this is a newbie question
2004-01-30 by M A Cinense
I need some help with some acronyms.  I know that this will not make
my beat making any better, but I hope it will help me understand the
unit better.  So any help would be great.
here it goes:
BTS =
MSB =
LSB =
I guess that is for now, I may have more later on.
thank you in advance.
Re: [xl7] this is a newbie question
2004-01-30 by Aaron Eppolito
--- M A Cinense <studio_6512@...> wrote:
> BTS =
Beats (n.) A small 16 channel sequence that can be triggered from the
audition riff or from beats mode.
> MSB =
Most Significant Byte (n.) In a number, the high digit.  Most often
used with bank select command to choose ROM ID.
> LSB =
Least Significant Byte (n.)  The low digit.  With E-mu devices, this
bank select LSB selects the "bank" within a particular ROM.
Source: Aaron's House of Definitions  =)
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
http://webhosting.yahoo.com/ps/sb/
Re: Aaron's House of Definitions =): BTS: Beats
2004-01-31 by steve_the_composer
--- In xl7@yahoogroups.com, Aaron Eppolito wrote:
> BTS =
> the audition riff or from beats mode.
Suggested addendum:
BTS (1) a prefix used by E-Mu (one of several e-music gear
manufacturers) for patches (presets, in E-Mu terminology) optimized
for being played with E-Mu's amazing beats functionality found in
gear based on their Proteus 2000 synth engine with either OS 2.26 (12-
controller based gear)or OS 2.0 (16 controller-based gear). (2) the
preset itself, usually containing 4 differerent layers zoned across a
keyboard map. For example, L1 may be a SFX (Special Effects) ROM
Instrument assigned to the keyboard range C-2 through A#0, L2 may be
a KIT (drum kit)ROM Instrument assigned to the keyboard range B0
through B3, L3 may be a BAS (Bass) ROM Instrument assigned to the
keyboard range C4 through B5, and L4 may be a STR (string) ROM
Instrument assigned to the keyboard range C6 through G8. (3) a prefix
used by E-Mu to designate special audition riffs optimized for E-Mu's
beats functionality.  See Beats.
NOTE: The BTS prefix may be selected alphabetically when using E-Mu's
built-in preset navigator. In preset edit mode BTS riffs are
alphabetically navigable.
Links to long-winded LSB/MSB explanation posts
I spotted some inconsistent use of terminology in the following
links, but the basic concepts are (I believe) sound.  I hope it helps
with some practical insights into how to use MSB #s.
http://groups.yahoo.com/group/xl7/message/11438
"LSB/MSB & Bank Switching - part 1: bits and bytes"
"LSB/MSB & Bank Switching - part 2: Selecting E-Mu Presets"
> make my beat making any better, but I hope it will help me
> understand the unit better.  So any help would be great.
> here it goes:
> BTS =
> MSB =
> LSB =
