xl7/s900 sampler issue
2003-12-21 by dlo_10035
can someone please help me figure how to sequnce samples from my akai
s900 into the xl7 using different tracks for different samples. i can
sequence one track fine but when i switch to another track it cuts
off the first i done when i hit the key pad. i hope i was clear and i
eagerly await any response. thank you!
Re: xl7/s900 sampler issue
2003-12-21 by mike
Let me make sure I am understanding you here.
You are trying to trigger samples in your s900 with the xl7?
What outputs are you using on the s900?
I am pretty sure that you have to use seperate outs for each sound in
the S900.  I could be wrong but that is how I rember that sampler
working.  At least the main outs would cut samples off when new ones
where triggered.  But it has been many years since i had a S900
Good luck
Mike G.
akai
can
i
thanks alot i think that will fix the problem...i just set back up
and i had the same issue once b4. thank you very much.
in
ones
> Good luck
> Mike G.
> akai
> can
cuts
and
> i
2003-12-21 by mike
your welcome
Mike G.
sound
> in
> ones
> > Good luck
> > Mike G.
my
> > akai
i
> > can
> cuts
> and
> > i
