Cakewalk StudioWare Panels; (1) Realtime Preset Editor (2) Controller Panel
2004-02-27 by steve_the_composer
I have uploaded two zipped files created by Dave Crowl. Each file has a StudioWare panel for use with Cakewalk Software [Cakewalk Pro Audio and its successors] plus a readme file. (1) P2500 StudioWare panel ->Functions as a preset editor -->(edited presets can be saved to E-Mu) ->Allows for realtime recording of preset editor changes --->(Cakewalk records sysex commands generated by StudioWare panel) (2) Controller panel ->8 Assignable CC Sliders [global select channel 1->16/track 1->64] Although they were designed using the P2500, I believe they should be fully functional on the Command Stations (and other P2K synth engine gear). If there are any problems, let me know and I will (1) remove the files if necessary and (2) pass the details onto Dave. As usual, all standard precautions/warnings apply. Make sure to make backups of presets, tunes, etc. Hope you find these useful. --Dr. Steve =============================================== Legacy gear need not fade away! Creativity is only limited by the imagination! ===============================================
