rEalm's Emulator X Review
2004-05-26 by erik_magrini@Baxter.com
Emulator X is available in standalone and VST versions.  For the purposes
of this review, I will be focusing on the standalone version.  Sadly,
there's no way to resize the onscreen image, and some of the controls are
sorta small.  At the bottom of the window is a read out of the current CPU
and Disk activity, the size of the current preset, and the Preset name and
channel.
The main Emulator X window is divided into two panes, similar to Windows
Explorer.  The left side serving mainly as a file overview/browser of the
contents of the sampler "memory", hard drives, and your Emu Sound Library.
 You can scan your PC to add new Emu sample banks to the Library, so it's
a nice way to organize things.  This pane also has a view filter, that
allows you to filter which presets are shown by categories or name. Then
you just drag and drop your sample of choice on to the Emulator tab at the
top of the screen.  It's a very intuitive and fast way of working in use,
though it's not possible to hide this pane once you'e made your choice.
The right side is dedicated to the sampler controls themselves.  You
switch between the 4 pages that make up the interface by selecting them on
the right hand pane (main preset overview, voices and zones, links, and
voice processing).  Again, very easy to use, and intuitive.  The main
sampler window also has a mini piano for playing the sampler if you don't
have a midi keyboard connected.  I do wish the keys showed which MIDI
notes it was receiving though, that's always a handy trouble shooting
feature, and I would think it would be especially important in a sampler.
The main sampler overview window contains the Preset Patchcords and 4
modulators, the 16 initial controller amounts with user defineable labels
(I assume for controllers with scribble strips?), and the master volume
and tuning controls.
The voices and zones view is where you do all of you keymapping and
setting up velocity and key crossfades.  You double click on a sample name
to open the sample editor itself, where you can trim and loop your
samples.  The voices and zones view reminds me of Kontakt in a way, in
that you have your multisamples stacked vertically, and you click on a
small button to expand them and see your samples.  Be nice if you could
zoom in vertically in this view, as a lot of screen space is wasted if you
only have a few samples, and the piano shown up top to use as a guide
while mapping samples is a tad small.
The Links view is where you can link multiple presets into one
uber-preset.  Anyone familiar with Emu hardware synths and samplers will
undoubtable know about this feature.  It functions exactly the same and
merely lets you have other presets play at the same time as the current
one.
The Voice Processing view is where the real fun begins though.  Here is
whre all of the synthesis parameters are located.  Again, this is the same
Emu architecture that has been used in their synths and samplers for
years, it's just laid out nicely on screen.  You can edit all of the
Preset voices at once, or just chose individual voices to edit.  You get 2
LFO's, 1 Filter with 55 types, 36 Patchcords per layer, an amplifier
section, tuning and transpose (oddly these don't work in real time, but
only at note on), chorus, and 3 envelopes (Pitch, filter, and aux).  The
filter section in particular is soooo cool. For those of you familiar with
Emu's past filters (these are identical), you know that they are complex
morphing filters, capable of all sorts of weirdness. In the EMu X, you can
actually see the shape of the filter curve morph as you tweak the cutoff
and resonance dials (they look like sideways pitchbend knobs).  That's
nice as it's easy to change them with your mouse by dragging in a straight
line.  Too bad the rest of the controls require circular mouse movements,
I wish there was a preference setting to change this to a linear mode,
it's much easier to control.  Anyway, this section is guaranteed to keep
you hypnotized for a good while.
This view is where I imagine most people will spend their time, and it's
laid out very well.  Too bad this couldn't be backward compatible and
function as an editor for the Proteus 2000 series, as it's exactly what so
many people have been asking for.  But I digress...
This sampler is very easy to use, on par with HALion if not easier.
Definitely easy to manage a project in this one, the left hand view is
always there as an overview and a way to get new sounds fast.  As a sound
design tool, if you know the EMu hardware Proteus synths, this will be all
familiar and very welcome, all these parameters are typically hidden
behind a small 2 bar LCD!  It doesn't have the weirdness that Kontakt has,
but it's much easier to use IMO, yet still has a lot of mangling options
now that the Proteus synth parameters are now finally easily accessible.
The sounds that come with it are varied and sound good to me.  The Studio
Grand Piano Bank is so so, sounds kinda light to me, not much weight to
it.  I still prefer Steinberg's THe Grand in that regard, but this is a
personal preference.  The Emu piano would probably sit in a mix
unprocessed much easier than The Grand.  The rest of the sounds were
typical Proteaus quality, which is to say good.
My wishlist is fairly short for this one:
- Linear mouse movement option for the knobs.
- Templates with the Emu X synth parameters already mapped to the same
CC's that the Command Stations and Proteus synths current transmit by
default.  This one seems obvious to me, kinda surprised it wasn't
included, unless I missed something.
- Maybe a bigger version for people with higher screen resolutions?  It's
a stretch, I admit it.
I'll keep playing with this one, and post as I get more aquainted with it.
 This is all from only a couple hours spent with the Emu X so far, first
impressions so to speak.  Didn't even crack the manual, so it's easy to
use.
Peace and Beats,
rEalm
http://www.soundclick.com/innerportal
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of, or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
Re: [xl7] Re: rEalm's Emulator X Review
I'll add more after the weekend, so if you have any questions, wait til
Tuesday as I won't be around email until then after this afternoon.
rEalm
mike <curiousproductions@...>
05/26/2004 09:45 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: rEalm's Emulator X Review
Great post rEalm.  I for one appreciate it.
Mike G.
Yahoo! Groups Links
use of , or taking of any action in reliance upon, this information by
For Translation:
2004-05-26 by mike
Sall good rEalm I am not going to be picking that one up any time
soon I have been having way to much fun messing with reaktor with the
xl as a controller !
Peace
til
> rEalm
> mike <curiousproductions@r...>
> 05/26/2004 09:45 AM
>         cc:
> Mike G.
entity
legally
than
privilege
other
by
> For Translation:
