Controlling XL-7 from cubase
2002-01-14 by dkravan
I hooked my XL-7 up to cubase and I can use the sounds etc
easily enough.
My problem is that if i send midi clock to the XL-7 then
the sequencer starts playing (when I just want to use the
sounds basically).
What is the best way of having XL-7 and Cubase in the same
setup?
Re: [xl7] Controlling XL-7 from cubase
2002-01-14 by Scott Ruda
> sounds basically).
It sounds like Cubase is sending a MIDI Song Start command out over
MIDI. The XL-7 shouldn't start on it's own without something telling it
to start. Turning off sending Song Start should be an option somewhere
in Cubase.
Scott
2002-01-14 by Lynn Bruington
just put the thing on an empty pattern
Sent: Monday, January 14, 2002 1:23 AM
Subject: [xl7] Controlling XL-7 from cubase
easily enough.
sounds basically).
setup?
2002-01-15 by erik_magrini@Baxter.com
Turn off send MIDI Clock & MTC in Cubase.  I believe it's in the
Synchronization menu, lower right corner.
rEalm
sounds basically).
2002-01-15 by Lynn Bruington
fuck that, don't you want the arpeggiator and other shit to sync?? just put it on an empty pattern
Sent: Tuesday, January 15, 2002 7:45 AM
Subject: Re: [xl7] Controlling XL-7 from cubase
Turn off send MIDI Clock & MTC in Cubase. I believe it's in the Synchronization menu, lower right corner.
rEalm
sounds basically).
Didn't think about the arps, sorry!
rEalm
"Lynn Bruington" <nufleisch@...>
01/15/02 08:59 AM
Please respond to xl7
        To:     <xl7@yahoogroups.com>
        cc:
an empty pattern
To: xl7@yahoogroups.com
rEalm
sounds basically).
2002-01-16 by Scott Ruda
> sounds basically).
Or, like suggested before, tell Cubase to *not* send a Song Start
command when it starts.
Scott
