External tempo Sync Drift
2004-03-18 by wildstar_1701
hi folks. i could really use some help on this one, as it's grinding
my work to a
halt. problem summary: my XL-7's tempo drifts in relation to an
external
master tempo clock. yes, i have Base Tempo set to "ext". the XL-7 is
connected to a MOTU micro lite, connected via USB to my Mac G4,
running
Digital Performer 4.1 on OS 10.2.8.
as a Digital Performer sequence plays, the tempo on the XL-7 will
usually
start in-sync, then jump a few BPM's higher or lower, then return to sync for a
few measures. then it might jump 1 BPM higher, stay there for two
measures,
and then regain sync. the fluctuations are erratic, and while it
keeps sync
about 80% of the time, that other 20% can really screw up arpeggios,
delays,
and LFO's that are supposed to be tempo-synced.
the problem remains whether an empty sequence plays back (no MIDI
data at
all) or a sequence with 10 MIDI tracks and lots of CC info plays back.
i've checked, re-checked, and re-re-checked my Digital Performer sync
settings, and of course the XL-7's Base Tempo setting.  maybe it's
the MOTU
interface? maybe it's USB? i've heard strange rumors about MIDI and
USB not
getting along well. maybe it's that my MIDI interface is plugged into
a USB
hub?
i've tried searching the archive here, but haven't found anything
like this
problem. if anyone could direct me to a thread here that i've missed,
or of
anyone has some insight into this problem, you would have my eternal
gratitude. my hunch is that either i don't have DP's "transmit sync" settings
right (even though i THINK i do), or that there is a problem with USB or my
MIDI interface.
thanks!
Re: [xl7] External tempo Sync Drift
2004-03-18 by erik_magrini@Baxter.com
Wow, that's pretty crazy!  To be honest, the only setting that might have
anything to do with this in the XL-7, is the Base Tempo (which you already
know).  So I'd be inclined to think this is a motu problem rather than an
EMu one.  I know, I know, not what you want to hear, but I honestly can't
think of anything in the XL-7 that would be causing this.  Are you sure
you're using a quality MIDI cable?  It's a long shot, but that might be
causing it (very unlikely though).
When you say that the XL-7 is jumping up or down a BPM or two, how are you
determining this?  Just by looking at the front panel of the XL-7?  I
don't think that you should neccesarily go by just that, even with a solid
clock source, the XL-7's display tends to jump like that when sync'd
externally.  NOw if you're hearing timing fluctuations, that's a different
story.
Are you using the latest drivers for your MIDI interface?  I don't think
USB MIDI interfaces are inherently bad with timing though.  I use a
MIDISport 4x4 with no issues what so ever, so it can be done.
rEalm
as a Digital Performer sequence plays, the tempo on the XL-7 will usually
for a few measures. then it might jump 1 BPM higher, stay there for two
measures, and then regain sync. the fluctuations are erratic, and while it
keeps sync about 80% of the time, that other 20% can really screw up
arpeggios, delays, and LFO's that are supposed to be tempo-synced.
the problem remains whether an empty sequence plays back (no MIDI data at
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of, or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
Re: External tempo Sync Drift
2004-03-18 by deknoww
...i would first find a drum machine, or kbd with midi clock out and
try syncing with that....at least you could then eliminate the xl7 as
being the problem.
then, i would try using the mtp without the hub, and if that fails,
try another cheap midi interface.  those motu boxes can be a pain,
and may be the culprit.
deknow
> my work to a
> external
is
> running
> usually
to sync for a
> measures,
> keeps sync
> delays,
> data at
back.
sync
> the MOTU
> USB not
into
> a USB
> hub?
> like this
missed,
> or of
eternal
sync" settings
USB or my
> MIDI interface.
> thanks!
Re: [xl7] Re: External tempo Sync Drift
2004-03-19 by erik_magrini@Baxter.com
That's a good idea too, I use that one sometimes for trouble shooting.  If
you're syncing to another box, make sure it's tempo is set to a whole
number, as the XX-7's don't display finer resolutions, and the display
will always jump around in these cases.
rEalm
being the problem.
use of , or taking of any action in reliance upon, this information by
For Translation:
2004-03-19 by wildstar_1701
thanks for the help. i think i'm narrowing in on the problem. i don't have
another durm machine to test, but i am getting rock-solid sync with my other
synths for thier delays and LFO's, all hooked into the same MOTU interface.
so i think Digital Performer is not the problem. gotta be the cables, interface,
or XL-7 (which i highly doubt.)
realm, i took your suggestion and tried swapping MIDI cables. unfortunately,
it's the same brand of super cheapo cables, but a shorter length so i thought:
give it a try. the sync has actually improved a bit.  i'm not 100% about my
judgement now, since i've been obsessed with this problem for a couple of
weeks. so i went ahead and ordered a top of the line MIDI cable to see if that
helps. i once had a problem with cheap MIDI cables and my Nord modular a
few years ago (which i had forgotten about until you reminded me.)
you asked if i was going by the front panel display to verify tempo sync - yes
and no.  when i hear a fluctuation in delays or LFO's during playback, i'll look
at the panel and see that it has jumped to a signifigantly different tempo
(though briefly.) the typical fluctuations are small - 1or 2 BPM's, and i don't
hear anything wrong with those, so you're right that those must be normal. it's
the big stuff that screws everything up, but they don't last long.
if the new MIDI cable doesn't solve this, then i will probably try a new
interface. did you mention you used a MIDISport, realm? anything else that
anyone recommends? it's needs to be USB and Mac compatible.
thanks so much!
> being the problem.
2004-03-19 by dj 61
I have had this problem before, but it seems the display will lag
before the actual sounds. I guess it has its priorities straight.
  Tom
shooting.  If
whole
display
> rEalm
and
as
> being the problem.
entity
legally
than
privilege
other
information by
> For Translation:
2004-03-19 by dj 61
Ah, a DP user. I have spent the last few weeks trying to work with
DP. I think I'm going to loose my sound card and go w/protools. DP
just doesn't seem to make sense to me. How do you like it? (ver 2.72)
  Tom
don't have
with my other
interface.
cables, interface,
unfortunately,
so i thought:
about my
couple of
see if that
modular a
tempo sync - yes
playback, i'll look
different tempo
BPM's, and i don't
normal. it's
a new
else that
> thanks so much!
shooting.  If
whole
display
and
xl7 as
> > being the problem.
2.72)
>   Tom
are you nuts?! ditch DP for PT? stop the madness!
seriously though, do you like to do a lot of sequencing with your
computer?
(as opposed to your XX-7) because MIDI editing and sequencing with
Pro
Tools sucks. truly, profoundly sucks. PT excels at certain things,
but MIDI it
ain't. i use PT 6.1.2 with a Digi 002 Rack system for certain things,
but never,
ever MIDI.
no disrespect intended towards anyone who does like PT for MIDI,
because
i'm sure there are many serious dudes on this board who do serious
stuff with
PT. i tip my hat to them.
but you asked, so i'm answering, based on my own humble opinion. and
this
reply assumes you intend to do real sequencing with your DAW. i use
DP 4.1
on OS 10, but spent a few years on 2.7-3.2 in OS9 first. the first
thing you
should do is switch to OS10and upgrade to 4.1. the difference is
amazing. but
if you can't do that, at least upgrade to 3.2 for OS9. the jump
between 2.XX
and 3 is also pretty damn cool.
when it comes to MIDI sequencing with software, nothing, and i mean
nothing,
beats the Big Three: DP, Cubase, and Logic. kinda like Lexus,
Infinity, and
Acura. to each his own, but everyone knows those are the best. i
prefer DP
because i do a lot of film scoring, and it has a lot of features just
for folks like
me.
just as an example of why DP rules: have you tried <compressing> your
on-
velocity information with its "change velocity" tool? i mean come on!
that is the
coolest shit ever! you can set ratio, make-up gain...  or how about
drawing in a
nice logarithmic MIDI volume fade-in fade with the Pencil tool.
Pro Tools LE does not do these things. and it does not do a lot of
other
important stuff. Pro Tools LE is essentially designed to leave out
certain
features to make you want an HD system, which costs $10,000 or so.
i'm
assuming you're talking about a $400 - $2000 LE system.
 the Big Three are designed to be native-system answers to HD, TDM,
and
what-have-you. they are big players. they are deep. stick with DP,
get through
the learning curve, and you'll be glad you did. and MOTU's DP manual
is
great - i've read it cover to cover several times.
good luck with it!
2004-03-20 by dj 61
I have been using the mp-7 and 2500 for sequencing but I am planning
to move to computer for that to add more variation to loops. I have
read so many fhorror stories on having problems with new versions of
dp and osx. I am new to the mac platform and want to work with
something that is already stable. It did seem to have alot of midi
features that I did not see on PT, but I have not tried to do any
midi with either. What about audio functions? It is so much quicker
and more intuitive for me in the pro tools environment. Just the
simples audio editing seem slow in DP and just does not make alot of
sense to me. I would hate to try to do a stutter. Maybe I just need
to learn the shortcuts. I have played with cubase and logic as well,
but they were difficult for me as well. I just did simple recording
and audio sequencing. Do you have an extra copy of your old 2.xx
manual you want to get rid of? I do not have net or a printer at
home and it would be a small fortune to print on campus. I would
like to just purchase a print version. I posted a request on the DP
group but alas no response. Anyway I will keep working with it and
possibly use protools for audio.
   Thanks for your input. If you know where I could get a good DP
tutorial please post a link.
          Tom
with
DP
> 2.72)
> >   Tom
> computer?
> Pro
> but MIDI it
things,
> but never,
> ever MIDI.
> because
> stuff with
and
> this
> DP 4.1
> thing you
> amazing. but
> between 2.XX
> nothing,
> Infinity, and
> prefer DP
just
> for folks like
> me.
your
> on-
on!
> that is the
> drawing in a
> other
> certain
> i'm
> and
> get through
manual
> is
> good luck with it!
2004-03-20 by dj 61
          Tom
with
DP
> 2.72)
> >   Tom
> computer?
> Pro
> but MIDI it
things,
> but never,
> ever MIDI.
> because
> stuff with
and
> this
> DP 4.1
> thing you
> amazing. but
> between 2.XX
> nothing,
> Infinity, and
> prefer DP
just
> for folks like
> me.
your
> on-
on!
> that is the
> drawing in a
> other
> certain
> i'm
> and
> get through
manual
> is
> good luck with it!
2004-03-22 by erik_magrini@Baxter.com
Yes, I use a MIDISport 4x4 and have had no issues with it.  Though I must
add that this is with Windows drivers, so you may want to research and
make sure that the Mac drivers are stable too, I have no idea on that.
rEalm
For Translation:
2004-03-31 by wildstar_1701
just wanted to let folks know that a brand new, top of the line MIDI
cable did
the trick. i wouldn't have believed it, but now sync is 100% rock
solid. i got a
monster performance 500 MIDI cable, which cost 4 times as much as the
previous one! i tried to find a mogami MIDI cable, but no luck.
if any problems recur, i'll try a new interface.
thanks to all who responded for your help! realm, it looks like your
idea was
right on target, even though you seemed to doubt it yourself.
rock on, everyone.
I must
and
that.
> rEalm
a new
else that
entity
legally
than
privilege
other
by
> For Translation:
2004-03-31 by erik_magrini@Baxter.com
Excellent news!  I think for a MIDI cable, the Monster one is just fine,
probably would have been over kill to try and find a Mogami MIDI cable, if
they even make them.
rEalm
i got a monster performance 500 MIDI cable, which cost 4 times as much as
the previous one! i tried to find a mogami MIDI cable, but no luck.
For Translation:
2004-04-03 by Christoph Kluxen
havin no problems syncing XL-7, recorded notes from external, there is not 1
tick mistake, I´m using
z-tracker,
Christoph
+++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz +++
100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz
