more tech??? not files!
2003-12-12 by dj 61
I had a tech question that appears to have been overlooked in the
files discussion. I will post it again since we all no there is no
such thing as a stupid question, only stupid people.
Here goes:
Say I have a 16 bar pattern. Often times when sequncing into a song,
I will loop only 1, 4, or 8 bars before playing out the 16. The
problem is on some loops it appears to cut off the first note. ie
when using an arp, it will not play back on some loops. I assume
this is because it is not playing the first not which is the only
note triggering the arp for the track. There seems to be no problem
in pattern mode.
Has anyone else encountered this?
Confession: only running os 1.38, but I have ordered a midi/usb
interface to upgrade. Will this still be a problem in 2.0? ALso can
you use x-mix in song mode or is it just for pattern mode?
Re: [xl7] more tech??? not files!
2003-12-12 by Aaron Eppolito
--- dj 61 <dj61@...> wrote:
> The problem is on some loops it appears to cut off the first note.
This is a known issue that was fixed in 2.00.
> ALso can you use x-mix in song mode or is it just for pattern mode?
Pattern mode only.
-Aaron
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing.
http://photos.yahoo.com/
Re: more tech??? not files!
2003-12-12 by dj 61
Thanks
What I get for being a step behind, I'll catch up soon
--- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
note.
mode?
> Pattern mode only.
> -Aaron
> Do you Yahoo!?
2003-12-15 by erik_magrini@Baxter.com
OS 2.0 will get rid of this problem for you.
rEalm
"dj 61" <dj61@...>
12/12/2003 01:32 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] more tech??? not files!
Here goes:
in pattern mode.
The information transmitted is intended only for the person(s)or entity to
which it is addressed and may contain confidential and/or legally privileged
material.  Delivery of this message to any person other than the intended
recipient(s) is not intended in any way to waive privilege or confidentiality.
Any review, retransmission, dissemination or other use of , or taking of any
action in reliance upon, this information by entities other than the intended
recipient is prohibited.  If you receive this in error, please contact the
sender and delete the material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
