More Live Features?
More Live Features?
2002-01-07 by erik_magrini@Baxter.com
Q1. I want to be able to send a sequence (loop) out the MIDI Outs to my
synth and/or sampler instead of to the XL-7 internal sounds. For example
button 1-4 enable/mute the loops for the XL-7 internal drum set. Then
button 5-8 are configured to enable/mute loops that are sent to my Virus b
via the XL-7 MIDI Out A, then buttons 9-12 to my
sampler via MIDI Out B.
>>>Well you can't specify which tracks go to the internal sounds and which
ones go to the external ports.  But you can specify which MIDI channels do
this.  So basically yes you can do what you want, just watch your
terminology.  I say this because the tracks in the XL-7 aren't
"hard-wired" to their corresponding midi channels.  Ie, track 1 doesn't
have to be MIDI Channel 1, you can make it whatever you want.  Routing to
the external MIDI ports is controlled by the MIDI channel, not the track
number.... <<<<
rEalm
