Re: [xl7] Emu X: User Definable Filters
2004-06-01 by erik_magrini@Baxter.com
This sounds like something I'd enjoy, esp. if you can do new cool things with CCs. If you explore this, please let me know. For example, are there new patch cord controls (sources/destinations)? >>>Yes and no. There's an easier way to access Preset Lag functions, but in terms of the usual layer cords, I think they are all the same, though a few have been renamed slightly if I remember correctly. It's all in the manual, which you can DL from the Emu site. <<< Also, does the documentation included sysex documentation? >>NO sysex. <<< Among other things, I'd be interested in the chart of filter types. >>>Sorry for the formatting! Filter Name Order Type Description 2-pole Lowpass 02 LPF Typical OB type low-pass filter with a shallow 12 dB/octave slope. 4-pole Lowpass 04 LPF 4-pole low-pass filter, the standard filter on classic analog synths. 24 dB/octave rolloff. 6-pole Lowpass 06 LPF 6-pole low-pass filter which has a steeper slope than a 4-pole low-pass filter. 36 dB/octave rolloff! 2-pole Highpass 02 HPF 2-pole high-pass filter. 12 dB/octave slope. 4-pole Highpass 04 HPF Classic 4-pole high-pass filter. Cutoff sweep progressively cuts 4th Order High-pass. 2-pole Bandpass 02 BPF Band-pass filter with 6 dB/octave rolloff on either side of the passband and Q control. 4-pole Bandpass 04 BPF Band-pass filter with 12 dB/octave rolloff on either side of the passband and Q control. Contrary Band pass 06 BPF A novel band-pass filter where the frequency peaks and dips midway in the frequency range. SweptEQ 1 octave 06 EQ+ Parametric filter with 24 dB of boost or cut and a one octave bandwidth. Swept EQ 2->1 octave 06 EQ+ Parametric filter with 24 dB of boost or cut. The bandwidth of the filter is two octaves wide at the low end of the audio spectrum, gradually changing to one octave wide at the upper end. Swept EQ 3->1octave 06 EQ+ Parametric filter with 24 dB of boost or cut. The bandwidth of the filter is three octaves wide at the low end of the audio spectrum, gradually changing to one octave wide at the upper end. Phaser 1 06 PHA Recreates a comb filter effect typical of phase shifters. Frequency moves position of notches. Q varies the depth of the notches. Phaser 2 06 PHA Comb filter with slightly different notch frequency moving the frequency of notches. Q varies the depth of the notches. FlangerLite 06 FLG Contains three notches. Frequency moves frequency and spacing of notches. Q increases flanging depth. Vocal Aah-Ay-Eeh 06 VOW Vowel formant filter which sweeps from "Ah" sound, through "Ay" sound to "Ee" sound at maximum frequency setting. Q varies the apparent size of the mouth cavity. Vocal Ooh-Aah 06 VOW Vowel formant filter which sweeps from "Oo" sound, through "Oh" sound to "Ah" sound at maximum frequency setting. Q varies the apparent size of mouth cavity. Dual EQ Morph 06 PROG Please refer to the detailed description on page 79. Dual EQ + Lowpass Morph 06 PROG Please refer to the detailed description on page 81. Dual EQ Morph + Expression 06 PROG Please refer to the detailed description on page 80. Peak/Shelf Morph 06 PROG Please refer to the detailed description on page 81. Ace of Bass 12 EQ+ Bass-boost to bass-cut morph MegaSweepz 12 LPF "Loud" LPF with a hard Q. Tweeters beware! EarlyRizer 12 LPF Classic analog sweeping with hot Q and Low-end. Millennium 12 LPF Aggressive low-pass filter. Q gives you a variety of spiky tonal peaks. MeatyGizmo 12 REZ Filter inverts at mid-Q. KlubKlassik 12 LPF Responsive low-pass filter sweep with a wide spectrum of Q sounds BassBox-303 12 LPF Pumped up lows with TB-like squelchy Q factor. FuzziFace 12 DST Nasty clipped distortion. Q functions as mid-frequency tone control. DeadRinger 12 REZ Permanent "Ringy" Q response. Many Q variations. TB-OrNot-TB 12 EQ+ Great Bassline "Processor." Ooh-To-Eee 12 VOW Oooh to Eeee formant morph. BolandBass 12 EQ+ Constant bass boost with mid-tone Q control. MultiQVox 12 VOW Multi-Formant, Map Q To velocity. TalkingHedz 12 VOW "Oui" morphing filter. Q adds peaks. ZoomPeaks 12 REZ High resonance nasal filter. DJAlkaline 12 EQ+ Band accentuating filter, Q shifts "ring" frequency. BassTracer 12 EQ+ Low Q boosts bass. Try sawtooth or square waveform with Q set to 115. RogueHertz 12 EQ+ Bass with mid-range boost and smooth Q. Sweep cutoff with Q at 127. RazorBlades 12 EQ- Cuts a series of frequency bands. Q selects different bands. RadioCraze 12 EQ- Band limited for a cheap radio-like EQ Eeh-To-Aah 12 VOW "E" to "Ah" formant movement. Q accentuates "peakiness." UbuOrator 12 VOW Aah-Uuh vowel with no Q. Raise Q for throaty vocals. DeepBouche 12 VOW French vowels! "Ou-Est" vowel at low Q. FreakShifta 12 PHA Phasey movement. Try major 6 interval and maximum Q. CruzPusher 12 PHA Accentuates harmonics at high Q. Try with a sawtooth LFO. AngelzHairz 12 FLG Smooth sweep flanger. Good with vox waves. e.g. I094, Q =60 DreamWeava 12 FLG Directional Flanger. Poles shift down at low Q and up at high Q. AcidRavage 12 REZ Great analog Q response. Wide tonal range. Try with a sawtooth LFO. BassOMatic 12 REZ Low boost for basslines. Q goes to distortion at the maximum level. LucifersQ 12 REZ Violent mid Q filter! Take care with Q values 40-90. ToothComb 12 REZ Highly resonant harmonic peaks shift in unison. Try mid Q. EarBender 12 WAH Midway between wah & vowel. Strong mid-boost. Nasty at high Q settings. KlangKling 12 SFX Ringing Flange filter. Q "tunes" the ring frequency. Programmable Morphing Filters There are four user-programmable morphing filters which have the ability to change their response over time. Now you can design your own custom filters that morph between filter types. Take the time to learn about these powerful filters because they are extremely useful and sound great. The frequency response graphs are especially helpful to understand the action of these complex filters since the control functions are slightly different for each filter. Dual EQ Morph This is a programmable 2-frame Morphing filter with two EQ sections. As the Morph value is increased, the filter interpolates from the low to high settings. The Gain of each section remains constant during the Morph, but can be scaled at note-on time by controlling the Initial Gain parameter. This filter can be used to create your own vocal formant filters. (Try the settings shown and modulate with the + filter envelope or +LFO.) Frequency Amplitude Morph Low EQ 1 High EQ 1 High EQ rEalm The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of , or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
