DDD-1 Drum Machine Sync
2005-04-18 by Jason Weaver
Hello all. Just wondering if anyone has used Korg's DDD-1 drum machine.
I just bid on one on ebay and I'm hoping the sync output on the DDD-1
will work with my P6's arp trigger input. Anybody try this yet?
-Jasonmd2020
Re: [PolySix] DDD-1 Drum Machine Sync
2005-04-19 by Chromatest J. Pantsmaker
I think I have a DDD-1, but not really sure.  It *SHOULD* work.  what might also work is to use the audio output and program using only snare drums or something else with a fast attack/decay....  You might also have to build a special cable for the DDD-1 sync output, depending on if the sync is "High to Ground" or "Ground to High".  The special cable just reverses the wiring... tip to sleeve instead of tip to tip.
To: PolySix@yahoogroups.com
Subject: [PolySix] DDD-1 Drum Machine Sync
Date: Mon, 18 Apr 2005 08:55:58 -0000
> -Jasonmd2020
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
.sig
-Chromatest J. Pantsmaker
http://www.chromatest.net
