mp-7 with usb device
2005-08-11 by soscary00
I tried to connect my E-MU MP-7 drum machine to my laptop using a
Edirol USB - Audio interface, but all my laptop picked up was a low
static.  I'm thinking that I need to send the MP-7 signal through a
stereo amplifier before it goes into the USB interface.  I wish I
didn;t have to use a stereo amp b/c I don't got the $ to buy one.  Do
you connect the drum machine to your laptops without using MIDI?  I
wish I could send the MP-7 signal to my laptop  through the HOST
connector that's on the back of the drum machine.
Re: [xl7] mp-7 with usb device
2005-08-11 by Bob S.
Levels out of the XX-7 are line levels and will so more than static on a
working input.  Have you used your Edirol inputs before...are they
configured ok?  And have you checked the output of the XX-7 and is the XX-7
volume pot turned up?
Bob
Corona/Riverside, CA
To: <xl7@yahoogroups.com>
Sent: Wednesday, August 10, 2005 11:22 PM
Subject: [xl7] mp-7 with usb device
Re: mp-7 with usb device
The Yamaha DJX works with the Edirol.  I connected the DJX to my
laptop using the Edirol, so I expected it to be the same with the MP-
7.  I know the MP-7 output works, b/c I connect headphones to the MP-
7 and I hear it.
static on a
the XX-7
> Bob
> From: "soscary00" <soscary00@y...>
low
through a
one.  Do
MIDI?  I
> > Yahoo! Groups Links
Re: [xl7] Re: mp-7 with usb device
Also, make sure you are using a TS (2 conductor) plug in the output of the
XX-7 it does not have balanced outs and the UA-25 (if you are using that
one) does.
Bob
Sent: Wednesday, August 10, 2005 11:44 PM
Subject: [xl7] Re: mp-7 with usb device
> 7 and I hear it.
> static on a
> the XX-7
> > Bob
> low
> through a
> one.  Do
> MIDI?  I
> > > Yahoo! Groups Links
2005-08-12 by soscary00
I use the UA-1X and I'm connecting the xx-7 to the ua-1x with a
2RCA - 2 1/4 in. cable.
output of the
using that
> one) does.
> Bob
the MP-
the MP-
> > 7 and I hear it.
> > static on a
they
and is
> > the XX-7
> > > Bob
using a
was a
> > low
> > through a
wish I
> > one.  Do
> > MIDI?  I
HOST
> > > > Yahoo! Groups Links
> > Yahoo! Groups Links
2005-08-12 by Bob S.
That should work !
Sent: Thursday, August 11, 2005 5:28 PM
> output of the
> using that
> > one) does.
> > Bob
> the MP-
> the MP-
> > > 7 and I hear it.
> > > static on a
> they
> and is
> > > the XX-7
> > > > Bob
> using a
> was a
> > > low
> > > through a
> wish I
> > > one.  Do
> > > MIDI?  I
> HOST
> > > > > Yahoo! Groups Links
> > > Yahoo! Groups Links
I wish it did, my brother.  Ooh I wish it did.  b/c I'd be JAMMIN!
> That should work !
> > output of the
> > using that
> > > one) does.
> > > Bob
to my
> > the MP-
> > the MP-
> > > > 7 and I hear it.
than
> > > > static on a
before...are
> > they
> > and is
> > > > the XX-7
> > > > > Bob
> > using a
> > was a
> > > > low
> > > > through a
I
> > wish I
buy
> > > > one.  Do
using
> > > > MIDI?  I
> > HOST
> > > > > > Yahoo! Groups Links
> > > > Yahoo! Groups Links
> > Yahoo! Groups Links
