older O/S (v1.32) download?
2004-08-31 by gonzinigonz
Hi
Im lookinmg for a site were i might be able to download the older
v1.32 operating system for the command station.
Cant find it here or on the other yahoo groups..
Maybe someone has it sitting on there hardrive as well?
Emu dosent have it either (from the site)
Gonz
Re: [xl7] older O/S (v1.32) download?
2004-08-31 by BEAUFILS Adrien
I will try to send you the two files given with my xl7 but i don't think that you want. Personnaly I'm still using O/S (v1.31) cause i havent got the good midi interface on my pc.
gonzinigonz <gonzini@...> wrote: Hi
Gonz
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/xl7/
Créez gratuitement votre Yahoo! Mail avec 100 Mo de stockage !
Créez votre Yahoo! Mail
Le nouveau Yahoo! Messenger est arrivé ! Découvrez toutes les nouveautés pour dialoguer instantanément avec vos amis.Téléchargez GRATUITEMENT ici !
2004-08-31 by [cYcLoThYmIqUe]
ftp://Emuserv:s37at5@.../
Check out the Command Stations folder.
gonzinigonz a \ufffdcrit :
> v1.32 operating system for the command station. Cant find it here or
> on the other yahoo groups.. Maybe someone has it sitting on there
> hardrive as well? Emu dosent have it either (from the site) Regards
> Gonz
Sebastien,
One way to better your lot is to do a lot better...
Re: older O/S (v1.32) download?
Cheers Sebastien
Gonz
--- In xl7@yahoogroups.com, "[cYcLoThYmIqUe]" <poumtschak@f...> wrote:
> ftp://Emuserv:s37at5@f.../
or
> > Gonz
> Sebastien,
Re: [xl7] Re: older O/S (v1.32) download?
2004-08-31 by Aaron Eppolito
Careful, I think the older OS's might blow away your user data if you
downgrade.  Why do you want to run the older OS anyway?  It's less
stable and has less features.
-Aaron
> > > or on the other yahoo groups.. Maybe someone has it sitting on
> > > there hardrive as well? Emu dosent have it either (from the site)
_______________________________
Do you Yahoo!?
Express yourself with Y! Messenger! Free. Download now.
http://messenger.yahoo.com
2004-09-01 by erik_magrini@Baxter.com
Why do you want an older OS?  There's no reason at all to downgrade to an
older OS for the XX-7's.  Well, except that beta version with realtime Q
enabled, but you won't find that :)
rEalm
08/31/2004 10:23 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] older O/S (v1.32) download?
Hi
Gonz
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
2004-09-01 by gonzinigonz
Hi
>you downgrade.
Not worried about that @ present, im trying to sort out a few probs
im having..
Wanted to see if the probs were O/S related or i have a hardware
problem.
I have 2 probs @ moment.
1 - Voice stealing (?) Having reloaded all factory data i notice that
some factory patterns also suffer with pops, clicks and notes cut on
my unit. I havn't been through many yet but i will look deeper into
it.
2 - I noticed that if i have all 16 channels volumes set to 000 via
the MIX screen, then reduce or come up from min on the main volume
control i will get clicks and pops and even parts of sounds @ full
volume as i go through the first 8th turn of the knob. They die away
past this point.
If i set all the channels to 001 the problem goes away! Back to 000
problem returns. seems to be sounds with longer realse times / held
notes.
This would be an issue if i wanted to fade in a mix while the seq was
running with some channels volume set @ 000. If i mute this also
corrects the problem.
There also appears to be some zipper noise around this area.
O/S 1.32 does it as well.
Hardware problem??
Gonz
older
here
site)
> Do you Yahoo!?
Wish I had it in the E-Mu.  (And if I had known it was deliberately
disabled, I might not have spent so much time trying to figure out what I
was doing wrong.)
>>>Yes, res is only calculated at Note On. <<<
I imagine in the wrong hands realtime control over resonance with filters
such as EaryRizer could pop an E-Mu into oblivion--either that or it would
enable presets that would be way too amazing for audience comprehension.
Any idea why it was disabled?
>>>Baically because the engineers at Emu felt that it didn't sound as
smooth as they'd like, and gave unpredicatble results with some of the
esoteric filters.  I argued long and hard that more options (no matter how
they sound) are always a better thing when it comes to sound design, but
to no avail.  It was felt that people would not be able to get over the
fact that the resonance didn't behave like on other gear in some
instances, and thus would be a cause for complaint.  Personally, I never
noticed any of the above, at least not in a way that I thought was
negative. <<<
rEalm
For Translation:
It ok now ive found it :o)
Thanks anyway
Gonz
--- In xl7@yahoogroups.com, BEAUFILS Adrien <fatalojyxvsfacial@y...>
> gonzinigonz <gonzini@f...> wrote: Hi
> Regards
> Gonz
Service.
GRATUITEMENT ici !
2004-09-06 by PLASTICEFX@aol.com
In a message dated 8/31/04 2:02:45 PM, synthesis77@... writes:
<< Careful, I think the older OS's might blow away your user data if you
-Aaron >>
gear junkies too lazy to fuck w/the new shits and love the "purity" of the
original OS's......
plastic  lol!!!!!
for minimalist eno filtered pad shits too!!!!!  shit...sometimes i think the
room's gonna explode w/wicked ass decay!!   brilliant!!!
