Re: [xl7] Low Digital output - Sampling the Drum ROM.
2003-12-03 by erik_magrini@Baxter.com
what i don't understand is why the SPdif digital out has such a low
output.
>>>It has to acommidate for the fact that you could have up to 32
different presets playing at once.  If it didn't leave enough headroom,
there's would be clipping at the output. This is also the reason that the
Presets are stored on the ROM at about -14dBFS. <<<
also if you want to sample sounds off it is it best to use the Digital
output and then normalize or should you just sample off the analogue "Main
outs"?
>>>Definitely digital out, then normalize if you wish.  Analog will work
too, but the digital outs will give youa  cleaner signal. <<<
User Hint: If you have the Protean Drum ROM, you can sample every single
sound from it very easily.  Set up your sequencer to play a 45 minute long
SINGLE note, doesn't matter what note it is.  Then route that track to a
MIDI output connected to the XX_7.  Connect the digital out of the XX-7 to
your computer's sound card, and route that to an audio track in the
sequencer, preferably set to record at 24 bits.
Go to the Preset edit menu, and select the DRUM ROM Instrument: "779 Play
Through" for Layer 1.  Make sure all other layers are empty.  This is an
instrument that will sequencially play through all of the samples on the
Drum ROM as long as a key is pressed (thus the 45 minute note above).
While still in Preset Edit, make sure that you set the following for Layer
1:
Filter = None
Amp = +10
Non-Transpose = On
Make sure the layer isn't routed through any effects as well.  Now you
simply have to hit record, then play on the sequencer and sit back for
awhile while the it records all of the sounds as one long wave file.  Once
it's done, you'll still have to go back and trim out all of the samples
you want, but it's fairly easy to do.  Right before each sample, is a very
short noise burst (still trying to find out what this actually is, though
I have my ideas).  Simply zoom in while editing, and look for this noise
burst preceeding every sample.  Just after it you'll see a short section
of silence, and it's here you'll trim the sample start.
In fairness to Emu, I have to say I don't know about the legalities of
doing this.  Obviously you'd be wrong to sample them all and give them to
others, but I think it's ok to use them in your own productions.  I know I
did this so I could use my Drum ROM samples in Reason, and it's worked out
great.  The new samples on the Drum ROM are really sweet.
rEalm
The information transmitted is intended only for the person(s)or entity to
which it is addressed and may contain confidential and/or legally privileged
material.  Delivery of this message to any person other than the intended
recipient(s) is not intended in any way to waive privilege or confidentiality.
Any review, retransmission, dissemination or other use of , or taking of any
action in reliance upon, this information by entities other than the intended
recipient is prohibited.  If you receive this in error, please contact the
sender and delete the material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
Re: Low Digital output - Sampling the Drum ROM.
2003-12-03 by rajah_patel
hi
i think the samples (waveforms) in any case are 16bit
the XL-1 turbo has 16bit spdif (i asked emu)
it think the xl7 is 20bit
Thanks v.much for the through info guys...
and also for that beautiful tip on sampling all the drums
sequentially.
I just prefer drums coming from my sampler (organisation wise) and
treating my Emu module as a synth
Re: Play Thru
2003-12-04 by rajah_patel
hi
noticed that the Mo -phatt Rom has a 062(2) Rom:Play Thru
is this similar to the play thru function as described before?
Re: [xl7] Re: Play Thru
2003-12-04 by erik_magrini@Baxter.com
Should be.  Hold down a key and find out.
Uh oh, now I've done it :)
rEalm
rajah_patel <rajah_patel@...>
12/03/2003 07:26 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Play Thru
hi
For Translation:
