(BUG) Notes recorded too long?
2001-12-13 by erik_magrini@Baxter.com
Anyone else had a problem with their note durations occasionally getting
set to the wrong value when you real time record?  Sometimes I'll record a
part in live record mode, then when I go to play it back, it plays through
the pattern once fine, but when the pattern loops, the sound drops out for
that track.  I'll go into Note List Edit to look at it, and only one of
the notes I played will have it's duration maxed out to the highest value,
when I obviously didn't hold the note for anywhere near that long.  If I
set the duration back to where it should be it's fine though, weird.  This
has happened a few times to me...
Another problem I get if I am playing and recording rhythm parts in real
time with the record quantize set to 1/16th notes.  Sometimes I like to go
into Grid mode after I'm done to move a note around a bit, add some
variety to what I played.  Occasionally I'll see a note indicator in the
display that I'm unable to get rid of.  I can clearly see that I've got a
note on the grid, however pressing the corresponding track mute button to
turn it off doesn't do anything.  The note stays there and continues to
sound.  The only way I can get rid of it, is to cursor to it's location
and set the velocity to 0, or enter Note List Editor and erase it there.
Anyone else seen this one?
Were these possibly fixed in the new OS?  Can we get list of the new bug
fixes in OS 1.18 please?
rEalm
Re: (BUG) Notes recorded too long?
2001-12-14 by tommy_trance
Occasionally I'll see a note indicator in the display that I'm
unable to get rid of.  I can clearly see that I've got a note on the
grid, however pressing the corresponding track mute button to turn
location and set the velocity to 0, or enter Note List Editor and
erase it there.  Anyone else seen this one?
Strange, after reading your comment, I tested out a pattern in 4
measures with arp on and
recorded pad rhythm in realtime using quantize value of 16.  Then I
went into grid mode
and record a few notes here and there in all 4 measures.  Then I
saved to pattern. Then I
replayed the sequence and I can hear my grid notes.  Then went into
grid mode to see where
they are located and it is clearly there also.  I cleared the grid
notes via pressing the track note button to mute like you did and it
all seemed okay on my end.  Did you try to create the same scenario
with another pattern to
see if it happens again?
getting
record a
through
out for
one of
highest value,
long.  If I
weird.  This
in real
like to go
some
in the
I've got a
button to
continues to
location
there.
new bug
> rEalm
