Hum Elimination (was: New User)
2004-02-21 by Andy Hutson
Yes, testify, brotha!  I have become a sort of EbTech Evangelist!  I once
suffered huge ground loop hum.  Hum Eliminators made it all go
away...completely, permanently!  Blessed silence!  Hallelujah!
Glad to hear that the Hum-X is good too.
Andy
=== ORIGINAL MESSAGE ===
Subject: RE: Re: New User
> Really hard to suggest how to get rid of a ground loop
No, really easy:
EbTech Hum Eliminators. These things WORK! Also, the new HumX is great.
-m@
Re: Hum Elimination (was: New User)
2004-02-21 by Mike-E
How many Hz does it work on? In Holland the humm is 50Hz.
I once
> Andy
>    From: "Matt Picone" <matman@m...>
> No, really easy:
great.
> -m@
2004-02-22 by Andy Hutson
Hi Mike,
Fortunately, this is totally irrelevant.  The Hum Eliminator is an isolation
transformer, not a filter, so it does not matter what frequency your AC
power mains are.
They SHOULD work equally well, anywhere in the world, but you may want to
verify that with the manufacturer:  info@...
Manufacturer's website:  http://www.ebtechaudio.com/products.html
Andy
===== ORIGINAL MESSAGE =====
   Date: Sat, 21 Feb 2004 20:37:11 -0000
Subject: Re: Hum Elimination (was: New User)
Re: [xl7] Re: Hum Elimination (was: New User)
2004-02-22 by Wesley D
where do these things come from and how much are they?
you're talking about a circuit that recognizes noise more or less and flips the phase essentially cancelling it right?
have you also tried using a direct box and 'lifting' the ground?
Ground hum sucks.  not to mention, they say somewhere between 1 in 5 or 1 in 10 outlets is wired improperly.  apparently black, which is usually ground, on a normal US outlet is hot, white is neutral, and green is ground.  so naturally people can get confused.
If anyone has a killer ground hum that you just can't shake it's possible your building isnt' grounded properly.  You can check behind that plate on your circuit breaker, there should be an actual wire there.  I've heard of homes not having them.  Also, sometimes they don't bury the grounding rod as deep as they should.  I forget how deep it's supposed to go.
Peace,
WEsley
Do you Yahoo!?
Yahoo! Mail SpamGuard - Read only the mail you want.
Circuit Testers/Recepticle Testers
2004-02-23 by steve_the_composer
--- In xl7@yahoogroups.com, Wesley D <Serfiss@y...> wrote:
[snip]
[snip]
Here in the US, full service hardware stores usually have a little
Circuit Tester you plug into the 3-prong outlet to tell you how the
outlet is wired (or miswired).  Anyone who has any e-music gear worth
protecting should spend the money to get one.  I think they are under
$5.00.
It won't get rid of your hum, but it will tell you if the circuit is
wired correctly.
Mine is from Gardner Bender, Inc. Milwaukee WI 53209.  Using 3 lights
(2 amber, 1 red), it shows the following conditions:
--open ground
--open neutral
--open hot
--hot/ground reverse
--hot/neuttral reverse
--correct
Mine is yellow; evidently they are now red.  Looks like list is now
$5.49.
http://www.gardnerbender.com/fr_testers.html
If you want one, try a hardware store.
Hope this helps.
PS:  If you attempt to rewire an outlet (or convert froma two prong
socket to a three prong socket), please make sure the circuit is off
first!!!  (The tester is also good for that--much handier than
carting around a light or powering up your rig.)
2004-02-23 by Mike-E
Oh OK... and uh... voltage? ;)
220 volt over here.
> Hi Mike,
isolation
your AC
> power mains are.
want to
> verify that with the manufacturer:  info@e...
> Andy
>    From: "Mike-E" <d_jumpmaster@y...>
