tuning instability?
2016-06-28 by Malte Rogacki
Hello everyone; I'm currently trying to fix two Polysix (including fittin a new processor board) and both show similar behaviour. I am not sure if this is actually normal (since the oscillators are true VCO's and not DCO's) or if there is something wrong with those units. All calibrations went very well and the unit is good in tune. However it displays a very slight irregular "trembling" or "wavering" in the tuning - sort of like a very small random modulation. It's a bit as if the pitch jumps a little bit to the side and is immediately pulled back to the regular pitch. When playing a chord or using the modulation effect it becomes practically inaudible; the pitch deviation is perhaps 1 cent (when it happens). First I thought that this could come from some instability in the power supply. However when making the filter self-oscillate the generated tone is completely stable without the "trembling" phenomenom hence I don't think this is a power supply issue. Since it's been some time since I last worked on a Polysix: Is that perhaps even normal and in the nature of the VCO's? Or is this a known problem? Thanks, Malte
