Nice use of the input transformers! I think that the best thing to do,
would be to just insert a bogus message CC into the blank tracks in the
XL-7. Maybe insert a Pan Command that set the panning to center (unless
you use panning a lot), or something else that's esoteric.
rEalm
In Cubase I have a template with 12 midi tracks which map to tracks 5-
16 from the XL-7. I am using the input transformer on the tracks in
Cubase so that they filter out channels not assigned for this track.
For example:
In cubase:
Midi Track 1 -> Halion channel 1 <- From XL-7 channel 5
Midi Track 2 -> Halion channel 2 <- From XL-7 channel 6
Midi Track 3 -> Halion channel 3 <- From XL-7 channel 7
Midi Track 4 -> Halion channel 4 <- From XL-7 channel 8
Midi Track 5 -> Virusb channel 1 <- From XL-7 channel 9
Midi Track 6 -> Virusb channel 2 <- From XL-7 channel 10
Midi Track 7 -> Virusb channel 3 <- From XL-7 channel 11
Midi Track 8 -> Virusb channel 4 <- From XL-7 channel 12
Midi Track 9 -> MS2000r channel 1 <- From XL-7 channel 13
Midi Track 10 -> MS2000r channel 2 <- From XL-7 channel 14
Midi Track 11 -> Juno 106 channel 1 <- From XL-7 channel 15
Midi Track 12 -> Absynth2 channel 1 <- From XL-7 channel 16
This is my scratch-pad template that also involves using Ableton Live
rewired to Cubase. This way I can use the XL-7 in the same manner I
use Ableton Live, for example, quickly trying out different
combinations of both audio(Ableton Live) and midi(XL-7)loops, using
the mute buttons on the XL-7 and keyboard maps for Live.
-grimley
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
> What do you mean so you can control Cubase? As in it's track
faders, or
> onscreen synths? I would just create a Multisetup with the
appropriate
> channel and CC's assigned to each knob in Program Mode, might be
> easier....
> rEalm
> rEalm,
> Thanks for the reply. No, I don't have any data on the tracks. I
> was just trying to create a template that I can use with Cubase.
Is
> there anything I could put in the tracks that would fool the XL7
but
> wouldn't be of any significance audio-wise.
> Thanks,
> grimley
> > You have to have some type of data on the track for it to
remember
> it's
> > settings. Do you have midi data on those tracks?
> > rEalm
> > "Justin Grimley" <grimley@i...>
> > 02/02/2004 12:22 PM
> > Please respond to xl7
> > To: xl7@yahoogroups.com
> > cc:
> > Subject: [xl7] Losing INT/EXT track settings
> > I've just started using the XL7 to control my other gear.
However,
> > when I set a track to be external, the setting doesn't stick. I
am
> > using Pattern Edit, then routing each channel 09A - 016 to
> external.
> > However, the settings continually get reset to internal. It
seems
> > that when I change an earlier channel to internal for example
(01A -
> > INT) than all subsequent channels/tracks get set to internal.
> > Anyone any ideas?
> > Thanks,
> > grimley
> > Yahoo! Groups Links
> > To visit your group on the web, go to:
> > http://groups.yahoo.com/group/xl7/
> > To unsubscribe from this group, send an email to:
> > xl7-unsubscribe@yahoogroups.com
> > Your use of Yahoo! Groups is subject to:
> > http://docs.yahoo.com/info/terms/
> > The information transmitted is intended only for the person(s)or
> entity
> > to which it is addressed and may contain confidential and/or
> legally
> > privileged material. Delivery of this message to any person other
> than
> > the intended recipient(s) is not intended in any way to waive
> privilege
> > or confidentiality. Any review, retransmission, dissemination or
> other
> > use of , or taking of any action in reliance upon, this
information
> by
> > entities other than the intended recipient is prohibited. If you
> > receive this in error, please contact the sender and delete the
> > material from any computer.
> > For Translation:
> > http://www.baxter.com/email_disclaimer
> > [Non-text portions of this message have been removed]
entity
legally
than
privilege
other
> use of , or taking of any action in reliance upon, this information
by
> For Translation:
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
For Translation:
