1. Enter Song View Mode
2. Press Song Edit button.
3. Select EVENT SOURCE menu
4. Select tempo event
You have the following choices:
--song events only
--1st pattern only
--all patterns
--songs & patterns
I believe what you want to do is create your songs with the "song
events only setting" and have them all start with the same tempo.
Alternatively I suppose you might be able to create a 1-measure (or 1-
beat) pattern as a count off or dummy start, use that pattern as the
first pattern in all your songs, and select "1st pattern only" as your
tempo SOURCE EVENT.
Hope this helps.
--- In xl7@yahoogroups.com, "universumsmedelpunkt" <hjhake@...> wrote:
> Hello.
> I want to have the tempo for the songs to be set so that they are the
> same as eachother and controlled by the general tempo and tap.
> There is a way to do this for pattens but I cant figure out how to
> make all the songs play the same tempo.....
> Any ideas?
