Re: [xl7] midi setup almost works
2003-08-21 by erik_magrini@Baxter.com
Advice? Stop being greedy :) Hehe, what exactly do you mean by "if I fire up a groovebox and hit record, nothing happens"? I'm not understanding what par of your set up isn't working for you.... rEalm Here is the one small problem: I write patterns on the non-XL boxes and then record them into Sonar, or at least I did before I had the XL. Now I cant do this anymore, if I fire up a groove box and hit record, nothing happens. If I change the DX for midi thru, all sorts of chaos happens. Setting the midi echo to off doesn't help either. So I could actually live with this, since I could just disconnect the xl and record the basic patterns like I used to - but I'm greedy and want it all! Any ideas most appreciated! [Non-text portions of this message have been removed]
