Digital Output
Digital Output
2006-02-15 by freakyfreq
Hello,
Is the sample rate 44.1 or 48k at the digital output and is the bit
depth 16 or 24?
I read in a post it was 20 bit. Can anyone verify this? The owners
manual doesn't say jack!
Thanks so much, Brandon
RE: [xl7] Digital Output
2006-02-15 by Carlisle, Stephen
The output should be 44.1, or 48KHz depending upon your choice in the
preferences.  I believe the bit depth is 24, unless you are playing the
sampled sounds pcm which are 16 bit.
I could be wrong though.
Z
	From: xl7@yahoogroups.com [mailto:xl7@yahoogroups.com] On Behalf
Of freakyfreq
	Sent: 15 February 2006 03:58
	To: xl7@yahoogroups.com
	Subject: [xl7] Digital Output
	Hello,
bit
	depth 16 or 24?
owners
	SPONSORED LINKS
Drum machines
<http://groups.yahoo.com/gads?t=ms&k=Drum+machines&w1=Drum+machines&w2=E
lectronic+instrument&w3=Electronic+drum+machine&w4=Electronic+music&w5=E
lectronic+musical+instrument&w6=Electronic+instrument+cases&c=6&s=165&.s
ig=6INNG8BkNyIc1GrzIms53Q>  	Electronic instrument
<http://groups.yahoo.com/gads?t=ms&k=Electronic+instrument&w1=Drum+machi
nes&w2=Electronic+instrument&w3=Electronic+drum+machine&w4=Electronic+mu
sic&w5=Electronic+musical+instrument&w6=Electronic+instrument+cases&c=6&
s=165&.sig=nHw5UC-j9-ZjaYQWICdp-Q>  	Electronic drum machine
<http://groups.yahoo.com/gads?t=ms&k=Electronic+drum+machine&w1=Drum+mac
hines&w2=Electronic+instrument&w3=Electronic+drum+machine&w4=Electronic+
music&w5=Electronic+musical+instrument&w6=Electronic+instrument+cases&c=
6&s=165&.sig=spiwrXs_p6gNS0FEXa55_Q>
Electronic music
<http://groups.yahoo.com/gads?t=ms&k=Electronic+music&w1=Drum+machines&w
2=Electronic+instrument&w3=Electronic+drum+machine&w4=Electronic+music&w
5=Electronic+musical+instrument&w6=Electronic+instrument+cases&c=6&s=165
&.sig=K1By4GtVfCXqzW97FlwLHQ>  	Electronic musical instrument
<http://groups.yahoo.com/gads?t=ms&k=Electronic+musical+instrument&w1=Dr
um+machines&w2=Electronic+instrument&w3=Electronic+drum+machine&w4=Elect
ronic+music&w5=Electronic+musical+instrument&w6=Electronic+instrument+ca
ses&c=6&s=165&.sig=F-OwTS8Jb7xFq9TR2Fnj9g>  	Electronic instrument
cases
<http://groups.yahoo.com/gads?t=ms&k=Electronic+instrument+cases&w1=Drum
+machines&w2=Electronic+instrument&w3=Electronic+drum+machine&w4=Electro
nic+music&w5=Electronic+musical+instrument&w6=Electronic+instrument+case
s&c=6&s=165&.sig=T7GEVPNNxl16GeH1jvZJeA>
	YAHOO! GROUPS LINKS
	*	 Visit your group "xl7
<http://groups.yahoo.com/group/xl7> " on the web.
	*	 To unsubscribe from this group, send an email to:
<mailto:xl7-unsubscribe@yahoogroups.com?subject=Unsubscribe>
	*	 Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service <http://docs.yahoo.com/info/terms/> .
Re: Digital Output
2006-02-16 by gonzinigonz
Hi
I went through this the other day, check out the very recent post
message 17544..
If you download the latest PX7 manual and has more information in it
regarding this. This is where i got the info i posted.
Also the firmware revisions are document in this manual so its easier
to get your head around the changes that arn't in the earlier model
manuals.
Yes thats right
Just the internal effects are 24 bit...
Digital out is 20 bit, so the manual says..
Gonz
--- In xl7@yahoogroups.com, "Carlisle, Stephen"
>the preferences.  I believe the bit depth is 24, unless you are
>playing the
> Z
> 	-----Original Message-----
Behalf
> Of freakyfreq
>Hello,
>Is the sample rate 44.1 or 48k at the digital output and is >the
>bit depth 16 or 24?
>owners manual doesn't say jack!
Re: Digital Output
2006-02-16 by freakyfreq
Thanks, I'll do that now!
So does the clock on the XL-7 run at 44.1? I'm guessing it does...
then record at 44.1 24 bit to get full bit resolution???
--- In xl7@yahoogroups.com, "gonzinigonz" <gonzini@...> wrote:
> Hi
> message 17544..
it
easier
model
> manuals.
> Yes thats right
> Gonz
in
> >playing the
> > Z
> Behalf
> > Of freakyfreq
> >Hello,
> >bit depth 16 or 24?
Re: Digital Output
2006-02-17 by gonzinigonz
well the sample rate is 44.1khz, so Yes
You can do that, but remember you will gain nothing by recording at a
higher resolution with the XL-7 digitally. You could try recording the
analogue outputs at 24bit, it will sound differant, better or worse..
You might well have no choice, maybe you get the choice of 16 or 24.
Go for it, it should be fine
Check this page out
http://www.digido.com/portal/pmodule_id=11/pmdmode=fullscreen/pageadder_
page_id=27/
Gonz
