More for Heinrich
More for Heinrich
2002-01-23 by erik_magrini@Baxter.com
Heinrich, don't worry mate we're getting there! It can be frustrating I know, but this is just the way iot is sometimes when working on electronic music, especially when you bring a computer into the picture. If nothing else, think how much you're learning! Ummm, ok that was lame I'll admit it. :)
So, to help me narrow this down, I guess I need to understand what you're doing a bit more. We know WHAT the problem is now, we just need to figure out how it's happening. Are you writing the patterns in Cakewalk (which version BTW) and then savin the patterns as SMF"s to be loaded via E-loader into the MP-7? Or are you writing the parts in the MP-7 and then having problems once you get it in Cakewalk? Consider me dense (shouldn't be too hard) and walk me through your process of writing.
Thanx, just trying to understand completely what you're doing,
rEalm
So I checked the bars where notes are missing and found that notes that usually have the same position in
the bar, have moved to a different position in the bar with the "missing" notes. Instead of - say - 14/1/32 - 14/2/32 - 14/3/32 - 14/4/32 they went: 14/1/32 - 14/2/32 - 14/2/232 - 14/2/238 - I moved them to the right
position to see if it works - it does! But the velocity still was very low and I had to fix that as well.
Final point: Cakewalk played back fine while recording on the mp-7, but the recorded results are moved notes with changed velocity in some bars, but sometimes just as well missing notes.One hint: Before I recorded the pattern I actually copied a formerly recorded pattern to an empty pattern, just to have the settings, then cut track 1 to clipboard to delete it, then record a new pattern on track one. Is it possible that some information (except the settings sure enough) still remains on the track when cutting it to clipboard? Could these bits and pieces disturb the newly recorded track?
Sorry for the long posting. Maybe somebody knows whats going on here.
I am so tired with all this fixing and asking. I can´t make music
like that. I´m close to moving over to a simple machine thats working
at least for me.
Any suggestions are welccome.
Re: More for Heinrich
2002-01-23 by heinrich22001
Erik,
seems you´re my personal mp-7-consultant! Thanx again.
Okay, this is what I do:
I have some drum patterns I once recorded directly from an old yammie-
PSR-Keyboard to - I think cubase light - via midiman. I saved the
patterns as *.mid files on my computer.
Some of the patterns are quite good, have at least a bit of human
feel. I play back the files now with a cakewalk sonar demo version I
recently took from a covermount-CD-ROM. I use this program because it
gives me the opportunity to switch off resets of program changes so I
can filter this data out.
My computer is linked via the midman sport 2x2 to the mp-7. I play
back the pattern on my computer and record parts of it directly to
the mp-7. Cakewalk runs the pattern on Channel 9 and 10. I use
realtime record on the mp-7 and record to track 1. I want to build up
a drum pattern database apart from whats to be found in the presets.
(Later I split the patterns according to voices and record them to
track 1 (kick), 2 (snare).... to 8 (alt. percussion). Then you can
mute/unmute to your likes and play variations by that. Sounds
terrible, I know, but this is a way to have a little more human feel
in the drum section. The user arp section I wanted to use fully for
Percussion licks and program some afro cuban rhythms (I have the
rhythm sheets from my conga teacher), then tweak the hell out of it.
Should go nicely with basic r&b and hiphop beats. Yes, you can
sample, but then again its not my own stuff.)
This is basically what I do right now with the mp-7. Its a bit off
the road but - well - why not?
Unfortunately they didnot integrate the audition riffs in the command
stations for further use. (I´m a bit Yammie-spoiled) And, pity, thers
no way how to grid record rhythm arps instead of programming them the
hard way.
Best regards
Heinrich
frustrating I
electronic
nothing
admit
> it. :)
you're
figure
(which
and then
(shouldn't
> rEalm
that
the "missing"
they went:
right
very low
but
bars,
recorded the
pattern,
it,
track
here.
working
> at least for me.
Re: [xl7] Re: More for Heinrich
I saved the patterns as *.mid files on my computer.Some of the patterns
are quite good, have at least a bit of human feel. I play back the files
now with a cakewalk sonar demo version I recently took from a
overmount-CD-ROM.  My computer is linked via the midman sport 2x2 to the
mp-7. I play back the pattern on my computer and record parts of it
directly to the mp-7.
>>>Why not save the MIDI pattrn as a ".mid" file in Sonar, and then use
E-Loader to transfer into your MP-7?  That would be far easier and way
more accurate than realtime recording it into the MP-7! Also, did you turn
off Rechannelize MIDI before recording?<<<
(Later I split the patterns according to voices and record them to track 1
(kick), 2 (snare).... to 8 (alt. percussion). Then you can mute/unmute to
your likes and play variations by that. Sounds terrible, I know, but this
is a way to have a little more human feel in the drum section.
>>>Again why not split the channels in Sonar, save the mid file and E-Load
it into the MP-7?  You're making yourself do unneccesary steps currently.
This is basically what I do right now with the mp-7. Its a bit off the
>>>Hey, to each his own!  If we all did the same way, there'd be a million
Walter (er...Wendy) Carlos's running around right now! <<<
Hi, Eric,
you´re definitely right!
The only reason I do not use the E-loader is: I bought the mp-7, got
the box without E-Loader of the Emu sales rep in Germany and I am
waiting for the new box to arrive with CD-ROM and stuff - since five
or six weeks by now!!!
Download? - At the moment I am using a very old laptop without
internet facilities at home for sequencing. I am waiting for my newer
laptop to be fixed but the retailer went broke and refuses to send it
back. Shall I ask some repo-man???
The Posting I do at work (if I find the time).
Still: Any ideas about these missing notes? Maybe this thing is just
obsolete when my mp-7 finally arrives. So I keep waiting. Is E-loader
running okay? I read about some people havin difficulties installing
it.
Thank you for answering
HEinrich
patterns
files
to the
use
way
you turn
track 1
mute/unmute to
but this
E-Load
currently.
million
I had some troubles initially with E-Loader, but once I installed the Sun
Java instead of the Microsoft Java Environment, all is well.
rEalm
(Hmmm, maybe I should have told you to go read the FAQ now that we have
one huh?)  :)
Is E-loader running okay? I read about some people havin difficulties
installing it.
