I don't generally do step recording, but I just tested it to record
CCs [via knobs] and it works just fine. In step mode, when you twist
knob(s) and then press play, that CC(s) get recorded at the time
displayed before you press play.
To verify that CCs were recorded, look for them in the EVENT editor.
No need to exit step record mode to use the EVENT editor.
BTW, to test, put your 1st CCs at 001.01.001 [not 001.01.000].
Here's the steps I used:
1. In pattern view mode select an Empty Sequence.
2. Press Record 3x for step record mode.
3a. Set desired Res[olution] and Gate, if inserting notes.
3b. Set desired time for CC [knob settings] insertion.
4. Tweak knobs [ccs].
5. Press Play to advance the sequencer.
etc.
Is this what you are trying to do?
--Steve
--- In xl7@yahoogroups.com, Paul Muon <paulmuon@...> wrote:
> Is there a way to enter controller changes in step record without
> entering notes? I have tried changing a controller ( via one of
> knobs) while using play to enter a rest note, but the controller
change
> isn't recorded. Seems you have to actually enter a note. The only
way
> around this as I can see is to enter notes at a keyboard location
that
> isn't mapped for the active preset ( i.e it will not make any
sound,
> just for your sanity if you are entering 128 precision controller
> changes for a bar!). You could use this non-sounding note to make
> controller changes and then use the pattern:erase events: note
function
> to remove the note after step record has finished.
> Maybe I am missing something?
> -Paul
