BOB
BOB
2006-01-16 by lifeistheformofenergy
well you seemed to have noticed what I was talking about but I don't
think that you got my reply - so  I will post it again : ok so when you
refer to an echo what
exactly does this mean ? it seems to me that you might be refering to
a given track outputing but also rechanellizing to another track and
then that track outputing to the original where as before I was only
talking about one initial track - is this the case ? I am not using
any external midi gear - I just want to stay in the XX7 and yet go
beyond it's parameters if so possible the thing is that there might
be some code embedded in the XX7 that actually prevents this sort of
thing from happening which is also what I am asking - what exactly gets
sent out and if rerouted what gets interpreted as actual effect during
imput - if other gear is used for effects - does it correctly interpret
the sysex or will it leave it only as note on or off ... how can a
rechannelized track be set up so  that it acts as though it is
continues or realtime and still keeps changing the effect
information ...
