Subject: Re: [xl7] Saving Patchs w/ Patterns
Erik's right. Another thing to note if it's not remembering *which*
preset a track uses (not just the changes you made to a preset) is that
you have to have something on a track for it to save vol, pan, preset,
etc.
That being said, here's a trick for all you folks who want to tweak
custom presets without saving them to a new location. If your edits
are just via the quick edit knobs, just record them at tick 0 in the
step editor. For example, if you like a pad, but it needs to have a
little bit shorter attack, simply enter step edit mode, tweak knob E
till it sounds right, then save the pattern. Know, when you play that
pattern, MIDI E will get played once at the first loop before any
notes, and your preset will have the longer attack.
-Aaron
--- erik_magrini@... wrote:
> Patterns and Presets are completely seperate entities. You have to
> save any Patterns you create to the User Pattern locations, and the
> same goes for any Presets you create. The Pattern doesn't actaully
> save the Preset data, it just saves the location of the preset that
> was used in the Pattern.
> fusioncm2000 <fusioncm@...>
> Subject: [xl7] Saving Patchs w/ Patterns
> Hey guys, newbie question here. I have been creating my own patterns
> and saving them with the xl7. I have been having a problem though
> when I turn off the xl7. When I turn it back on, all of the patches
> that I have set up for the individual tracks for my pattersn are
> changed to some default set up.
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
http://promotions.yahoo.com/new_mail
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
