Accent Part
Accent Part
2003-10-10 by Christoph Kluxen
here´s a tip for non musicians to create accents without using velocity,
it was always quiet uncomfortable to edit accents in grid edit.
So, I wanted to accent up and downbeats (16th) automatically.
1. set the main volume to 127 (so you never have to think about it again..)
2. set that chord:
LFO 1+ -> Amp volume -> -008 (or anything)
3. set the LFO to Square 1/8 sync
4. set the preset amps
5.turn off vel-Amp, use vel for something else
that´s it, accented and non accented 16th, invert Amp to change accents, set
a second LFO to control LFO
1 to set other accents.
No use 16th quantized realtime record, voila. Put Quantization to it last or
program delays in the preset.
Besides you can use a arp pattern (Key 0, Length 2/1) to create a
synchronized synth, the note value in
the arp menue sets the quantization.
But you don´t have swing in the arp patterns, so that´´s one bad point for
the XX-7, I think there is just
the way to program delays in the preset menue, perhaps you could set some
notes earlier than others or
whatever.
Christoph
NEU FÜR ALLE - GMX MediaCenter - für Fotos, Musik, Dateien...
Fotoalbum, File Sharing, MMS, Multimedia-Gruß, GMX FotoService
Jetzt kostenlos anmelden unter http://www.gmx.net
+++ GMX - die erste Adresse für Mail, Message, More! +++
