OS version 1.01 Download Problem
2001-09-08 by Melle
Hi everyone!!
Just purchased a new XL-7 and I'm loving it so far.
However, I'm having a problem downloading the latest OS version
1.01   When I launch the E-Loader application I'm able to select
the .dli file, but when i go to the "configure Midi Device menu" my
only options in the(input and output ports) are "none"
and "soundblaster PCI128." How do i get the EMU sound module to show
up in those windows so that I can select them?
Is there something I'm missing here?
Any and all suggestions appreciated!
Much appreciated,
Gazz
Re: [xl7] OS version 1.01 Download Problem
2001-09-08 by kgilani@earthlink.net
You need to configure your OMS setup for XL-7 first. Then you have to have
your midi interface on and connected. then try it again.
Cheers
Kamy
Hi everyone!!
Much appreciated,
Gazz
Re: OS version 1.01 Download Problem
2001-09-08 by Melle
ahh, thnx for responding Kamy!
 Please pardon my ignorance but what is OMS
set up? and Midi interface? Is that something I need in addition to
the midi expansion cable that I have connected between my sound card
and the XL-7 ??
thanx again!
to have
> Cheers
> Kamy
> Hi everyone!!
> Much appreciated,
> Gazz
Re: [xl7] Re: OS version 1.01 Download Problem
You probably don't need a midi interface, since XL-7 is you only midi gear.,
but your soundcard has to have at least 1x In and 1x out, which you will
interconnect to XL-7 In and out (2 cables).
i assume you have Mac:
Then download OMS for free at http://www.opcode.com  and install it.
Then open the software by going to OMS studio setup, and then select
auto-detect midi devices, here you sound card should show........then add on
your XL-7 manually by opening new device menu
then give it canal 1..........then save the setting and close OMS then go to
e-loader and try again..
Good luck
Kamy
and the XL-7 ??
thanx again!
(oh I forgot..you have PC......but it's basically the same procedure)
Good luck
Kamy
and the XL-7 ??
thanx again!
Y
