Track Destination and MIDI on off. Controlling external gear.
2004-03-03 by drewaight
Hey Aaron....how come when track rechannelize is off and I set a
track destination to "ext" I also have to turn off the MIDI channel
or else the internal patch still plays. Shouldn't the Track
destination set to external preclude having the internal sounds
played? I kind of would like to leave the MIDI channel on, that way I
can play external tracks using the XX-7 pads.
Re: [xl7] Track Destination and MIDI on off. Controlling external gear.
2004-03-04 by Aaron Eppolito
Um, because you turned rechannelize off?
Seriously though, that's exactly what rechannelize is for.
-Aaron
Do you Yahoo!?
Yahoo! Search - Find what you\ufffdre looking for faster
http://search.yahoo.com
Re: Track Destination and MIDI on off. Controlling external gear.
2004-03-04 by drewaight
It is entirely possible that i am a retard.......but i dont
understand your answer.
The tracks and the channels are separate no? which is why the unit
kicks so much ass. However if the sequence of events is MIDI -->
rechannelize --> MIDI channel --> track --> output. How is it
possible that a MIDI channel assigned to only one track that
has "ext" as its destination can get to the internal sounds.
Rechannelize hijacks whatever the input is and forces it to be the
channel that is currently selected so how does turning this off make
it so that incoming MIDI messages can force assigned tracks to
output on the internal sounds.
Seriously I do not like rechannelize...i leave it off at all times.
The rechannelize feature belongs on a Casio and not a serious
gigging instrument. I dont need any sequencer to hold my hand and
make sure im in the right channel when i play. Can we set up a poll
and see who leaves rechannelize on and who disables it?
Thanks so much for humoring me. As always im sure there is something
about the XX-7 that im not understanding and will probably feel
stoopid when it is pointed out to me.
                                       Drew
> -Aaron
channel
> Do you Yahoo!?
> Yahoo! Search - Find what you're looking for faster
Re: [xl7] Re: Track Destination and MIDI on off. Controlling external gear.
2004-03-04 by erik_magrini@Baxter.com
I love rechannelize, and pretty much it's always on with my PX-7.  I'll
set up a poll though, just for you! :)
rEalm
                                       Drew
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
Correct.
> MIDI --> rechannelize --> MIDI channel --> track --> output.
Not quite.  It's more like:
MIDI (or pads) --> track --> rechannelize (and int/ext'ify) --> output.
There're nice big flowchart diagrams in the 2.0 addendum (1.31
addendum?) that detail how rechannelize works.
> How is it possible that a MIDI channel assigned to only one track
that
This is where your disconnect is.  TRACKS have "int" and "ext"
destinations, CHANNELS do not.  Tracks are assigned to channels, not
the other way around.
MIDI comes in on channels.  With rechannelize off, it will play the
internal channels.  With rechannelize on, it will send all incoming
MIDI to the current track's output, be it internal or external.
Um, well, obviously you do, because otherwise, when you wanted to play
an external track, you'd like turning on "keyboard transmits MIDI",
turning off "local control", setting the "keyboard channel" to be the
right channel, and reassigning any knobs that you wanted to use.  When
you wanted to play an internal sound, you'd like to have to put it all
back.  Not saying you couldn't do it, but it sure seems like the
feature you claim you hate is the one you're asking for...
-Aaron
Do you Yahoo!?
Ah ha. So that means if I record on TRACK 1 assigned to MIDI
CHANNEL_01 with TRACK_05 = "ext" rechannel = "off" but MIDI_C05 = "on"
Then the playback of that TRACK should be on the external device only?
> Correct.
output.
> that
make
play
When
all
> -Aaron
> Do you Yahoo!?
2004-03-05 by Aaron Eppolito
> "on"  Then the playback of that TRACK should be on the external
device
> only?
Huh?  Now I'm confused.
Okay, here's a summary:
1 - You can only record one TRACK at a time
2 - Tracks may hold one or 16 channels
3 - You can record any channel into a track
4 - What comes OUT of a track may not be the same as what you put in
    * this is because if rechannelize is off, you may be putting
      events into the track that do not correspond to its output
5 - Rechannelize on/off ONLY affects INPUT, not track output
6 - You cannot specify the track to record via an external channel
7 - With rechannelize off, MIDI input will ALWAYS play internal
with rechannelize ON:
MIDI --> Track --> [track destination/channel] --> synth and/or output
with rechannelize OFF:
MIDI ---> Track
      \-> Synth
Really, read the diagrams.  They are not misleading.  I drew the
diagrams and wrote the code and the QA guys used it in their testing.
They may be unclear and/or hard to understand, but they are correct.
The only reason you should have rechannelize OFF is if you are
sequencing the box with an external sequencer or if you are using it as
a multitimbral synth with a controller keyboard transmitting multiple
channels.
-Aaron
Do you Yahoo!?
> How can I select channels using my MIDI controller?
I think what you meant is:
How can I select *TRACKS* using my MIDI controller?
and the answer is "you can't".
> Ideally I want the sequencer to control the track routing, BUT my
> MIDI controller to control the channels. After looking at the diagram
> it seems that track routing is intrinsically linked to rechannelize.
> I can use only rechannelize AND track routing, or neither. I dont
> entirely understand why these components must be linked.
Not quite.  Track routing is ALWAYS ON no matter what.  The tracks will
always PLAYBACK on the channels and destinations that they say they
will.
Rechannelize (which also "reportifies" but there was no UI room for
that) only affects incoming MIDI and the pads.  With rechannelize off,
you will not hear the same thing when you're recording as you do when
you play back.
I think I finally understand what you want.
You want to be able to say "anything that comes in on MIDI channel 5
goes to track 5, and will play the same sound as track 5, internal or
external".  Unfortunately, this is simply not how the XL-7 works.  You
can only record one track at a time, and you must specify it on the
unit itself.  Therefore, you should have rechannelize on, and simply
change the track/channel on the XL-7 and leave your master keyboard's
channel alone.
-Aaron
Do you Yahoo!?
2004-03-05 by drewaight
Haha i tried to delete the first message after i posted it.
I think i finally understand now. Thank you so much for your
patience. =)
I kind of hope that other people are confused by this too because if
I was the only one Id feel stupid.
                             Drew
Nah, it's not just you.  That's why I ended up making those digrams,
because it is so confusing.  There's a more elegant solution, but alas,
we ran out of time to implement it.  It's still my pet feature
though...
-Aaron
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
2004-03-05 by Ravi Ivan Sharma
Do tell! (if you can)
  To: xl7@yahoogroups.com
  Sent: Thursday, March 04, 2004 8:27 PM
  Subject: Re: [xl7] Re: Track Destination and MIDI on off. Controlling external gear.
  though...
  -Aaron
  Do you Yahoo!?
  Yahoo! Groups Links
    http://groups.yahoo.com/group/xl7/
RE-RE-RE-RE-RESTART Pattern
2004-03-05 by Matt Picone
Know what would have been nice? If holding STOP and START would have
stuttered the auto-restart of a pattern at the rate of the current
quantize when REPEAT were engaged.
-m@
Re: [xl7] RE-RE-RE-RE-RESTART Pattern
That's totally cool.
> -m@
Do you Yahoo!?
2004-03-05 by Turby Schmidt
I agree!
>From: Aaron Eppolito <synthesis77@...>
>Reply-To: xl7@yahoogroups.com
>Subject: Re: [xl7] RE-RE-RE-RE-RESTART Pattern
>Date: Fri, 5 Mar 2004 08:41:13 -0800 (PST)
> > -m@
>Do you Yahoo!?
Protect your PC - get McAfee.com VirusScan Online
http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
2004-03-12 by erik_magrini@Baxter.com
Wicked idea!
rEalm
"Matt Picone" <matman@...>
03/04/2004 11:15 PM
Please respond to xl7
        cc:
        Subject:        [xl7] RE-RE-RE-RE-RESTART Pattern
-m@
Yahoo! Groups Links
For Translation:
Re: RE-RE-RE-RE-RESTART Pattern
2004-03-12 by robotchas
> "Matt Picone" <matman@m...>
> -m@
Yeah, great idea. Should definitely go on the wishlist.
2004-03-17 by frodo76at
Well, if it helps ... I'm confused now too :P
After reading this rechannelize thing I think it might be the clou
to my MIDI IN to MIDI OUT problem.
I want to control external MIDI gear from my keyboard wich sends its
data trough the XL-7, because I want to record/play the XL-7 with it
AND have to use it for the other gear as well.
So it goes like this:
Keyboard -> (MIDI In set to B) XL-7 (MIDI OUT B) -> external
sequencers (synced to the XL-7)
The keyboard plays the XL-7 and (should play) the external
sequencers.
The problem is that if I set the MIDI IN to B, I cannot route
incoming MIDI data to any of the MIDI Outs.
I could solve the problem when selecting MIDI IN A, but then I not
only play the external, but also the internal XL-7 sounds when using
the factory patterns (because they are all on MIDI A).
When I turn off the MIDI A channels I cannot play back the patterns,
so I would have to rearrange all factory presets to be played via
MIDI B :/
So, is there an elegant way of solving this problem ?
Any help is appreciated !
>   ----- Original Message -----
digrams,
but alas,
>   though...
>   -Aaron
because if
>   Do you Yahoo!?
>   Yahoo! Groups Links
of Service.
2004-03-17 by Aaron Eppolito
Wow, you almost confused me.
There's two ways to do what you're asking; it depends on what you want.
Method 1: (recommended)
Use this if you want your external keyboard to play the appropriate
sound for the track you're working on.
Rechannelize ON, Merge MIDI A:OFF B:OFF, MIDI In Channels A, and...
for each track, setup its destination in the 2nd to last screen in the
pattern edit menu (i.e. should it play internally, externally, or
both).
Now, as you switch tracks on the XL-7, notes played from your kybd (or
pads) will always play the same sound as they will when you record that
track and play it back.
Method 2:
Use this if you want your external synth to always sound in response to
notes played on the keyboard, regardless of what track you're on.
Rechannelize OFF, Merge MIDI A:OFF B:ON (hook ext synth up to B), MIDI
In channels A.
Note however, that with method 2, notes from your external kybd will
ALWAYS play both the internal A synth channels as well as play your
external synth.  This is probably not what you want, but maybe it is.
-Aaron
> sequencers.
> MIDI B :/
> digrams,
> but alas,
> >   though...
> >   -Aaron
> because if
> >   Do you Yahoo!?
> >   Yahoo! Groups Links
> of Service.
Do you Yahoo!?
Yahoo! Mail - More reliable, more storage, less spam
http://mail.yahoo.com
2004-03-17 by drewaight
"Note however, that with method 2, notes from your external kybd will
external synth. This is probably not what you want, but maybe it is."
....Unless you turn the MIDI channel to off, which is what i do.
Actually I pretty much only use tracks and channels 1-5 for internal
sounds, so my main multisetup has tracks 6-16 ext and MIDI channels 6-
16 off. Of course you have to turn the MIDI back on if you are trying
to step sequence an external device, but in this case I have some
dummy patches with no waveforms selected....I use the same patches to
arpeggiate external devices also.
2004-03-18 by frodo76at
Rehi !
The problem is that I want to use the factory patterns (on MIDI 1-16
A) AND play external hardware with my keyboard through the XL-7. (I
have to go through the XL-7 because I need the MIDI clock signal of
the XL-7 for the tempo sync.)
My question: Can I route "MIDI In - B" to "MIDI Out A and/or B".
And if not ... Why ? I can do it with MIDI IN set to A, so ...
what's the difference and why's there a difference ?
I cannot find any reference to this in the manual.
When I go through it it seems that MIDI IN A can behave just like
MIDI IN B. There are no exceptions I'm aware of.
Is "MIDI IN - B" only meant for internal MIDI B sounds ?
If so this means that MIDI B would be the best place for factory XL-
7 sounds, since MIDI A is more flexible in routing the signal.
(internal and external)
This really gives me a headache.
Just to be a little more confusing ;)
Ronald
want.
> both).
(or
that
> Method 2:
response to
MIDI
> In channels A.
will
is.
> -Aaron
clou
its
with it
> > sequencers.
not
using
patterns,
via
> > MIDI B :/
> > digrams,
solution,
> > but alas,
feature
> > >   though...
> > >   -Aaron
> > because if
> > >   Do you Yahoo!?
> > >   Yahoo! Groups Links
Terms
> > of Service.
> > Yahoo! Groups Links
> Do you Yahoo!?
RE: [xl7] Re: Track Destination and MIDI on off. Controlling external gear.
2004-03-18 by Turby Schmidt
There is no midi in a isnt it, there is just one midi in but 2 midi out
but you can patch the midi in to any output,
just have in mind that the settings wont be stored in the pattern if there
is no note or controller data to save
>Rehi !
>Ronald
>want.
>the
> > both).
>(or
>that
> > Method 2:
>response to
>MIDI
> > In channels A.
>will
>is.
> > -Aaron
>clou
>its
>with it
> > > sequencers.
>not
>using
>patterns,
>via
> > > MIDI B :/
> > > digrams,
>solution,
> > > but alas,
>feature
> > > >   though...
> > > >   -Aaron
> > > because if
> > > >   Do you Yahoo!?
> > > >   Yahoo! Groups Links
>Terms
> > > of Service.
> > > Yahoo! Groups Links
> > Do you Yahoo!?
Add photos to your messages with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
In know that there is only one MIDI In, but you can assign it to be
MIDI In A or MIDI In B (see the MIDI setting: "MIDI IN CHANNELS")
There it says: "This menue allows MIDI data received at the MIDI
input port to control either the internal "A" or "B" channels. With
this set to "B", you could play an external MIDI keyboard on
channels 1B-16B while channels 1A-16A remain dedicated to the
internal sequencer."
Well, this is exactly what it does NOT.
When I select "MIDI IN CHANNELS: B" I cannot route the MIDI In
signals to the MIDI Out Port B. (Either not with MERGE MIDI IN TO
OUT B set to ON or OFF. And either not with RECHANNELIZE set to ON
or OFF)
So ... is it a bug ?
Thanks for the help !
Ronald
--- In xl7@yahoogroups.com, "Turby Schmidt" <trabantmusic@h...>
midi out
if there
> >Rehi !
16
(I
of
XL-
> >Ronald
you
> >want.
appropriate
and...
screen in
> >the
or
> > > both).
kybd
> >(or
record
> >that
> > > Method 2:
> >response to
on.
B),
> >MIDI
> > > In channels A.
> >will
your
it
> >is.
> > > -Aaron
> >clou
sends
> >its
> >with it
> > > > sequencers.
I
> >not
when
> >using
> >patterns,
> >via
> > > > MIDI B :/
<noision1@h...>
those
> > > > digrams,
> >solution,
> > > > but alas,
> >feature
> > > > >   though...
> > > > >   -Aaron
too
> > > > because if
> > > > >   Do you Yahoo!?
> > > > >   Yahoo! Groups Links
> >Terms
> > > > of Service.
> > > > Yahoo! Groups Links
> > > Do you Yahoo!?
2004-03-18 by n6i6s6
Have you set the B channel tracks to "ext" or both in the pattern
edit menu?
be
With
> or OFF)
> Ronald
2004-03-20 by frodo76at
Yes. The B channels are set to both, but I don't want to use recorded
patterns to go through the MIDI Out Port B. I would like to go
through the XL-7 to play external instruments live.
I also found out that rechannelize doesn't help me with that, since
there is no MIDI output either on MIDI Port B, when setting "MIDI In
to Output B" and selecting a MIDI B channel in the Sound-Preset
window. Seems like there is no way to get MIDI In B signals out of
the XL-7 (live). :(
In the meantime I tried a different setup.
I use the XL-7 rubber pads (mostly) for external instruments on other
MIDI equipment and the external keyboard for the internal XL-7 sounds.
Sadly I cannot use more than an octave for the external sounds, but I
think I won't need them that much, since I'm about to use the full
capacity of the XL-7 rom-space an therefore would be able to have
most of the instruments in my cool, freaky, funky, orange XL-7 baby =)
> edit menu?
> be
> With
ON
> > or OFF)
> > Ronald
