notes getting cut off in external gear
2004-05-14 by mike
2004-05-14 by mike
I am wondering if there is a fix for this "bug" that I don't rember hearing about. When sequencing external synths moving past the track the sustained notes get cut off. I can select the track but then when I select another track the notes being held release. This is a pretty big problem for me as I almost only use external sounds. Help! Mike G
2004-05-16 by keiodi
--- In xl7@yahoogroups.com, "mike" <curiousproductions@r...> wrote: > I am wondering if there is a fix for this "bug" that I don't rember > hearing about. When sequencing external synths moving past the track > the sustained notes get cut off. I can select the track but then > when I select another track the notes being held release. This is a > pretty big problem for me as I almost only use external sounds. > > Help! > > Mike G one thing to try is to switch the note destingation for that channel to both rather than int and then turn down the volume knob on the xl7 and see if that make a difference. I don't know if it is the same problem but when controlling my Boss SP-202 with my XL-7 I noticed that it wouldn't always trigger it. it was weird sometimes it would and sometimes it wouldn't but I couldn't figure out what the difference is when it works and not. with the destination set to both it triggers it fine. I haven't noticed it with any other external gear.
2004-05-16 by mike
thanks that is a good idea i will give that a shot. Mike G. --- In xl7@yahoogroups.com, "keiodi" <ms06j@h...> wrote: > --- In xl7@yahoogroups.com, "mike" <curiousproductions@r...> wrote: > > I am wondering if there is a fix for this "bug" that I don't rember > > hearing about. When sequencing external synths moving past the > track > > the sustained notes get cut off. I can select the track but then > > when I select another track the notes being held release. This is > a > > pretty big problem for me as I almost only use external sounds. > > > > Help! > > > > Mike G > > one thing to try is to switch the note destingation for that channel > to both rather than int and then turn down the volume knob on the xl7 > and see if that make a difference. > > I don't know if it is the same problem but when controlling my Boss > SP-202 with my XL-7 I noticed that it wouldn't always trigger it. it > was weird sometimes it would and sometimes it wouldn't but I couldn't
> figure out what the difference is when it works and not. with the > destination set to both it triggers it fine. I haven't noticed it > with any other external gear.
2004-05-18 by mike
Ok I can't seem to make this stop happening it is not some thing that is bothersome all the time but this is a pretty big bug if you ask me. Is there a work around? Mike G. --- In xl7@yahoogroups.com, "mike" <curiousproductions@r...> wrote: > thanks that is a good idea i will give that a shot. > > Mike G. > > > --- In xl7@yahoogroups.com, "keiodi" <ms06j@h...> wrote: > > --- In xl7@yahoogroups.com, "mike" <curiousproductions@r...> wrote: > > > I am wondering if there is a fix for this "bug" that I don't > rember > > > hearing about. When sequencing external synths moving past the > > track > > > the sustained notes get cut off. I can select the track but then > > > when I select another track the notes being held release. This > is > > a > > > pretty big problem for me as I almost only use external sounds. > > > > > > Help! > > > > > > Mike G > > > > one thing to try is to switch the note destingation for that > channel > > to both rather than int and then turn down the volume knob on the > xl7 > > and see if that make a difference. > > > > I don't know if it is the same problem but when controlling my Boss > > SP-202 with my XL-7 I noticed that it wouldn't always trigger it. > it > > was weird sometimes it would and sometimes it wouldn't but I > couldn't > > figure out what the difference is when it works and not. with the > > destination set to both it triggers it fine. I haven't noticed it > > with any other external gear.
2004-05-18 by Aaron Eppolito
When you move through a track, it sends an all notes off for that track if it's an external (or both) track. I suppose I thought this was a good idea. It's somewhat of a copout instead of keeping track of every note played via pads or soft-thru'ed MIDI so that you could send each note off when you switch away from the track. We do this for internal tracks (i.e. all notes off *just* for notes played by hand) because the synth architecture made it easy, but the data structures weren't there for the ext stuff, and I didn't have time to put them there. If you want (and can in your external gear) disable all notes off, but then make sure not to hold any notes while you switch tracks, or else you'll get stuck notes. -Aaron --- mike <curiousproductions@...> wrote: > Ok I can't seem to make this stop happening it is not some thing that > is bothersome all the time but this is a pretty big bug if you ask > me. Is there a work around? > > Mike G. > > --- In xl7@yahoogroups.com, "mike" <curiousproductions@r...> wrote: > > thanks that is a good idea i will give that a shot. > > > > Mike G. > > > > > > --- In xl7@yahoogroups.com, "keiodi" <ms06j@h...> wrote: > > > --- In xl7@yahoogroups.com, "mike" <curiousproductions@r...> > wrote: > > > > I am wondering if there is a fix for this "bug" that I don't > > rember > > > > hearing about. When sequencing external synths moving past the > > > > track > > > > the sustained notes get cut off. I can select the track but > then > > > > when I select another track the notes being held release. This > > > is > > > a > > > > pretty big problem for me as I almost only use external sounds. > > > > > > > > Help! > > > > > > > > Mike G > > > > > > one thing to try is to switch the note destingation for that > > channel > > > to both rather than int and then turn down the volume knob on the > > > xl7 > > > and see if that make a difference. > > > > > > I don't know if it is the same problem but when controlling my > Boss > > > SP-202 with my XL-7 I noticed that it wouldn't always trigger > it. > > it > > > was weird sometimes it would and sometimes it wouldn't but I > > couldn't > > > figure out what the difference is when it works and not. with > the > > > destination set to both it triggers it fine. I haven't noticed > it > > > with any other external gear. > > > > ------------------------ Yahoo! Groups Sponsor > > > Yahoo! Groups Links > > > > > __________________________________ Do you Yahoo!? SBC Yahoo! - Internet access at a great low price. http://promo.yahoo.com/sbc/
2004-05-20 by mike
thank you for your responce to this Aaron. Please dissreguard my previous post. Mike G. --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > When you move through a track, it sends an all notes off for that track > if it's an external (or both) track. I suppose I thought this was a > good idea. It's somewhat of a copout instead of keeping track of every > note played via pads or soft-thru'ed MIDI so that you could send each > note off when you switch away from the track. > > We do this for internal tracks (i.e. all notes off *just* for notes > played by hand) because the synth architecture made it easy, but the > data structures weren't there for the ext stuff, and I didn't have time > to put them there. > > If you want (and can in your external gear) disable all notes off, but > then make sure not to hold any notes while you switch tracks, or else > you'll get stuck notes. > > -Aaron > > --- mike <curiousproductions@r...> wrote: > > Ok I can't seem to make this stop happening it is not some thing that > > is bothersome all the time but this is a pretty big bug if you ask > > me. Is there a work around? > > > > Mike G. > > > > --- In xl7@yahoogroups.com, "mike" <curiousproductions@r...> wrote: > > > thanks that is a good idea i will give that a shot. > > > > > > Mike G. > > > > > > > > > --- In xl7@yahoogroups.com, "keiodi" <ms06j@h...> wrote: > > > > --- In xl7@yahoogroups.com, "mike" <curiousproductions@r...> > > wrote: > > > > > I am wondering if there is a fix for this "bug" that I don't > > > rember > > > > > hearing about. When sequencing external synths moving past the > > > > > > track > > > > > the sustained notes get cut off. I can select the track but > > then > > > > > when I select another track the notes being held release. This > > > > > is > > > > a > > > > > pretty big problem for me as I almost only use external sounds. > > > > > > > > > > Help! > > > > > > > > > > Mike G > > > > > > > > one thing to try is to switch the note destingation for that > > > channel > > > > to both rather than int and then turn down the volume knob on the > > > > > xl7 > > > > and see if that make a difference. > > > > > > > > I don't know if it is the same problem but when controlling my > > Boss > > > > SP-202 with my XL-7 I noticed that it wouldn't always trigger > > it. > > > it > > > > was weird sometimes it would and sometimes it wouldn't but I > > > couldn't > > > > figure out what the difference is when it works and not. with > > the > > > > destination set to both it triggers it fine. I haven't noticed
> > it > > > > with any other external gear. > > > > > > > > ------------------------ Yahoo! Groups Sponsor > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > __________________________________ > Do you Yahoo!? > SBC Yahoo! - Internet access at a great low price. > http://promo.yahoo.com/sbc/
