Logic Start Stop
Logic Start Stop
2002-02-05 by fchieli
I'm using my XL-7 like a sound module a lot.
In this situation I've been trying to bypass the XL-7 sequencer without success:
I'd like to press start on my logic without starting the XL-7 sequencer.
The only way I've found so far is to disable 'Transmit Midi Clock' in Logic.
This way though I loose the time sync with other midi devices...
Is there a way to disable midi sync in the xl-7?
Thanks
Federico
Re: [xl7] Logic Start Stop
2002-02-05 by erik_magrini@Baxter.com
I do this same thing in Cubase.  The easiest way I've found so far, is to
take the XL-7 pattern you're trying to sequence from Logic, and save it to
a new location in the XL-7.  Now erase all of the note data on all tracks,
and resave the pattern (in that new location). That way the sequencer in
the XL-7 may start, but there's no additional notes being triggered by it,
and all your tempo based LFO's and envelopes will still sync correctly.
rEalm
success:
Logic.
Thanks
Federico
2002-02-05 by Lynn Bruington
i usually just put the emu on an empty pattern....
Sent: Tuesday, February 05, 2002 11:49 AM
Subject: [xl7] Logic Start Stop
Thanks
Federico
