Preset users
2004-07-05 by Whoïo
2004-07-05 by Whoïo
Hi!! I would like to know if someone has already created an "empty bank user" sysex files??? I would like to replace all the users presets with a blank preset, and I don't want to do copy/paste with 3x127 presets... THX Enhmy
2004-07-06 by erik_magrini@Baxter.com
Yes, there is a blank Preset Bank in the files section of this group that
you can use for this. Load this into the XL-7, and then use the Copy Bank
command from the Save menu to copy it to your other User Banks.
rEalm
"Whoïo" <enhmy@...>
07/05/2004 03:09 PM
Please respond to xl7
To: xl7@yahoogroups.com
cc: Subject: [xl7] Preset users Hi!! I would like to know if someone has already created an "empty bank user" sysex files??? I would like to replace all the users presets with a blank preset, and I don't want to do copy/paste with 3x127 presets... THX Enhmy Yahoo! Groups Links The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of , or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
2004-07-06 by gonzinigonz
Hi, so you can over write the original emu patch banks, is that correct? Also is it possible to completey edit the drum kits in there, ie start from scratch and create your own with what ever samples are present on the roms you have installed? Still waiting on my XL-7 to turn up... Regards Gonz --- In xl7@yahoogroups.com, erik_magrini@B... wrote: > Yes, there is a blank Preset Bank in the files section of this group that > you can use for this. Load this into the XL-7, and then use the Copy Bank > command from the Save menu to copy it to your other User Banks. > > rEalm > > > > > > "Whoïo" <enhmy@y...> > 07/05/2004 03:09 PM > Please respond to xl7 > > > To: xl7@yahoogroups.com > cc: > Subject: [xl7] Preset users > > > Hi!! > > I would like to know if someone has already created an "empty bank user" > sysex files??? I would like to replace all the users presets with a blank > preset, > and I don't want to do copy/paste with 3x127 presets... THX > > Enhmy > > > > > > Yahoo! Groups Links > > > > > > > > > > > The information transmitted is intended only for the person(s)or entity > to which it is addressed and may contain confidential and/or legally > privileged material. Delivery of this message to any person other than > the intended recipient(s) is not intended in any way to waive privilege > or confidentiality. Any review, retransmission, dissemination or other > use of , or taking of any action in reliance upon, this information by
> entities other than the intended recipient is prohibited. If you > receive this in error, please contact the sender and delete the > material from any computer. > > For Translation: > > http://www.baxter.com/email_disclaimer > > > [Non-text portions of this message have been removed]
Hi, so you can over write the original emu patch banks, is that correct? >>>Yes and no. The Factory Preset Banks that come with each ROM cannot be overwritten, but they are also copied to the User Banks when you buy a new Command Station. It's the Presets that have been copied to the User banks that can be overwritten. <<< Also is it possible to completey edit the drum kits in there, ie start from scratch and create your own with what ever samples are present on the roms you have installed? >>>Not directly no, you're stuck with whatever is assigned in each Preset to some extent. Each Preset (including Drum Presets) are made up of 4 layers. You can mix and match layers (the Protean Drum ROM is excellent for this BTW), and transpose each layer too, in addition to being able to layer up to 3 Presets at once. This basically gives you 12 layers to use in making up your own kits. If you're just waiting for your XL-7 to arrive, mioght not hurt to DL the manual and start reading so you can be up to speed when it arrives :) MIght want to get the FAQ and Tips and Tricks docs too from the files section of this group. <<< rEalm The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
2004-07-07 by gonzinigonz
Ok thanks for that, think it will make more sense when i can see it in front of me.. Ive flicked through the PDF of the manual to see what it can do.. Find it a bit hard to read it off the screen, better with a real manual for me. Maybe l'll have another go with it. Cheers for your responce, i think ive had a look at the tips and tricks and FAQ's.. Regards Gonz --- In xl7@yahoogroups.com, erik_magrini@B... wrote: > Hi, so you can over write the original emu patch banks, is that correct? > > >>>Yes and no. The Factory Preset Banks that come with each ROM cannot be > overwritten, but they are also copied to the User Banks when you buy a new > Command Station. It's the Presets that have been copied to the User banks > that can be overwritten. <<< > > Also is it possible to completey edit the drum kits in there, ie start > from scratch and create your own with what ever samples are present on the > roms you have installed? > > >>>Not directly no, you're stuck with whatever is assigned in each Preset > to some extent. Each Preset (including Drum Presets) are made up of 4 > layers. You can mix and match layers (the Protean Drum ROM is excellent > for this BTW), and transpose each layer too, in addition to being able to > layer up to 3 Presets at once. This basically gives you 12 layers to use > in making up your own kits. If you're just waiting for your XL-7 to > arrive, mioght not hurt to DL the manual and start reading so you can be > up to speed when it arrives :) MIght want to get the FAQ and Tips and > Tricks docs too from the files section of this group. <<< > > rEalm > > > > > > > > > > > The information transmitted is intended only for the person(s)or entity > to which it is addressed and may contain confidential and/or legally > privileged material. Delivery of this message to any person other than > the intended recipient(s) is not intended in any way to waive privilege > or confidentiality. Any review, retransmission, dissemination or other > use of, or taking of any action in reliance upon, this information by
2004-07-07 by Whoïo
Thank you rEalm, I am going to try this tonight.. If it's work, I will venerate you :) Cheers Enhmy --- In xl7@yahoogroups.com, erik_magrini@B... wrote: > Yes, there is a blank Preset Bank in the files section of this group that= > you can use for this. Load this into the XL-7, and then use the Copy Ban= k
> command from the Save menu to copy it to your other User Banks. > > rEalm > > > > > > "Whoïo" <enhmy@y...> > 07/05/2004 03:09 PM > Please respond to xl7 > > > To: xl7@yahoogroups.com > cc: > Subject: [xl7] Preset users > > > Hi!! > > I would like to know if someone has already created an "empty bank user" = > sysex files??? I would like to replace all the users presets with a blank= > preset, > and I don't want to do copy/paste with 3x127 presets... THX > > Enhmy > > > > > > Yahoo! Groups Links > > > > > > > > > > > The information transmitted is intended only for the person(s)or entity > to which it is addressed and may contain confidential and/or legally > privileged material. Delivery of this message to any person other than > the intended recipient(s) is not intended in any way to waive privilege > or confidentiality. Any review, retransmission, dissemination or other > use of , or taking of any action in reliance upon, this information by > entities other than the intended recipient is prohibited. If you > receive this in error, please contact the sender and delete the > material from any computer. > > For Translation: > > http://www.baxter.com/email_disclaimer > > > [Non-text portions of this message have been removed]
