Multisetup questions.
2004-04-09 by Turby Schmidt
> >>>Send amoutns are saved as part of the Pattern, AND as part of the
>Multisetup.  But I think you're getting a bit confused about what Multi's
>are.  Basically, a Multi will override any settings made to the Pattern.
>It's global snapshot of all the XX-7's settings, including those that are
>also saved as part of a pattern.  They are completely independant though,
>so while they can save some of the same parameters, they have nothing else
>to do with each other. <<<
>rEalm
ii am a little confused to,
when i realized that the preset parameters get saved in the multisetup i
started a new setup with every new track, now, if i write a total different
multi [lets say to sequenz external gear] and if i later go back to a
pattern i made before the XX7 did not recognize the multi used originally by
the pattern. It uses different presets and fx parameters.
Whats the right way to save patterns and multis to be able to acsess them at
any time?
The new MSN 8: smart spam protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
Re: [xl7] Multisetup questions.
2004-04-09 by erik_magrini@Baxter.com
>>>Preset parameters are NOT saved as part of a Multi though.  A multi
will remember what Preset was assigned to each channel, but then so will a
Pattern.  Better off just saving the Pattern. <<<
now, if i write a total different multi [lets say to sequenz external
by the pattern.
>>>That's because Patterns have no way of knowing what Multi was used at
that time, and it's irrelevent anyway. <<<
It uses different presets and fx parameters.Whats the right way to save
patterns and multis to be able to acsess them at any time?
>>>That's because Patterns also store this info, so everytime you recall a
Pattern, it will ALWAYS use the Pattern settings.  Multi info is only
recalled when you Restore a previously saved Multi, otherwise Pattern have
priority.  Basically, if you're just writing Patterns, then save the
Patterns and don't even worry about Multis. Here's a quick rundown, this
is by no means a complete list though:
PATTERN DATA
- Presets assignments for each channel.
- Effects Types.
- Effect Send amount.
- Sequence data (notes, CC's, sysex, aftertouch, etc)
- Any other setting you make while in Pattern Edit (ie, output).
MULTI DATA
- All of the above.
- Screen contrast
- Midi Menu settings.
- Custom arps.
- Controllers menu settings.
- All global settings.
So you can see, that Multi's save a lot more information than Patterns,
but in terms of making regular tracks and such, just saving the Pattern
should be sufficient.  Multi's come in handy when you want to set up the
Controller Knobs to control different synths externally, and you need
different CC's for each knob depending on the synth.  Just one example,
there's literally hundreds more.  I think this is covered in the FAQ too.
rEalm
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
thanz a lot for the workaround, if it is so ...revert to saved pattern...
always should restore the original pattern, isnt it true? i try this
afternoon and come back...
MSN 8 with e-mail virus protection service: 2 months FREE*
http://join.msn.com/?page=features/virus
Yes, Revert to Saved will always restore the Pattern to what it was when
you last saved it.
rEalm
"Turby Schmidt" <trabantmusic@...>
04/09/2004 08:45 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        Re: [xl7] Multisetup questions.
Yahoo! Groups Links
For Translation:
