Buggers
Buggers
2002-01-09 by erik_magrini@Baxter.com
- mp-7 runs (sometimes not) even if the tempo in the controller menu is
set to ext., (is this a bug?)
>>>Was it running originally before the tempo was set to EXT?  I was
getting some weirdness with this too when linked to my Micro Sync, even
before I activated the Micro sync.  Thought maybe I had accidentally
pressed play on the MS without realizing it... <<<
- midi data is received on the mp-7 (red light on) even if cakewalk as
master stops
>>>Not a bug, some gear sends out MIDI signals (sensing I think it's
called) when not playing back.  My CS2x does this too when connected to
the XL-7. <<<<.
- timing problems when mastering cakewalk from the mp7
>>>What problems? Out iof curiousity, why use the MP as the master?  Your
tempo would probably be tighter if Cakewalk was the master.  Could be your
MIDI interface too.  I had a slight timing problems using the MIDI port on
my Layla24, but when I swapped it to my girlfriend's MIDIsport 2x2,
everything was fine.  That's a hard one to nail down. <<<
- incorrect detection of tempo when synced to cakewalk, tempo changes on
the display, but the beat ist stable
>>>I DEFINITELY get this one too when I set the XL-7 to sync to EXT (Micro
Sync).  The tempo the XL-7 is getting is rock solid, yet the tempo display
is all over the place! <<<
omissions:
- no track/pattern delete function (only via cut to...)
>>> Erase events works for tracks, not sure how you would implement the
pattern one though.  Similiar to my Initial Pattern suggestion sounds
like. <<<
- no replace-function when copying tracks over existing tracks (only
merge)
>>>Oh yeah!  That would help save a lot of time! <<<
Nice ones!
rEalm
