mp7 bug. does a sound get stuck on for a while ?
2007-02-20 by romildagreat
Sometimes when im making a track i hit a key and that sound just stays and keeps buzzing for a long time and no matter what i press its just stuck. i cant press play or anything its like it freezes up. any solutions?
2007-02-21 by Bob S.
New setup ? Possible MIDI loop. Or a problem with your controller. Try a different configuration or controller... Bob El Segundo, CA
----- Original Message ----- From: romildagreat To: xl7@yahoogroups.com Sent: Tuesday, February 20, 2007 2:49 PM Subject: [xl7] mp7 bug. does a sound get stuck on for a while ? Sometimes when im making a track i hit a key and that sound just stays and keeps buzzing for a long time and no matter what i press its just stuck. i cant press play or anything its like it freezes up. any solutions? [Non-text portions of this message have been removed]
2007-02-21 by steve_the_composer
(1) Are the presets from ROM or User RAM? (2) If they are from User RAM, were they originally designed for a ROM that you don't have? (3) If so, make sure all the peset parameters are valid.* (I have had a lock up like the one you describe when adapting presets from different ROMS.) *Scroll through Preset parameters an look for ????. examples: LINK 1 PRESET ??? [and LINK 2 PRESET ???] off ARPEGGIATOR ???? Pattern 02^0 (not instld) AUDITIION RIFF ???? Plays:(not installed) Hope this helps. --Steve --- In xl7@yahoogroups.com, "romildagreat" <romildagreat@...> wrote: > > Sometimes when im making a track i hit a key and that sound just stays > and keeps buzzing for a long time and no matter what i press its just
> stuck. i cant press play or anything its like it freezes up. any > solutions? >
2007-02-21 by ROY MILLER
im a lil lost but what i can say is that I installed a protozoa rom and its happened more since then. I mean it would happen without it but it happens a lil more now.
steve_the_composer <smw-mail@...> wrote: (1) Are the presets from ROM or User RAM?
examples:
off
ARPEGGIATOR ????
AUDITIION RIFF ????
Hope this helps.
--Steve
stays
just
> solutions?
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
[Non-text portions of this message have been removed]2007-02-21 by vermis_rex
I've had this happen (or something very similar) on a few occasions with my PX-7. I think it is a MIDI problem, as it (my problem) gets solved every time with a MIDI-all-off (pressing MIDI and HOME/ENTER at the same time). And, as mentioned, it could be my controller (because at the moment I'm using an old CZ-101 I had lying around). --- In xl7@yahoogroups.com, "Bob S." <tttsystems@...> wrote: > > New setup ? > > Possible MIDI loop. Or a problem with your controller. Try a different configuration or controller... > > Bob > El Segundo, CA > > > ----- Original Message ----- > From: romildagreat > To: xl7@yahoogroups.com > Sent: Tuesday, February 20, 2007 2:49 PM > Subject: [xl7] mp7 bug. does a sound get stuck on for a while ? > > > Sometimes when im making a track i hit a key and that sound just stays
> and keeps buzzing for a long time and no matter what i press its just > stuck. i cant press play or anything its like it freezes up. any > solutions? > > > > > > [Non-text portions of this message have been removed] >
2007-02-22 by steve_the_composer
I agree with others' diagnostic suggestions: --Make sure it is not a midi loop lockup. --Try HOME/ENTER + MIDI (midi reset). Also, what OS do you have? If not 2.0, try upgrading the OS. In case those don't clear up the problem, let me clarify my previous steps: (1a) When you experience this kind of lock up, can you tell which preset(s) are in use at that moment? (1b) If you know which presets are in use when the problem occurs, look to see if they are from ROM [eg, P/123] or User RAM [User]. (2) [If they are from User RAM, go to Step 3. If not, you could try testing the ROMS via diagnostics mode, but that seems like a long shot since you are able to use the ROMS.] (3) Select one of the User Presets and check presets: (3a) Press Edit Preset. (3b) Scroll through the Preset parameters and look for question marks (??? or ????) in the display, such as the following: -------------------------- LINK 1 PRESET ??? off -------------------------- -------------------------- ARPEGGIATOR ???? Pattern 02^0 (not instld) -------------------------- [Make sure to check the Pattern page in the ARPEGGIATOR menu] -------------------------- AUDITIION RIFF ???? Plays:(not installed) -------------------------- (4) If you have parameters with question marks, change them to valid settings (no question marks). Again, this may not be your problem; I suggest it because I have had those symptoms with this problem. Hope this clarifies my previous post. --Steve PS: I doubt the problem is due to a bad ROM, but it couldn't hurt to do some diagnostics: (1) Hold both cursor buttons down and power up the E-Mu to enter diagnostics mode. DO >>**NOT**<< INITIALIZE DATA UNLESS YOU WANT TO WIPE OUT ALL USER DATA (including all patterns and all user presets). I can't emphasize this enough: If you initialize data in Diagnostics mode, YOU WILL LOOSE USER PRESETS AND USER SEQUENCES (PATTERNS AND SONGS). (If you only want to wipe out all User Presets, there is a diagnostics option for that.) (2) Run RAM Test, Sound Rom Test for each slot in which you have a ROM, and Sound Data CRC Test. (The RAM and Rom tests should pass; the CRC test should give to a number. You don't want to see the word "bad" as in "bad CRC" or something like that.) (3) When done, select Reboot option. Again, the problem doesn't sound like a bad ROM, but it couldn't hurt to check. --- In xl7@yahoogroups.com, ROY MILLER <romildagreat@...> wrote: > > im a lil lost but what i can say is that I installed a protozoa rom and its happened more since then. I mean it would happen without it but it happens a lil more now.
> > steve_the_composer <smw-mail@...> wrote: > (1) Are the presets from ROM or User RAM? > (2) If they are from User RAM, were they originally designed for a > ROM that you don't have? > (3) If so, make sure all the peset parameters are valid.* > > (I have had a lock up like the one you describe when adapting > presets from different ROMS.) > > *Scroll through Preset parameters an look for ????. > > examples: > > LINK 1 PRESET ??? [and LINK 2 PRESET ???] > off > > ARPEGGIATOR ???? > Pattern 02^0 (not instld) > > AUDITIION RIFF ???? > Plays:(not installed) > > Hope this helps. > --Steve
2007-02-22 by ROY MILLER
yeah this is what it is.ROM [eg, P/123] imma try out what u said. i have my mp7 on v2 but i just installed the protozoa so does that rom have to say v2 also.
steve_the_composer <smw-mail@...> wrote: I agree with others' diagnostic suggestions:
steps:
LINK 1 PRESET ???
off
ARPEGGIATOR ????
AUDITIION RIFF ????
--Steve
diagnostics mode.
to check.
> examples:
> off
> ARPEGGIATOR ????
> AUDITIION RIFF ????
> Hope this helps.
> --Steve
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
[Non-text portions of this message have been removed]2007-02-22 by Bob S.
Don't understand a word you said Roy ! Bob El Segundo, CA
----- Original Message ----- From: ROY MILLER To: xl7@yahoogroups.com Sent: Thursday, February 22, 2007 10:25 AM Subject: Re: [xl7] Re: mp7 bug. does a sound get stuck on for a while ? yeah this is what it is.ROM [eg, P/123] imma try out what u said. i have my mp7 on v2 but i just installed the protozoa so does that rom have to say v2 also. steve_the_composer <smw-mail@...> wrote: I agree with others' diagnostic suggestions: --Make sure it is not a midi loop lockup. --Try HOME/ENTER + MIDI (midi reset). Also, what OS do you have? If not 2.0, try upgrading the OS. In case those don't clear up the problem, let me clarify my previous steps: (1a) When you experience this kind of lock up, can you tell which preset(s) are in use at that moment? (1b) If you know which presets are in use when the problem occurs, look to see if they are from ROM [eg, P/123] or User RAM [User]. (2) [If they are from User RAM, go to Step 3. If not, you could try testing the ROMS via diagnostics mode, but that seems like a long shot since you are able to use the ROMS.] (3) Select one of the User Presets and check presets: (3a) Press Edit Preset. (3b) Scroll through the Preset parameters and look for question marks (??? or ????) in the display, such as the following: -------------------------- LINK 1 PRESET ??? off -------------------------- -------------------------- ARPEGGIATOR ???? Pattern 02^0 (not instld) -------------------------- [Make sure to check the Pattern page in the ARPEGGIATOR menu] -------------------------- AUDITIION RIFF ???? Plays:(not installed) -------------------------- (4) If you have parameters with question marks, change them to valid settings (no question marks). Again, this may not be your problem; I suggest it because I have had those symptoms with this problem. Hope this clarifies my previous post. --Steve PS: I doubt the problem is due to a bad ROM, but it couldn't hurt to do some diagnostics: (1) Hold both cursor buttons down and power up the E-Mu to enter diagnostics mode. DO >>**NOT**<< INITIALIZE DATA UNLESS YOU WANT TO WIPE OUT ALL USER DATA (including all patterns and all user presets). I can't emphasize this enough: If you initialize data in Diagnostics mode, YOU WILL LOOSE USER PRESETS AND USER SEQUENCES (PATTERNS AND SONGS). (If you only want to wipe out all User Presets, there is a diagnostics option for that.) (2) Run RAM Test, Sound Rom Test for each slot in which you have a ROM, and Sound Data CRC Test. (The RAM and Rom tests should pass; the CRC test should give to a number. You don't want to see the word "bad" as in "bad CRC" or something like that.) (3) When done, select Reboot option. Again, the problem doesn't sound like a bad ROM, but it couldn't hurt to check. --- In xl7@yahoogroups.com, ROY MILLER <romildagreat@...> wrote: > > im a lil lost but what i can say is that I installed a protozoa rom and its happened more since then. I mean it would happen without it but it happens a lil more now. > > steve_the_composer <smw-mail@...> wrote: > (1) Are the presets from ROM or User RAM? > (2) If they are from User RAM, were they originally designed for a > ROM that you don't have? > (3) If so, make sure all the peset parameters are valid.* > > (I have had a lock up like the one you describe when adapting > presets from different ROMS.) > > *Scroll through Preset parameters an look for ????. > > examples: > > LINK 1 PRESET ??? [and LINK 2 PRESET ???] > off > > ARPEGGIATOR ???? > Pattern 02^0 (not instld) > > AUDITIION RIFF ???? > Plays:(not installed) > > Hope this helps. > --Steve --------------------------------- It's here! Your new message! Get new email alerts with the free Yahoo! Toolbar. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
2007-02-25 by ROY MILLER
I know I was basically just stating that I had the protozoa rom installed in the mp-7. and I thought that the problem was coming from the protozoa rom. but I think its basically coming from any of the led sounds. Im going to try what u said I havent had the problem in a while though. "Bob S." <tttsystems@...> wrote: Don't understand a word you said Roy ! Bob El Segundo, CA
steps:
LINK 1 PRESET ???
off
ARPEGGIATOR ????
AUDITIION RIFF ????
--Steve
diagnostics mode.
to check.
> examples:
> off
> ARPEGGIATOR ????
> AUDITIION RIFF ????
> Hope this helps.
> --Steve
Sucker-punch spam with award-winning protection.
Try the free Yahoo! Mail Beta.
[Non-text portions of this message have been removed]2007-02-25 by steve_the_composer
Glad to hear you haven't had the problem in a while. --Steve --- In xl7@yahoogroups.com, ROY MILLER <romildagreat@...> wrote: > > I know I was basically just stating that I had the protozoa rom installed in the mp-7. and I thought that the problem was coming from the protozoa rom. but I think its basically coming from any of the led sounds. Im going to try what u said I havent had the problem in a while though.
