PX-7 wobbly
PX-7 wobbly
2004-03-27 by metalflakk
Just a quick question, does anyone else's command station wobble from side to side when
you press the pads? Will E-mu fix this under warranty?
Also, mine spontaneously turns itself on every so often....but I guess that's to be expected.
=J=
Re: PX-7 wobbly
2004-03-27 by dj 61
Sounds like you might be missing a rubber pad from the bottom. If it
wobbles it should be obvious where the problem is by turning it
over. I assume you have tried setting it on different surfaces. As
for the turning on, you must be using the soft switch and not the
hard switch on the back, correct?
If the power in changes and the hard switch is still on then it will
come on. For example if you turn on an off your surge protector or
unplug and replug the unit. If you are not doing any of these things
you may want to make sure that your power flow is regular (no surge
or fault)
--- In xl7@yahoogroups.com, "metalflakk" <metalflakk@y...> wrote:
> Hi,
> =J=
Re: [xl7] PX-7 wobbly
2004-03-29 by erik_magrini@Baxter.com
to side when you press the pads? Will E-mu fix this under warranty?
>>>Yeah, mine did this a little bit too. I just glued a thin piece of
rubber on the bottom of one of the rubber feet to correct this. <<<
>>>NO that shouldn't happen! <<<
rEalm
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
