presets
2005-10-14 by lifeistheformofenergy
is it possible to have multiple patterns applied to the same preset or does the preset have to be copied to a different location ?
2005-10-14 by bbbigup bbbigup
Yes it is possible. If you want exactly the same sound for all the pattern.
lifeistheformofenergy <lifeistheformofenergy@...> a écrit :is it possible to have multiple patterns applied to the same preset or
SPONSORED LINKS
Drum machines Electronic instrument Electronic drum machine Electronic music Electronic musical instrument Electronic instrument cases
YAHOO! GROUPS LINKS
Visit your group "xl7" on the web.
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez le ici !
[Non-text portions of this message have been removed]2005-10-15 by steve_the_composer
One thing that might help people get a handle on their E-Mu is the concept of POINTERS. It is a concept in computing, and remember-- electronic music gear are really just specialized computers One of the main functions of computers is to point. You the user have control over some pointers the E-Mu uses. You do not have control over other pointers. For example, consider the sound ROMs. They have digitized sound >>samples<<, but you do not have access to these directly. However, samples and multisamples are organized by the e-mu architecture to have pointers to >>ROM instruments<< in the EDIT PRESET functionality. When edit a preset and change a preset's instruments on layers 1->4, you are setting pointers to the ROMs table of contents (so to speak) which points to the digitized sound samples. Then, when you save the preset, let's call it My Sax 1.0, to User memory slot 025 in bank 3, you are setting a pointer to the cluster of parameters called a preset. NOW: When you create a sequence (pattern or song) you set pointers (in effect) to a table of contents which point to the preset parameters. If on Track 2 I want to use My Sax 1.0 on channel 5, I set a pointer that says to the sequencer: "Hey, on track 2, any notes played on channel 5 get played with the sound I am calling My Sax 1.0." SO: If you want, you can have 5 different channels on track 1, 3 different channels on track 7, and 16 different channels on track 9 all pointing to My Sax 1.0. ===================================== I hope the explanation of pointers helps. Once you figure out which ones you have control over and where they can point to, I think you will have a great deal of mastery over your gear. --Steve > is it possible to have multiple patterns applied to the same preset > or does the preset have to be copied to a different location ?
2005-10-16 by lifeistheformofenergy
Can they be at the same time though - if so - how many ? --- In xl7@yahoogroups.com, bbbigup bbbigup <bbbigup@y...> wrote: > > Yes it is possible. If you want exactly the same sound for all the pattern. > > lifeistheformofenergy <lifeistheformofenergy@y...> a écrit :is it possible to have multiple patterns applied to the same preset or > does the preset have to be copied to a different location ? > > > > > > SPONSORED LINKS > Drum machines Electronic instrument Electronic drum machine Electronic music Electronic musical instrument Electronic instrument cases > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "xl7" on the web. > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > > --------------------------------- > Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
> Téléchargez le ici ! > > [Non-text portions of this message have been removed] >
2005-10-16 by Bob S.
Until you run out of polyphony, based on the polyphony usage rules for the command station (in the manual). For example, a chorused voice uses twice the polyphony of a non-chorused voice, etc, etc., up to the polyphony count of 128 for the XX-7...... Some of our old posts delve specifically into effective polyphony..... Bob Corona/Riverside, CA
-----Original Message----- From: lifeistheformofenergy <lifeistheformofenergy@...> Sent: Oct 15, 2005 8:19 PM To: xl7@yahoogroups.com Subject: [xl7] Re: presets Can they be at the same time though - if so - how many ? --- In xl7@yahoogroups.com, bbbigup bbbigup <bbbigup@y...> wrote: > > Yes it is possible. If you want exactly the same sound for all the pattern. > > lifeistheformofenergy <lifeistheformofenergy@y...> a \ufffdcrit :is it possible to have multiple patterns applied to the same preset or > does the preset have to be copied to a different location ? > > > > > > SPONSORED LINKS > Drum machines Electronic instrument Electronic drum machine Electronic music Electronic musical instrument Electronic instrument cases > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "xl7" on the web. > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > > --------------------------------- > Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger > T\ufffdl\ufffdchargez le ici ! > > [Non-text portions of this message have been removed] > Yahoo! Groups Links
2005-10-16 by Mibrilane
On Oct 15, 2005, at 8:19 PM, lifeistheformofenergy wrote: > Can they be at the same time though - if so - how many ? Technically every sequencer track can have the same preset on it. However, one would have to start asking oneself: why the heck do I have the same preset on every sequencer track? ;D --- Mibrilane [Non-text portions of this message have been removed]
thanks - funny answer - I suppose I really should have specified : how many before problems are encountered or that the XX 7 gets slowed down (if so) ... we wouldn't want over loads now would we ... we need to make it back to the mother load ship - you just encountered an alien - welcome back to space - the truth is out there - doo doo doo doo duh do doo dooo ... thanks for tuning in to my brief version of X files ... tune in for some more techno - --- In xl7@yahoogroups.com, Mibrilane <mibrilane@c...> wrote: > > On Oct 15, 2005, at 8:19 PM, lifeistheformofenergy wrote: > > > Can they be at the same time though - if so - how many ? > > Technically every sequencer track can have the same preset on it. > However, one would have to start asking oneself: why the heck do I
> have the same preset on every sequencer track? ;D > > --- > Mibrilane > > > > > [Non-text portions of this message have been removed] >
