using xx-7 as a multimbral sound module
2007-06-09 by unwins4
Hello all, I have a midi keyboard connected to my computer via usb and my xx-7 connected to the midi in and out of my usb interface, my problem is I cannot play anything other than the preset on track 1, my keyboard only transmits on chan1 but I change the channel of the usb interface and all i get is no sound or it just plays track1 preset. Any ideas? mik950
2007-06-09 by BEAUFILS Adrien
Hello,
Try select omni channel receive in midi mode or in global mode i don't remember exacty, may it will work. After select the track you want to play and perhaps your keyboard will transmit the notes on this channel, may be. In this mode any enter midi play the channel enable in preset edit view.
Hope that will work for you because the fact that your keyboard play only on channel 1 is probably the cause of this disfonctionnement.
An other solution for you is to assign the preset you want to play on channel 1 then record it and copy the record on the channel you want but it's not a solution for playing live.
The third solution is to direct the channel via your computer but in this case please retry you question to a person more qualified with the pc, i'm a newbie with software solution.
Hope that help.
unwins4 <unwins4@...> a écrit :
Hello all,
mik950
Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions ! Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses.
[Non-text portions of this message have been removed]2007-06-09 by malik
if you have FLStudio you can just use the keyboard to control a midi out generator and use the menu on the generator to change the channles and send only the generators output to your xx7 --- In xl7@yahoogroups.com, BEAUFILS Adrien <fatalojyxvsfacial@...> wrote: > > Hello, > > Try select omni channel receive in midi mode or in global mode i don't remember exacty, may it will work. After select the track you want to play and perhaps your keyboard will transmit the notes on this channel, may be. In this mode any enter midi play the channel enable in preset edit view. > > Hope that will work for you because the fact that your keyboard play only on channel 1 is probably the cause of this disfonctionnement. > > An other solution for you is to assign the preset you want to play on channel 1 then record it and copy the record on the channel you want but it's not a solution for playing live. > > The third solution is to direct the channel via your computer but in this case please retry you question to a person more qualified with the pc, i'm a newbie with software solution. > > Hope that help. > > unwins4 <unwins4@...> a écrit : > Hello all, > > I have a midi keyboard connected to my computer via usb and my xx- 7 > connected to the midi in and out of my usb interface, my problem is I > cannot play anything other than the preset on track 1, my keyboard > only transmits on chan1 but I change the channel of the usb interface > and all i get is no sound or it just plays track1 preset. Any ideas? > > mik950 > > > > > > > --------------------------------- > Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions ! Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses.
> > [Non-text portions of this message have been removed] >
2007-06-10 by Liquid Saint
I think you would need to have more tracks enabled in your pattern to get to all 16 tracks. What is your main controller and what is the host software that your using? --- In xl7@yahoogroups.com, "unwins4" <unwins4@...> wrote:
> > Hello all, > > I have a midi keyboard connected to my computer via usb and my xx-7 > connected to the midi in and out of my usb interface, my problem is I > cannot play anything other than the preset on track 1, my keyboard > only transmits on chan1 but I change the channel of the usb interface > and all i get is no sound or it just plays track1 preset. Any ideas? > > mik950 >
2007-06-10 by Aaron Eppolito
Make sure to turn OFF "rechannelize input to track destination" in the middle of the MIDI menu. -Aaron
----- Original Message ----
Hello all,
mik950
Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center.
http://autos.yahoo.com/green_center/
