I don't have my xl-7 in front of me but, from the
haze of last night's tinkering:
1. Yes. Each track is capable of addressing all
sixteen channels of Port A, or Port B, as internal, external or both
together. You can't, however, specify some channels as internal and others
as external, or some from port A and some from port B
(It can also be specified to only address 1
channel, so all notes are sent to the same channel, regardless of of
the channel specified by the note.)
2. They both play. I'm doing this all the
time.
3. Yes, they are all multitimbral, unless you
specify otherwise.
Sent: Thursday, September 06, 2001 11:23
AM
Subject: [xl7] Tracks in relation to MIDI
channels
I'd like to get clarification on
this.
1. One sequencer track is capable of addressing 16 MIDI
channels. My
understanding is that if you've sequenced a piano and a
bass line on
the same track, then the track will be addressing 2 MIDI
channels. Is
this correct?
2. What happens if you have 2 tracks
addressing the same MIDI
channels at the same time. Is that allowed?
3. So basically each track is a multi-timbral sequence? ... that
might explain the need for 128 polyphony.
To
unsubscribe from this group, send an email
to:
Your use of
Yahoo! Groups is subject to the Yahoo! Terms of Service.
