Input Channel, External Controllers, MIDI outputs, and EMUE5000
2003-07-30 by drewaight1
Hey heres a seemingly stoopid question. As usual I am only posting
because I cant find the answer anywhere.
In a year of using my MP-7 I have yet to use any tracks on the B
channel. Yeah well I have other grooveboxes and samplers going too so
I havent need it. However I just got an EMUE5000 and my plan was to
have all the Channel B tracks dedicated to it. So I noticed some
strange things about the tracks 1B-16B. Let me get this straight.
1. The Mp-7 can only accept 16 incoming MIDI channels
2. The only way to play tracks 1B-16B with an external controller is
to set MIDI channel in to B in the MIDI menu thereby making it
impossible to play tracks 1A-16A....If my EMUE5000 is set up for
tracks 1B-16B (output B) the only way to control it live is to go
through the MIDI menu and change the MIDI in channel. Kinda
inconvenient dont you think?
So heres my question, I set MIDI off for the MP-7 for tracks 1B-16B
cause I dont want the sampler and MP-7 playing at the same time. I
set MIDI merge to B on. I set all B tracks in the Pattern menu to ext.
However, the sampler does NOT play unless I turn on track
rechannelize to on, this is bad because I prefer to be able to change
channels through my controller and be selecting patches on the MP-7
while I play on a different channel with the keyboard.
Does the fact that track rechannelize must be on for it to work
indicate that my controller is outputting the wrong channel. Unlikely
cause it only outputs 16 MIDI channels.
Thanks in advance and sorry for the long post.
Re: [xl7] Input Channel, External Controllers, MIDI outputs, and EMUE5000
2003-07-30 by Aaron Eppolito
This is exactly what "rechannelize" is for.  I'd recommend turning it
on "always" and getting used to not having to change the channel on
your keyboard.  It might take a few minutes to get used to, but in the
long run, you'll be FAR happier!
-Aaron
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
Re: Input Channel, External Controllers, MIDI outputs, and EMUE5000
it
> -Aaron
> Do you Yahoo!?
Whoops sorry about that.
Well let me put it this way Aaron, lets say you're up on stage
grooving live playing a bassline with your right hand, ah and now you
want to scroll through some patches to find the right pad, or set up
some Xmix action on another channel while you play the bass. With
rechannelize on you cant do that. It seems like a strange complaint
but i like being able to scroll to what im looking for before I
switch the channel on my Keyboard.
