Sequencing trick tip !
2005-03-02 by Daim
Here's a neat fact . You can ( in song mode ) program any of the 32 tracks no matter what number or letter become ( trigger 1 ) . So for all you Drum & Bass heads that like doing filter sweeps with the bassline in a live performance situation, but put the bassline is on; say ( track 16B ). In the pattern edit menu there is a section where you can place witch ever track sound where ever. The only catch is you have to cut and paste the notes, from track 16 to track 1. <Now that I think about it ,there is a X function, on the 2.0 OS . I don't know if that will save you from the cut and paste aspect of it,but I will check that out.> Make sure you save the multi-set and save on the pattern, then when you go to (step record ) in song mode, and that nasty bassline drops on the 1 ( pun intended )you can go nob crazy with out flipping channels or totally reconstructing your patterns for realtime effects. If this makes no sence to you and ya want more info hit me back Daim ;-)
