Patches won't change!!!
2004-04-05 by donegalpunk
Somebody tell me this is obvious...
I'm sending MSB LSB and Program change info to the xl-7, using it as
a sound module. The problem is that both the MSB and LSB change
appropriately, but the program change won't work!
HELP!
respond to donegalpunk@...
Re: [xl7] Patches won't change!!!
2004-04-06 by erik_magrini@Baxter.com
Are you sure you're sending the PC on the same MIDI Channel?  I know
obvious, but I can't think what else it might be....
rEalm
donegalpunk <donegalpunk@...>
04/05/2004 03:50 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Patches won't change!!!
HELP!
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
RE: [xl7] Patches won't change!!!
2004-04-06 by Turby Schmidt
It works fine with cubase...
there are some xml files in the files section, if you use cubase, you could
see how they are built and if you do it that way it should work fine, of
course you have to enable accept program change in the global menu
msb-lsb-prg.no.
Turby
>From: "donegalpunk" <donegalpunk@...>
>Reply-To: xl7@yahoogroups.com
>Date: Mon, 05 Apr 2004 20:50:01 -0000
>HELP!
The new MSN 8: smart spam protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
Re: Patches won't change!!!
2004-04-06 by donegalpunk
the support guys at EMU are not the most helpful in the world. I
performed a hard reboot on the XL7 and then it worked, go figure. All
the settings were correct before the reboot--must've been some other
issue that was corrected in the restart. The only change I have to
account for is the fact that the patches in the XL& patch numbers
start at "0" instead of one.
thanks for the help
you could
fine, of
> msb-lsb-prg.no.
> Turby
> >From: "donegalpunk" <donegalpunk@y...>
as
> >HELP!
> >respond to donegalpunk@y...
