Thanks for the confirmation. I found the passsage in the manual
earlier. That's one of the "workarounds" I thought of, too: a single
control track with up to 16 channels of patch changes or other data
[pan, volume, other CC, etc.] specifically for the external gear.
Using both MultiA and MultiB and two sequencer tracks, you should be
able to set up controls for up to 32 external channels. To me, this
is a nice feature, not just a workaround.
Another option is to double the track and make it ext. However, this
wastes a track and memory.
> This is also why "both" tracks don't send externally, because
> otherwise, you wouldn't be able to use this workaround.
I love this--best reason to not have something!!!!!
--Steve
--- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
> Steve is correct. When a track is set to "both", program changes on
> the track will only be sent internally. This is because, in a
> standard MIDI file, there's no notion of "port" so you couldn't
> have one PC for the internal synth and one PC for the external
> device. Since you can't have separate ones, and it wouldn't be
> useful to send the *same* program change internally as externally,
> we only send internal.
> What you *can* do, however, is set up an "ext" "MultiA" (or B) track
> and place *all* your external program changes on it. This is also
> why "both" tracks don't send externally, because otherwise, you
> -Aaron
> --- ufound12 <ufound12@y...> wrote:
> > Steve,
> > I read that and agree 100%. That design idea baffles me. That is
why
> > I posted my message to the experts here in the group. I am hoping
to
> > get some brilliant work around for it.
> > Joe
> > --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
> > wrote:
> > > I am just starting to tackle the sequencer, so someone with
more
> > > experience please correct me or please confirm. I thought I
read
> > > somewhere that the E-Mu sequncer doesn't send out patch change
> > > commands externally when the destination is set to both.
> > > Again, I am not sure of this.
> __________________________________
> Do you Yahoo!?
> Yahoo! Domains Claim yours for only $14.70/year
> http://smallbusiness.promotions.yahoo.com/offer
