Parts replacement: PSU Caps + Volume Pot
2017-05-12 by josh.nursing@gmail.com
What would be good modern replacement parts for the PSU PCB Filter caps?
I rarely see those Caps with leads on each end so I am wondering how to shoe-horn more normal caps in there but then have to worry about clearance inside (if indeed one has to worry about this).
I seem to have a very scratchy Volume Pot too, so is there a good modern replacement I could use?
Re: [PolySix] Parts replacement: PSU Caps + Volume Pot
2017-05-12 by Bob Grieb
You can still buy axial lead capacitors.    They are more expensive
but still available.
Check Mouser and DigiKey
On Fri, 5/12/17, josh.nursing@gmail.com [PolySix] <PolySix@yahoogroups.com> wrote:
 Subject: [PolySix] Parts replacement: PSU Caps + Volume Pot
 To: PolySix@yahoogroups.com
 Date: Friday, May 12, 2017, 1:07 PM
 parts for the PSU PCB Filter caps? I
 #yiv0009717397 #yiv0009717397 --
Re: Parts replacement: PSU Caps + Volume Pot
Hey Bob, long time no hear, how are things?
OK good to know, I will add some to my next order. Digikey ships fast internally to Canada. Definitely more expensive than elsewhere though.
Thanks a lot.
