saving arp-setting
saving arp-setting
2002-01-20 by ellmu
hi,
I use an arp inside a track. I save that preset. I save that pattern.
And I save the multisetup. But everytime I RTZ or power down/up the
arp has changed. How do I save the pattern that my track always has
the programmed arp????
Thanks
Gerald
Re: saving arp-setting
2002-01-20 by tekmunky
--- you wrote  "hi,
pattern.
> And I save the multisetup"
What you need to do is program the arp as part of the preset instead
of using the master arp.
Notice in the Edit Preset Menu there is an arp page, it is here that
you program the arp to play with that individual preset. Then when
you use that preset on a track in a pattern it will play the arp
settings saved with the preset.
Hope that solves your problem. I too initially had some issues with
how to get everything working correctly and thought that the OS
lacked features. What I realized is that it is all there and once you
know where all the settings are it is really very flexible. Good luck!
Emunky
2002-01-20 by ellmu
thanks a lot for your reply,
i never use the master arp, I always use the present arp. I don`t
know what I ´ve done wrong, but now it works.
thanks
gerald
--- In xl7@y..., "tekmunky" <tekmunky@p...> wrote:
> --- you wrote  "hi,
> pattern.
instead
that
you
luck!
> Emunky
