Wiardgroup
Index last updated: 2026-04-28 23:41 UTC
More Sequantizer/Quantizer tips
2007-09-18 by Grant Richter
Using the transpose input of the Sequantizer will also allow you to add portamento to
keyboards which don't have it. Like some MIDI/CV converters.
Using a keyboard which DOES have portamento and sending it through a quantizer like Bank
15 of the Waveform City or Mini-Wave, you can convert a portamento to a glissando. The
sliding control voltage will be quantized along with the key control voltage steps. You may
need to use a mixer processor type module to add a 40 millivolt offset to the keyboard
voltages so they fall into the "middle" of the 83 millivolts "windows" that the quantizer input
has. This should minimize "dithering" when the keyboard voltage is close to a transistion
voltage.
