Vintage Synth Repair
Index last updated: 2026-04-28 23:41 UTC
Casio CZ1 keyboard issue, please help me
2016-07-02 by roberflas@...
Hello,
I have a CZ1 , that was my first synthesizer , but one day I turn it on and if you touch any key , it sounds a very high note and hold on , if you play more keys it adds up but with high notes. If you play MIDI , all is correct, all notes , program change , etc.
Anyone have any idea what can happen ?.
Thank you
Re: [vintagesynthrepair] Casio CZ1 keyboard issue, please help me
2016-07-04 by Daniel Forró
Your description is not quite exact... I think it's you who should
have an idea what happened :-) There's always some reason for such
behavior.
One of them, for example, can be that if it was not in use for longer
time period, maybe contacts are dirty or oxidized. I would reseat and
clean all connectors as a first simple step. Focus on keyboard cables
and connectors, I suppose there are some.
Sometimes after the long sleep it's good to leave the machine on for
longer time - three days and nights, but keep eye on it and switch off
again when you can't stay near it.
Daniel Forro
On Jul 3, 2016, at 1:01 AM, roberflas@... [vintagesynthrepair]
wrote:
> Hello,
> Thank you
2016-07-04 by Terje Winther
If it is working all right through MIDI, but not with the keyboard, it
probably means that the internal keyboard processor is out of order.
If I remember correctly there is a dedicated IC controlling the
keyboard.
Den 2. juli. 2016 kl. 18.01 skrev roberflas@...
[vintagesynthrepair]:
> Hello,
> Thank you
Terje Winther
terje.winther@wintherstormer.no
http://wintherstormer.no/
Re: Casio CZ1 keyboard issue, please help me
2016-07-05 by roberflas@...
Hi, thanks to all, for your reply,
Ok, the battery is for replace in this moment, but i do a reset at power on time, to obtain the factory settings.
On the other hand, I do all checks for contacts of the keys and continuity for traces in printed board.
Anyone tell me that this issue may be caused for one or some diodes of the key matrix.
I will do a test of all diodes, there is 122, two for each key.
regrads
RE: [vintagesynthrepair] Casio CZ1 keyboard issue, please help me
2016-07-08 by Brian Fuller
Are you sure it’s not the internal battery(possibly a 2032 or other standard computer battery)???? I know when my CZ-101 did this the backup memory batteries were dead. The on board sounds in the CZ-101 were backed up by C batteries. That would be the first thing I would check. If you can’t change it yourself you’ll have to find a local tech to do it.
Brian In Ohio
From: vintagesynthrepair@yahoogroups.com [mailto:vintagesynthrepair@yahoogroups.com]
Sent: Monday, July 04, 2016 8:20 AM
To: vintagesynthrepair@yahoogroups.com
Subject: Re: [vintagesynthrepair] Casio CZ1 keyboard issue, please help me
Your description is not quite exact... I think it's you who should have an idea what happened :-) There's always some reason for such behavior.
One of them, for example, can be that if it was not in use for longer time period, maybe contacts are dirty or oxidized. I would reseat and clean all connectors as a first simple step. Focus on keyboard cables and connectors, I suppose there are some.
Sometimes after the long sleep it's good to leave the machine on for longer time - three days and nights, but keep eye on it and switch off again when you can't stay near it.
Daniel Forro
On Jul 3, 2016, at 1:01 AM, roberflas@... [vintagesynthrepair] wrote:
Hello,
Thank you
2016-07-16 by roberflas@...
Hi all, i just change the battery with a new one and The keyboard are wrong, one notes sound ok but the scale is wrong and another keys sound too hight in tone and sustained until poder off, in the middle of keyboard all notes are sustained and too hight the key velocity touch is ok for all keys.
Any idea about what happen.
Thank you
Re: [vintagesynthrepair] Re: Casio CZ1 keyboard issue, please help me
2016-07-21 by Daniel Forró
Does it occur with all sounds, even presets? Or only with Internal RAM sounds?
Have you performed System Initialization as described on the page 64 of Owner's Manual?
You can also try to send SysEx data to the instrument.
Daniel Forro
Thank you
RE: [vintagesynthrepair] Re: Casio CZ1 keyboard issue, please help me
2016-07-21 by Brian Fuller
Possibly a dead internal memory battery? Likely on the main board inside. I’m not sure if it used the typical button cell ex. 2032 or not in the CZ-1…
Good Luck,
Brian In Ohio
Sent: Saturday, July 16, 2016 8:54 AM
Subject: [vintagesynthrepair] Re: Casio CZ1 keyboard issue, please help me
Thank you
2016-07-25 by Brian Fuller
I can’t remember if there’s a system reset on the CZ-1 or not it’s been to long ago…if you have the manual check that if not look around the web…
Sent: Thursday, July 21, 2016 6:54 PM
Subject: RE: [vintagesynthrepair] Re: Casio CZ1 keyboard issue, please help me
Good Luck,
Brian In Ohio
Thank you
2016-07-27 by Daniel Forró
Daniel Forro
Thank you
2016-07-30 by Daniel Forró
Daniel Forro
Thank you
