midi echo is there a solution
Re: [xl7] midi echo is there a solution
2006-02-10 by Bob S.
Solution for what ?
What is it you ultimately want to achieve in terms of control or sound, leaving out how to do it ?
I had a lot of trouble interpreting what you wanted from all the wordy posts.
Use this form:
I want to be able to........
or
I want the mix to sound like......
Bob
>From: lifeistheformofenergy <lifeistheformofenergy@...>
>Sent: Feb 9, 2006 10:46 PM
>To: xl7@yahoogroups.com
>Subject: [xl7] midi echo is there a solution
>so.... if midi looping is not the solution is there one ...
>Yahoo! Groups Links
Re: midi echo is there a solution
2006-02-12 by steve_the_composer
--- In xl7@yahoogroups.com, "Bob S." <tttsystems@...> wrote:
> Solution for what ?
Here's the gist of the desired outcome as I understand it:
>>> I am trying to find out how to change parameters internally [to]
>>> allow for realtime adjustments that would keep adjusting the
>>> parameters even though the knobs only go as far as they do ...
Here's where I got that from (part 1 is from Aaron, part 2 is from
life itself) followed by some comments (part 3) that I hope either
(1) relate to the desired goal or (2) help someone else get more out
of their sequencer.
PART 1:
> My only attempt at deciphering the original  question is as
> follows.  I think he's asking if there's any way to internally
> loop the MIDI output of a track back into the track, possibly
> with some processing.  From a parameter or audio point of view that
> sort of makes sense (i.e. feeding back parameter changes can
> produce interesting effects and feeding back audio can yield
> filters,  flangers, and the like).  However, looping back MIDI
> isn't really  useful.
PART 2:
> YES YOU DECIPHERED COREECTLY  - I am trying to find out how to
> change parameters internally and I figured that looping it via
> midi track rechannelization back into the track might have been
> the resolution because the knob assignments only go so far ...
> and I thought that if the data was changed and then rechannelized
> back onto the track again it would allow for realtime adjustments
> that would keep adjusting the parameters even though the knobs
> so if this is case is it possible to do this in realtime or is it
> possible to do this all internally but not in realtime and how
PART 3:
The closest I came to doing something that resembles this (if I
understand it) is trying to use embedded sysex commands.  This
required the use of (in my case) Cakewalk software to create the
sysex command, embed it into a track, and create a SMF which I
loaded into my E-Mu sequencer using e-loader.
Using this method (as a test) I extended the use the knobs by
changing their settings (what the programmable knobs were set to)
with the embedded syex command.
I think I also tested the technique with changing ROM instruments in
a single patch.
I don't think this is what life...energy had in mind, but it is the
closest technique I have tried to extend the functionality of the
knobs.
I suppose life. . . energy might be able to use the technique to
change patchcord settings to achieve the desired outcome.
Let's say you have a 16-bar pattern using Preset User 005^2, and for
measures 1-4, the knobs function within a certain range based on
certain patchcord settings. You might be able to embed a sysex
command at the very end of measure 4 to change the patchcord
settings in measures 5-8 do different things or cover a different
range than in measures 1-4. etc. for measures 9-16.
I say "might" because I did not test this specific task. If anyone
wants me to do the groundwork and spell out step-by-step details of
how to do it (if it can be done), contact me off the list. If you
want to tackle it yourself, take a look in the Files section
(Controller Midi File:
Changes MidiA --> MidiE assignments via sysex embedded in pattern)
and the discussion in the archives (circa
http://launch.groups.yahoo.com/group/xl7/message/16542).
NOTE: If you try the sample *.mid file I posted, make sure you have
a multsetup saved with your current or desired controller settings.
The embedded sysex command will change your controller settings!!!!)
Hope this helps someone.
parameter solution
2006-02-13 by lifeistheformofenergy
- Nice Steve the Composer Nice - that seems as though that might
solve the dilema I was having ...
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...> wrote:
> --- In xl7@yahoogroups.com, "Bob S." <tttsystems@> wrote:
> > Solution for what ?
[to]
out
> of their sequencer.
> PART 1:
that
> PART 2:
> PART 3:
in
> a single patch.
> knobs.
for
