hello ya all
hello ya all
2002-01-13 by mikexl7
Ok I am building sets of sounds in my E5000 to be sequenced by the
XL and I have to manualy set the fx send in the event list for each
track that I use in the E5000, super anoying.  I have asked the
question befor but I would like to get a better understanding of why
this is happening.  And also the controller number that I have to
use to set this up right.  It has ben a wile since I have used the
E5000 due to previous frustrations using external gear with the XL.
Another thing that I don't understand is why when I am using my
controller to play the XL and the other sound moduals in my studio
the midi chanel that is selected in the controller still plays the
midi channel that is is set to as well as the channel that the XL is
set to.  what am i doing wrong here.  I have Rechanalize midi in
turned to always and the Merg midi in to out ON so I can play my
other sound sources.  Man oh man unless I am loosing my mind this
was working for me after the new os came out and now I have done
sompthing and it dont work.
well some feed back on this would be great. As it stands I often get
an idea and just cant deal with all the little nagging problems hour
after hour in the studio and am quickly building a pile of half
finished tracks.  My fault I know I am not blaming emu for this but
the frustrations that are ongoing with this thing are becoming very
tedious and are contributing to the problem.
Please help
Mike.
Re: [xl7] hello ya all
2002-01-14 by Aaron Eppolito
You can set these in the MIX OUTPUT page in the Global menu.  Also, if you
don't want the XL-7 to send these at all, set each external track to "ext" in
the CHANNEL ASSIGNMENT page.  Then, if you've already saved once with it set
otherwise, go and erase cc#79 (and any other cc# & prog change you don't
want).  Then, when you resave, those initial events won't be there.
I'm trying to follow along here, but I think I'm getting a bit lost.  In the
above situation (if I understand your routing correctly), the XL-7 should be
playing its *basic channel* and your external synths should be playing the
keyboard's basic channel.  If this is not what's happening, let me know.
-Aaron
