I've found a broken trace near to IC33 I didn't notice before as it was almost imperceptible. Now the effects are working!. Thank you for your help!
El vie, 7/8/15, Terje Winther terje.winther@wintherstormer.no [PolySix] <PolySix@yahoogroups.com> escribió:
Asunto: Re: [PolySix] Effects not working due to problem in battery board
Para: "moogchild@yahoo.es [PolySix]" <PolySix@yahoogroups.com>
Fecha: viernes, 7 de agosto, 2015 09:10
IC34 and IC35. It could be that the 4042 chips are
broken (very common), or that connections to or from the ICs
are broken.
Den 6. aug.. 2015 kl. 21.43 skrev moogchild@yahoo.es
[PolySix]:
I've just repaired a KLM-367
board with battery leakage. Everything works fine except
that the effects selector does nothing. It is definitively a
problem of this KLM-367 board, as I put
another working one board and the effects selector was doing
fine. So I suppose it's a problem of the mux/demux
circuit. Does anybody knows which IC in that board has to do
with the effects mode knob?.
Thank
you!
Regards.
Manuel
Terje
Wintherterje.winther@wintherstormer.nohttp://wintherstormer.no/
#yiv4073913858 #yiv4073913858 --
