Re: Searching for OS......
2005-08-31 by OutLaw1387@aol.com
My MP7 crashed repeated yesterday about 5-10 times..Just stalling.. Now it
sits at a screen on boot up that says "Searching of OS...." Is there anything I
 can do apart from sending it back to EPR? No other plugs are plugged  in
besides the power cable. Has this thing fried, died, and I should lay it  to the
side?
Thanks in Advance
RE: [xl7] Re: Searching for OS......
2005-08-31 by Daniel Jarvis
I am certainly nop expert on this...but it sounds like the OS is corrupted.
Searching for OS is what the machine says when you start it with the enter
button pressed down; perhaps that button is stuck in the down position.
Perhaps others with more knowledge can tell you if it would help to
reinstall the OS    best wishes for you and your machine; when they act up
it is a bother
Dan
Re: [xl7] Re: Searching for OS......
thank you, I greatly appreciate your time and effort..I'll check the enter
button and see if someone can give me the instructions for reinstalling to OS,
or whatever ideas may come along. At this point Im willing to try open heart
surgery, lol
2005-08-31 by Aaron Eppolito
Hook it up to E-loader and redownload the OS.  You might want to check
the internal connections too if you're familiar with electronics to
prevent future crashing...
-Aaron
> Now it
> anything I
>  in
> it  to the
> side?
> Thanks in Advance
> Life without art & music? Keep the arts alive today at Network for
> Good!
> http://us.click.yahoo.com/iuUuID/dnQLAA/n1hLAA/pWZylB/TM
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
Thanks. However it won't go past the loading OS screen to allow the os to  be
transferred back on. Any ideas as to what Im supposed to look for or do
internally? I'm familiar with internal working of gadgets but some direction or
instruction would surely be helpful.
2005-09-01 by Aaron Eppolito
It won't go past the loading screen till you hook it up to a PC or OS9
mac running eloader via bi-directional MIDI, select an OS to download,
and start downloading.  If you've already done this properly, let's
talk.  The E-Loader manual should detail how to set the connections up.
-Aaron
> os to  be
> do
> direction or
2005-09-01 by OutLaw1387@aol.com
Thanks but I have tried to this no avail.. The mp7 still sits at searching
for OS.. and since it will not move past this screen I can't reflash the OS. If
 I try to flash it while it sits at that screen I receive a midi
communications  error. A valid update request has not been received from the selected
device..
hold the phone ladies and gents.. Rebooting while holding enter may have
done the trick..Will let you know
not quite yet. Was able to reload the prep software and the s.00 software
and in the end the unit says Error! Code=001 Fatal: Bad Instruction..Thanks for
the help but I think this puppy needs a new flash  chip.
also get this error when attempting to reflash 2.00 OS without first  running
the prep software
Error Downloading
MIDI: Wrong Length.
2005-09-01 by Chris
have you tried the command prep in advance to installing OS 2.0?
no OS at all would be a version pre 1.17 in my opinion as well..
good luck
chris
From: xl7@yahoogroups.com [mailto:xl7@yahoogroups.com] On Behalf Of
OutLaw1387@...
Sent: Donnerstag, 1. September 2005 04:43
To: xl7@yahoogroups.com
Subject: Re: [xl7] Re: Searching for OS......
running
the prep software
Error Downloading
MIDI: Wrong Length.
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "xl7 <http://groups.yahoo.com/group/xl7> " on
the web.
*	 To unsubscribe from this group, send an email to:
<mailto:xl7-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
not quite yet. Was able to reload the prep software and the 2.00  software
for
the prep software
Error Downloading
MIDI: Wrong Length.
Yeah, sounds bad.  It's probably either the flash chip or memory chip,
or the connections to them.  I've heard of pins lifting off the pads
after time.  Maybe someone with QFP soldering chops could help you...
PS. I *wouldn't* run flash prep.  There are two "levels" of operating
system in the XL-7.  One is what's called a boot loader, the other is
the OS proper.  Flash prep updates the boot loader.  That thing is
responsible for finding an OS to run, either on flash, in memory, or
loading it via MIDI.  If you mess up the boot loader, you're hosed for
good (without reflashing from a ROM image).  If you mess up the OS,
there's always reloading.
-Aaron
> running
> the prep software
> Error Downloading
> MIDI: Wrong Length.
> Good!
Do You Yahoo!?
http://mail.yahoo.com
