careful
when probing with
in
an
and
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
Subject:
 Re: [PolySix]
I
have no
to
still
on.
quick
summary:
*dummy 56
 ohm => all leds on
leds
1+8 on
within
6V
don't
Phil
battery
leakage
See if
patchesin
analog
circuitsis
controls.But
then
output
OK.Did
would
be helpfulto
try
to
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
 until
I
have
my first
battery
leakage problem !
So I did
of
leds on at start
not
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
(15V,
5V
pots
which are not
active! I think at
procedure.
Is
diode..)
should be changed.
Thanks in
Phil
I am starting to think that trying to troubleshoot over email without a scope is
not such a good idea.   If having LED 3 on affects "C" LED, this implies
an issue with the enables to IC4,5 and IC2,3.   So now I would check resistance
to IC3-6 and 7 on KLM-371 to same signals on KLM367.  P26 and P27.
IC10 and IC11 pin 1 should be the same voltage as pin 3 on each chip.
If not, then either the op amp is bad, or something is shorting the output
to this voltage.  Maybe unplug CN05 on KLM-367 which is the only
place these signals go.  If the voltages are still so high, then replace the
op amps.
The IC18 circuit is a sample and hold one.   The DAC connects to each of
the caps in turn, through the mux (IC18) to refresh the voltage on the cap.
But the cap voltage should be limited to +/- 5V, and you should have the
same voltage after the op amp.
   Bob
Sent: Wednesday, June 4, 2014 6:14 PM
 Board 370 (sw2-0)
IC10-1   13,46
IC10-2   13,46
IC10-4   -14,99
IC10-5   3,173
IC10-6   3,206
IC10-7   3,206
IC10-8   14,94
IC11-1   14,2
IC11-2   14,2
IC11-4   -14,99
IC11-5   3,174
IC11-6   ~3,2
IC11-7   ~3,2
IC11-8   14,94
IC16-1   3,18
IC7-1     3,212
IC7-7     3,16
IC9-1     3,18
IC12-7   2,2
IC12-1   2,21
IC13-1   2,21
IC13-7   2,22
IC14-7   2,22
Phil
 Phil,
    Bob
Hi
Thanks
Phil
Hi
-hans
Hi Phil,
     Bob
Phil
Date: Jeudi 29 mai
2014, 14h49
Sorry for
mode,you
from 5-8as
Bob
To:
2014 4:47 AM
your point with the
information
P21 IC18-10
=>OK
VR6 CCW => from
7 then 6
OK
OK
OK
panel
voltage as you
at normal setting
to 3.346V
Phil
leakage
These should be
connected:
is signal "P22"
this is signal
"P21"
this is signal
"P20"
IC19-6 and
IC23-10
see the
If IC18
and IC19 are not
won't work
correctly.
IC19.
   Bob
To:
28, 2014 7:55 PM
Hi Bob,
from
8
to 7 then 6
together.
or
IC22 ??
panel
7
change
voltage as you
controls
at normal setting
and
3.240V
to 3.346V
Thanks for
Phil
battery
leakage
Hi Phil,
that
impliesthat
working.   Another
thing
to try -
in
that
you were supposedto
change.
now.
mostlyIC18
(4051).   I would
have
1
of
IC27, and between
pin
and
control,such
you
do it (in manual
mode).
careful
when probing with
in
an
and
corresponding
patches.
Bob
To:
28, 2014 6:05 PM
Subject:
Re: [PolySix]
I
have no
to
still
on.
quick
summary:
*dummy 56
ohm => all leds on
leds
1+8 on
within
6V
don't
Phil
battery
leakage
See if
patchesin
analog
circuitsis
controls.But
then
output
OK.Did
would
be helpfulto
try
to
get the
two
LEDs to light up.
Bob
To:
2014 6:02 PM
and VCF not
Bonjour !I am
French
until
I
have
my first
battery
leakage problem !
So I did
of
leds on at start
not
working...Check
Unfortunately sound
is not OK.
Tune seems
OK,
(15V,
5V
pots
which are not
active! I think at
procedure.
Is
diode..)
should be changed.
Thanks in
Phil
2014-06-24 by Phil65
It has been some time since my last email and I would like to update on my P6 issue with no sound except in EG square position.
Eventually Bob were right, IC10 and IC11 were dead. Changing both of them solved by initial problems (even bank c and 3 issue have been cleared).
Now my remaining problem is a noise problem when playing the polysix (not always but sometimes). I believe this can be described more as a scratchy sound problem, like a faulty pot, cap, transistor or line.
Is there a way to directly spot the origin of problem? I have started the calibration procedure and completed the KLM367 checking without problem?
Thanks for your advice!
Merci
Phil
De : "Bob Grieb bobgrieb@yahoo.com [PolySix]"
À : "PolySix@yahoogroups.com"
Envoyé le : Jeudi 5 juin 2014 0h53
Objet : Re: SV: [PolySix] EG and VCF not working after battery leakage
op amps.
Bob
Board 370 (sw2-0)
IC10-1 13,46
IC10-2 13,46
IC10-4 -14,99
IC10-5 3,173
IC10-6 3,206
IC10-7 3,206
IC10-8 14,94
IC11-1 14,2
IC11-2 14,2
IC11-4 -14,99
IC11-5 3,174
IC11-6 ~3,2
IC11-7 ~3,2
IC11-8 14,94
IC16-1 3,18
IC7-1 3,212
IC7-7 3,16
IC9-1 ;3,18
IC12-7 2,2
IC12-1 2,21
IC13-1 2,21
IC13-7 2,22
IC14-7 2,22
Phil
Le Mercredi 4 juin 2014 4h32, "Bob Grieb bobgrieb@yahoo.com [PolySix]" a écrit :
Phil,
should be. Do you see the same voltage on pin 2? ; Also, measure the
Bob
Hi
Does IC10 have -15 on pin 4? ; => -15V
Thanks
Phil
Le Mardi 3 juin 2014 14h03, "'Hans' hr.public@lonningdal.net [PolySix]" a écrit :
